Go to Post GP and the Scout Law are high ideals that only the best will achieve and live everyday. - Al Skierkiewicz [more]
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
Innovation First International, Inc.
ITT Tech
ADVERTISEMENT
Unread 01-30-2012, 04:29 AM
cilginbilgin cilginbilgin is offline
FRC #2905
cilginbilgin is a jewel in the roughcilginbilgin is a jewel in the roughcilginbilgin is a jewel in the roughcilginbilgin is a jewel in the rough
Kinect Setup
I'm trying to load Mirosoft Kinect 1.0 Beta2 SDK Setup but at the end of installation it gives an error
Microsoft Kinect 1.0 Beta2 SDK Setup Wizard ended prematurely because of an error. Your system has not been modified [What does that mean] To install this program at a later time run Setup Wizard again. Click the finish button to exit the Setup Wizard.
What do I need to modify to install Mirosoft Kinect Beta setup?
Unread 01-30-2012, 07:38 AM
zaphodp.jensen zaphodp.jensen is offline
Alumni and Mentor of 3130
AKA: Pierce Jensen
FRC #3130 (East Ridge Robotics Ominous Raptors (E.R.R.O.R.'s))
zaphodp.jensen is a jewel in the roughzaphodp.jensen is a jewel in the roughzaphodp.jensen is a jewel in the rough
Re: Kinect Setup
Well, you are going to need to be more specific. Is there an error message that goes along with that? Basically all that message is saying is: "I didn't change anything on your system because something went wrong."
Did you check your system requirements to make sure that you have all of the required components installed before installing the SDK?
Unread 01-30-2012, 08:20 AM
RufflesRidge has much to be proud ofRufflesRidge has much to be proud ofRufflesRidge has much to be proud ofRufflesRidge has much to be proud ofRufflesRidge has much to be proud ofRufflesRidge has much to be proud ofRufflesRidge has much to be proud ofRufflesRidge has much to be proud ofRufflesRidge has much to be proud of
Re: Kinect Setup
Especially Visual C# Express 2010 or another Visual Studio 2010 product.
Unread 04-19-2012, 02:56 PM
ksanger's Avatar
ksanger ksanger is offline
FRC #0211 (MaK)
ksanger is on a distinguished road
Re: Kinect Setup
I had the same issue. No additional error information. Downloaded Visual Studio C++, Visual Studio .Net, Direct X SDK, and reinstalled Microsoft Frameworks 4.0. The 32 bit version would not run on a 64 bit Windows Home PC. Had to load the 64 bit version. Hopefully the other executables required will work with the 64 bit version of the Kinect SDK.
The event viewer for the failure of installing the 32 bit version contains gibberish. Did not find anything online for the event IDs 11708 and 16368.
Product: Microsoft Kinect 1.0 Beta2 SDK -- Installation failed.
Log Name: Application
Source: MsiInstaller
Date: 4/19/2012 3:14:04 PM
Event ID: 11708
Task Category: None
Level: Information
Keywords: Classic
User: xxxxxx\xxxxxx
Computer: xxxxxx
Description:
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
<System>
<Provider Name="MsiInstaller" />
<EventID Qualifiers="0">11708</EventID>
<Level>4</Level>
<Task>0</Task>
<Keywords>0x80000000000000</Keywords>
<TimeCreated SystemTime="2012-04-19T19:14:04.000000000Z" />
<EventRecordID>16368</EventRecordID>
<Channel>Application</Channel>
<Computer>xxxxxx</Computer>
<Security UserID="xxxxx" />
</System>
<EventData>
<Data>Product: Microsoft Kinect 1.0 Beta2 SDK -- Installation failed.</Data>
<Data>(NULL)</Data>
<Data>(NULL)</Data>
<Data>(NULL)</Data>
<Data>(NULL)</Data>
<Data>(NULL)</Data>
<Data>
</Data>
<Binary>7B44463432343134462D463646372D343435382D38 3536362D4344433036313545394139427D</Binary>
</EventData>
</Event>
I'm assuming that we are supposed to download the correct version for our OS even though the instructions were explicit in specifying the 32 bit version. Hopefully the other applications will run under 64 bit. I have no 32 bit processors running win7...
Unread 04-19-2012, 03:13 PM
Itinerant Programmer
Re: Kinect Setup
I'm running it on 64-bit Win 7 Home Premium without trouble and I installed the 64-bit versions.
"Always exaggerate. It makes life seem more interesting." - Robert Weber
Unread 04-19-2012, 03:17 PM
Re: Kinect Setup
The Getting Started with the Control System document specifies the 32-bit version as it appears to be written with the Classmate in mind. The Getting Started with Kinect document tells you to select the appropriate version for your OS.
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
