How is qualifaction score calculated?
Also what is HP, BP, and CP?
Re: How is qualifaction score calculated?
Im pretty sure, HP: Hybrid Points; BP: Bridge Points; CP: Coopertition Points. That was the same question i had last week.
![]() Oh ya, and Qualification Points are calculated like this. If a team wins a match they get 2 Qualification Points. If a team balances on the coopertition bridge with an opponent, all teams on both alliances receive 2 Qualification Points. ![]() Last edited by EagleEngineer : 03-09-2012 at 05:25 PM. |
You get two qualification points when your alliance wins, one in the event of a tie and two coopetition points when the coopetition bridge is balanced with at least one robot from each alliance. Your alliance gets 1 coopetition point for trying to balance the center bridge, defined as the bridge supporting a robot from each alliance, but not being balanced. Your coopetition score is added to your qualification score to produce the final qualification score.
HP=Hybrid Points
BP=Bridge Points CP=Coopertition Points Here's the simple math to figure it out: Qualification Score (QS) = Wins*2+Ties+CP |
posted wrong link. here are the correct ones:
http://frc-manual.usfirst.org/viewItem/58#5.3 Qual scoring: Para 5.3.3 HP BP TP CP explanation: Para 5.3.4 & 5.3.6 |
