Go to Post There's no feeling quite like that one you get when you're behind the diamond plate controlling a metal beast that you've put your blood (literally), sweat (more literally), and tears (probably literally) into, and it working. Undescribable. - scali [more]
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
Innovation First International, Inc.
Callahan's Mufflers & Brakes
ADVERTISEMENT
Unread 02-01-2009, 04:57 PM
abross abross is offline
FRC #2729 (LC Storm Robotics Team)
Team Role: Electrical
abross is on a distinguished road
Gyro Sensor
Hello. I was wondering if the gyro included in the KOP, when mounted on a turret (unfortunately off-center mounted), can return information relating to how far from dead center it currently is. I wanted to know if we could use it to get a precise measurement as to how far from neutral our turret has turned.
Thank You.
Unread 02-01-2009, 05:52 PM
DonRotolo's Avatar
Is wishing HE had summers off...
FRC #1676 (Pascack PI Oneers)
Re: Gyro Sensor
That is not a good use for the Gyro (and off-center is a problem). Better off using a potentiometer with a large gear or something, perhaps connected to the motor moving the turret.
Unread 02-01-2009, 06:49 PM
Re: Gyro Sensor
OK. Thanks anyway. That's actually what we're using, but I just wanted to know if there was a way to use a gyro. And one quick question. What does the gyro actually tell you? Number-wise. And if you could give a quick situational example, that would be great.
Unread 02-01-2009, 08:04 PM
Send a message via AIM to Alan Anderson
Re: Gyro Sensor
The "gyro" is actually a yaw rate sensor. Its output is a voltage that tells how rapidly it is being spun, in degrees per second. There is a characteristic voltage that represents zero spin, and a certain number of millivolts above (or below) that voltage for each degree per second it is turning.
Unread 02-01-2009, 08:20 PM
Re: Gyro Sensor
Ok. Thank you. I understand it now.
Gyro Sensor Questions pheadxdll Programming 13 04-08-2008 11:52 PM
ADXRS150 Gyro Yaw Sensor sensitivity? hinewwiner Technical Discussion 5 02-08-2008 08:20 AM
Gyro/accelerometer/Gear tooth sensor sparrowkc Technical Discussion 2 01-11-2008 09:47 PM
ADXRS150 gyro yaw rate sensor Brian M. Electrical 13 10-17-2004 01:28 AM
Gyro Sensor Questions sanddrag Electrical 8 09-27-2003 07:58 PM
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
