Go to Post "I'd like the teeter-totter..." - Billfred [more]
Unread 01-27-2009, 05:56 AM
SwampDogs's Avatar
SwampDogs SwampDogs is offline
EE and Software, a bad social combo
FRC #0801
SwampDogs is an unknown quantity at this point
Driver Station Input
Need help resolving an implementation disagreement: locate autonomous configuration switches on driver station or on robot.
So, is the nominal robot gameplay state sequence:
Autonomous-Disabled to Autonomous-Enabled to Autonomous-Disabled...
thus allowing us to read DS station input during the initial Autonomous-Disabled state.
That is the intuitive answer but not clearly defined in the programming guide.
Unread 01-27-2009, 05:57 AM
SwampDogs's Avatar
FRC #0801
Re: Driver Station Input
gracias!
Unread 01-27-2009, 08:01 AM
I can't find the post quickly, but we've been told that the Driver Station inputs will be communicated to the robot in all states except Autonomous-Enabled. That means you'll definitely get a chance to read a DS-connected autonomous configuration selector before the match begins.
Unread 01-27-2009, 10:33 AM
SwampDogs's Avatar
FRC #0801
Out of Autonomous-Disabled mode prior to Autonomous-Enabled. Looking for the right place to initialze. thanks much! R.
Driver station problem team2491 FRC Control System 7 01-30-2009 11:18 PM
Flashing Driver Station Digital Input MacGyver1718 FRC Control System 3 01-15-2009 06:22 PM
Driver Station Setup?? Team 1708 Dave Programming 9 12-19-2008 10:09 PM
Interrupt on driver station digital input Nameless Programming 9 12-04-2008 03:55 PM
Need input on driver's station problem! Hawkins Control System 9 04-03-2008 09:48 AM
Copyright ©2000 - 2016, Jelsoft Enterprises Ltd.
