Go to Post Theory is a nice place, I'd like to go there one day. - JamesCH95 [more]
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
VEXpro
ITT Tech
ADVERTISEMENT
Unread 02-06-2004, 05:32 PM
thoughtful's Avatar
thoughtful thoughtful is offline
FRC #1219 (Emery Iron Eagle)
thoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to behold
SMC penumatics sizes
We wanted to order some cyclinders and we have this form from SMC canada where we can order 4 cylinders. They give u the boe size and the stroke size, now i understand the cylinder is about 1-2 inches more than the stroke size. Can anyone tell me about how long will be cylinders with 4",5",6" and 7" of stroke sizes.
Also a bigger bore size can make your compressor run more, but our use of pnemuatics is going to be pretty limited so is it better to have 2 cylinders of 3/4 bore than one of 2", we want to go against a compressed spring.
.:Bringling Brains to Life:.
03,04,05-Team 1219 Captain
2003 Rookie all Start @ GTR
2005 Galileo Semi-Finalist & Alliance captain
06-Team 1219 Mentor
2006 Radio Shack Innovation in control @ Waterloo
Unread 02-06-2004, 05:44 PM
tbmantia's Avatar
tbmantia tbmantia is offline
FRC #1288 (RAVEN Robotics)
tbmantia is an unknown quantity at this point
Send a message via MSN to tbmantia
Re: SMC penumatics sizes
http://www2.usfirst.org/2004comp/200...ics_Manual.pdf
Check here on pages 9-11
Unread 02-06-2004, 06:52 PM
the force the cylinder will produce is equal to the pressure in the line times Pi times half the diameter squared
the retract force is a little less due to the presence of the shaft on that side.
Unread 02-06-2004, 09:21 PM
maxgebhardt's Avatar
maxgebhardt maxgebhardt is offline
resident insomniac
#0555 (we dont have a team name, and what are you gonna do about it!)
Team Role: Student
maxgebhardt is on a distinguished road
Send a message via AIM to maxgebhardt
you say your pneumaics use is going to be limited, just something to consider:
if you are just going to use it to grab the bar go for the 2" bore, because the compressor cant run after the match ends, so you wont waste power. also if you are using it sparingly, you could add more pneumatic tubing between the two tanks to boost storage space. I belive they had a formula to determine the length of a cylender based on bore and stroke, and at the pneumatics workshop they said that formula as well as the pneumatics workshop powerpoint would be on the first web site. now you say your pushing a compressed spring, so I'd like to remind you to ensure there are no latteral forces. think about when you compress a clicky pen spring in your fingers, how sometimes it shoots out sideways. well that cant happen, you'll bend the cylender and render it useless. just a friendly reminder
Always remember... "with sufficient thrust pigs fly just well thank you."
team motto:
Trust, Love and Magic 2003
AFLAC 2002
Will stop for broken speed controlers 2001
{CPA}Maxzilla UT 2004
SMC valve leak? inwoodraider Pneumatics 1 02-02-2003 12:04 AM
SMC Double Solenoid Valve Assembly Dave Kempskie Pneumatics 0 01-29-2003 12:34 PM
SMC Stuff Ian W. Pneumatics 1 01-26-2003 02:30 PM
Hex key sizes archiver 2001 3 06-24-2002 12:21 AM
SMC Accumulator & Cylinders archiver 1999 3 06-23-2002 09:06 PM
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
