Go to Post So Love your robot, and it will love you. - Not2B [more]
Go Back   Chief Delphi > Technical > Programming > WindRiver C++
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
VEXpro
OLHSA
ADVERTISEMENT
Unread 03-27-2012, 10:28 AM
Butter's Butter's is offline
AKA: Joe Kent
FRC #0522 (Robo Wizards)
Butter's is an unknown quantity at this point
Adjust individual motor speed
Quick question. I've checked the library and I am unable to find a function that allows me to change an individual motor speed. I read some where that you can do this with Smart Dashboard but it's too late for us to implement that now. Also, I need to set these values is teleop.
Anyone know how do go about doing this?
Unread 03-27-2012, 11:20 AM
virtuald virtuald is online now
AKA: Dustin Spicuzza
FRC #2423 (Kwarqs)
virtuald is a splendid one to beholdvirtuald is a splendid one to beholdvirtuald is a splendid one to beholdvirtuald is a splendid one to beholdvirtuald is a splendid one to beholdvirtuald is a splendid one to behold
Send a message via AIM to virtuald
Re: Adjust individual motor speed
Create an object, call Set() on it.
// some global somewhere...
Jaguar my_motor(2);
// in your main loop
my_motor.Set( 1.0 );  // full speed in one direction
my_motor.Set( -1.0 ); // full speed in another direction
However, I suspect that is not what you're asking. If you want to control the motor using some external input, then the easiest thing is just pass the value retrieved from a joystick.
Joystick stick;
my_motor.Set( stick.GetY() );
--Innovation is just a problem away
2012 & 2013 Boston Regional Innovation in Control Award
NetworkTables for PC in a python module: https://github.com/robotpy/pynetworktables
FRC Software Resources (including 2012 python code): http://www.virtualroadside.com/FRC/
WPILib Doxygen Repo: http://www.virtualroadside.com/WPILib/index.html
Unread 03-27-2012, 01:06 PM
AKA: Joe Kent
Jaguar my_motor(2);
Joystick stick;
Thank you so much! I actually needed the first one. Our robot has a slight curve so I wanted to make one robot have a little more power than the other (Not joystick based).
I'll go test out a few different values and tell you if it works out!
EDIT: The first method you gave us would move the robot, the second would just control it. Could I maybe make a function that would automatically (Time based) use the .Set method? It would only turn on if your driving with that stick.
public void fixCurve(bool x){
while(x == true){
wait(2.0);
rightmotor.Set(whateverTheNumberWouldBe);
(X is made true when the robot drives and false when they stop)
EDIT: My function would work but we need a formula to determine the speed so this itself doesn't cause a curve..... FUN!
Unread 03-27-2012, 02:11 PM
FRC #2423 (Kwarqs)
Don't use Wait() to implement a timing delay. Use the timer class instead.
Unread 03-27-2012, 02:35 PM
Originally Posted by Butter's View Post
Our robot has a slight curve so I wanted to make one robot [ed: motor?] have a little more power than the other
First and foremost, you want to determine if there is an alignment or friction problem in your drivetrain, or a resistance problem in your wiring, that is causing this. For example, see this post. If you find a problem, it is far better to correct it at the source.
Secondly, What kind of drivetrain do you have, and what is your driver interface? I ask because there may be better ways to compensate.
Unread 03-27-2012, 02:42 PM
AKA: Joe Kent
I probably could answer your questions, however, I would rather talk to one of the team members on the build committee first before I throw out possibly incorrect information.
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
