Go to Post But really, FIRST attracts all kinds of people; nerds, geeks, dorks, preps, techies, PR people, financial persons, etc. - Dorienne [more]
Go Back   Chief Delphi > Other > VEX
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
VEXpro
ITT Tech
ADVERTISEMENT
Unread 10-18-2006, 05:20 PM
Anime-niac_2.9's Avatar
Anime-niac_2.9 Anime-niac_2.9 is offline
Japanese-crap freak(NOTE AVATAR)
AKA: Alex Abenoja, A-Squared, & Anime
FRC #0599 (Robodox)
Anime-niac_2.9 will become famous soon enough
Compiling problem
I am using MPLab v.7.31 for vex. I have all the requirements. The sad thing is the compiler is complaining that the "Coff file format for ifi_library.o is out of date". I changed the library file to Vex_alltimers: still not working. NEED HELP!!! Thank you.
THE ROBODOX FORUM
Reading: Suzumiya Haruhi no Yuutsu by Tanigawa Nagaru
Religion: Haruhiism
Unread 10-18-2006, 05:34 PM
Itinerant Programmer
Re: Compiling problem
Your mcc18 compiler is too new.
The ifi libraries require nothing newer or more recent than version 2.4.
(Thanks Mike)
"Always exaggerate. It makes life seem more interesting." - Robert Weber
Last edited by Mark McLeod : 10-19-2006 at 09:19 AM. Reason: Corrected my wording per Mike
Unread 10-19-2006, 03:10 AM
Electrical Engineer
Rookie Year: 1995
The ifi libraries require nothing older than version 2.4.
Mark,
I think you mean "nothing newer" than 2.40...
Mike
Alex,
I don't think that the older compilers are available from Microchip. However, you can order a programming CD from IFI for $50
Mike
Mike Betts
As easy as 355/113...
Unread 10-19-2006, 02:59 PM
FRC #0599 (Robodox)
The vex code requires a minimum of MPLab IDE v. 6.62. The other computer we have does not have a lower version.
THE ROBODOX FORUM
Religion: Haruhiism
Unread 10-19-2006, 03:13 PM
Sorry we weren't clear.
Your MPLAB version is fine, but there is a separate C compiler MPLAB calls that's responsible for your troubles. The Vex code requires an older version of the Microchip C18 compiler than the one you are attempting to use, and won't work with the latest version.
From http://www.vexlabs.com/vex-robotics-downloads.shtml
The Vexlabs Programming Kit ($99) includes a Programming Module, USB-to-Serial cable, RJ14 6-pin cable , the Microchip MPLAB IDE ver 7.2, the Microchip C18 Compiler ver 2.4 for Vex use
Look for the file C:\mcc18\README.C18 on each of your computers, open and read it using Wordpad or similar. It will tell you the C compiler version on the second line.
Very wierd compiling problem! Max Brin Programming 6 02-08-2006 02:43 PM
compiling in MPlab Greg Needel Programming 2 12-16-2005 11:43 AM
compiling in linux dasRatsel Programming 1 05-21-2005 08:00 PM
Compiling Problems Chris Hleva Programming 11 02-20-2004 04:12 PM
Problem compiling edubot Ben B Programming 3 01-13-2004 11:51 PM
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
