gyro help
Kevin Watson,
We used the new code, did the recomended checks at the end of the read me file. The program compiled with no errors, but when it downloaded to the RC, the program state led blinked red and the operator interface showed solid code error. We are using the BEI gryo chip AQRS-00075-109. No print statements are working in the user.c code. |
Re: gyro help
Edit: And just to make sure that I haven't done something knuckleheaded, I'll load up the code on my robot controller tonight and see if I can induce a red-light-of-death. -Kevin Last edited by Kevin Watson : 02-01-2005 at 07:25 PM. |
Re: gyro help
I loaded the gyro code into my full-size robot controller and it worked as advertised. Just out of curiosity, which version of the master processor firmware is running on your robot controller? -Kevin |
Re: gyro help
We are running version 10 of the firmware and had the OI and RC tethered when it was loaded. When I get to school today I will check our print statements and make sure they are still in the right place.
Re: gyro help
-Kevin |
#7
Re: gyro help
We had tried it every different way we could think of. Then finally we tried uninstalling MPLAB and IFI Loader and reinstalling them - after that both codes worked fine. I don't have a clue why this was the problem because it worked with the default code. Thanks for your help.
| Updated: Example Gyro Interface Code | Kevin Watson | Programming | 2 | 03-28-2005 03:36 AM |
| Example gyro code released. | Kevin Watson | Programming | 60 | 03-17-2005 05:32 PM |
| Gyro Troubles | SteveO | Programming | 13 | 01-30-2005 03:46 PM |
| No Signal From Gyro | colt527 | Programming | 12 | 10-19-2004 06:30 AM |
| ADXRS150 gyro yaw rate sensor | Brian M. | Electrical | 13 | 10-17-2004 01:28 AM |
