Go to Post If you have the time to be caught up on Delphi and the Q&A forum, then you have time to go write a WFA entry. No more excuses. Go! Write! Now! :) - Jessica Boucher [more]
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
Innovation First International, Inc.
Delphi
ADVERTISEMENT
Unread 08-22-2008, 06:54 PM
kamocat's Avatar
kamocat kamocat is offline
Test Engineer
AKA: Marshal Horn
FRC #3213 (Thunder Tech)
Send a message via AIM to kamocat Send a message via MSN to kamocat Send a message via Skype™ to kamocat
Get pixel color (Labview)
I've started to move into experimentation with image processing for the purpose of tracking or controlling a robot and simulating a field, but more and more I find I need to get the colors of the pixels surrounding the robot for this to be of any use. Is there a way of doing that without using Pixmaps? (If not, is there a way of doing that with pixmaps?)
Thanks!
-- Marshal Horn
Unread 08-22-2008, 09:08 PM
no team (Team NI)
Re: Get pixel color (Labview)
I'm not sure I understand what you are attempting. LabVIEW has basic pixmaps of a sort, but they are called Image Clusters or something similar. You can get at pixels and do basic stuff, but these aren't really for image processing.
For image processing, NI sells an add-on to LV and C for machine vision. This introduces a new datatype and diplay for images, and many many functions for processing the images.
If I'm off the mark, break down the question for me.
Greg McKaskle
Unread 08-22-2008, 09:52 PM
kamocat's Avatar
Test Engineer
AKA: Marshal Horn
I'm not quite sure whether you understand it or not (I think I know what Pixmaps are, but I'm not sure that Labview has the same interpretation of them).
I want to get the color of a specific pixel. Say I have a pixel at coordinates 259, 340. How do I find its color? (Obviously, I can see it, but that doesn't mean I can incoorperate that specific pixel as a value into the block diagram).
-- Marshal Horn
Unread 08-23-2008, 07:48 PM
no team (Team NI)
Where is the pixel? On the screen? If you drew it, then you can index the array of pixels to get at the one you are interested in. If the pixel is part of a camera or video display shown elsewhere onscreen, then you need to access the source content -- the jpeg on disk or frame buffer content.
This is where the types I mentioned in LV come into play. If LabVIEW is a part of the video display, you will end up using the image type provided. If loading JPEGs from disk you will use the image cluster.
As for pixmaps, there are hundreds of variations in how they are defined. LV can manipulate all of them, but it may not have built-in support. With more details, I'd be happy to help.
Greg McKaskle
Unread 08-24-2008, 01:28 AM
kamocat's Avatar
Test Engineer
AKA: Marshal Horn
Thank you! I think I found what I was looking for. I didn't realize it initially because I didn't know what "unflattening a pixmap" meant.
-- Marshal Horn
Does the Trackball Color Match your team Color??? ZInventor Kit & Additional Hardware 14 03-07-2008 07:09 PM
What color Trackball did you get in your kit? Elgin Clock Kit & Additional Hardware 76 03-03-2008 06:04 PM
Pan Center Pixel jdejoannis Programming 1 02-10-2007 07:18 AM
Where can I get LabVIEW? Hershey LabView and Data Acquisition 1 01-21-2006 01:38 PM
HOWTO: Get a good color scheme Brandon Martus Website Design/Showcase 24 11-24-2004 08:52 PM
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
