Go to Post Let me tell you, the scariest day ever was the day that I realized since I am a mentor, people actually take my advice and I should be careful of what kind of advice I give. :ahh: - Elgin Clock [more]
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
VEXpro
Cross the Road Electronics
ADVERTISEMENT
Unread 04-10-2012, 11:35 AM
rbmj rbmj is offline
FRC #0612 (Chantilly Robotics)
rbmj is a jewel in the roughrbmj is a jewel in the roughrbmj is a jewel in the rough
Axis Camera Real-Time Vision Processing
Hi everyone,
I've written a small program to help with vision processing for FRC. Right now it only does the thresholding, but you can use it quickly see the results of thresholding ops in real time. The idea is that if you need to recalibrate your vision processing at competition, then all you have to do is plug your laptop in and you can get new values and see the result of the thresholding ops as you change the ranges. I've tried to make the thresholding as similar as I can to the cRIO's.
URL:
https://github.com/rbmj/axisviewer
Program:
axisviewer
Dependencies:
libcurl (not sure about the version)
gtkmm 3 (sorry, i'm working on getting a gtkmm >= 2.4 version)
cmake (to build)
Because it requires gtkmm 3 there's no currently stable way to build this on windows. However, gtkmm 3.4 is about to be released, and I just got info from the mailing list that this version should work well on windows. As far as the libcurl dependency, that's just there so that I don't have to deal with the http socket stuff. I plan to remove this dependency in the future.
TODOs:
Make the image processing stuff less crufty
Add more vision operations
Get a working gtkmm2 build
and other misc. stuff.
I'll put a screenshot up tomorrow.
If you want to use this with your own, just go to Config->Set Camera IP and use that. It should also *theoretically* work with other IP MJPEG cameras too, you just need to get the correct delimiter. Maybe I can add something to guess the delimiter in the future...
Any suggestions or patches are welcome!
Unread 04-10-2012, 01:36 PM
Re: Axis Camera Real-Time Vision Processing
OK, so here's a screenshot. Should be self-explanatory.
Unread 04-10-2012, 03:06 PM
techhelpbb's Avatar
FRC #0011 (MORT - Team 11)
Very nice.
Unread 04-10-2012, 06:57 PM
I just pushed a revision that adds gtk2 compatibility. I'll see if I can get MinGW to cooperate (I *hate* developing on windows... or any OS without a package manager!)
CMake should now automatically try and find GTK and configure the project to use gtkmm-2.4 or gtkmm-3.0 depending on you installed libraries.
Unread 04-10-2012, 10:26 PM
WizenedEE's Avatar
AKA: Adam
FRC #3238 (Cyborg Ferrets)
If anybody is using arch linux, here's a PKGBUILD. I don't have a camera with me, but it successfully builds and installs the program.
(remove the .txt extension; some people still think the extension matters)
File Type: txt PKGBUILD.txt (954 Bytes, 5 views)
Unread 04-11-2012, 09:21 AM
kenavt's Avatar
kenavt kenavt is offline
outwork us.
AKA: Colin S
FRC #2337 (EngiNERDs)
kenavt has a brilliant futurekenavt has a brilliant futurekenavt has a brilliant futurekenavt has a brilliant futurekenavt has a brilliant futurekenavt has a brilliant futurekenavt has a brilliant futurekenavt has a brilliant futurekenavt has a brilliant futurekenavt has a brilliant futurekenavt has a brilliant future
That's a pretty sweet, simple, lightweight program. Yet, when I want to verify thresholds for our camera at competitions, I just use NI's Vision Assistant with a snapshot photo from the Axis (using the color threshold VI) which works just as simply, although the whole program is a bit clunky.
Are you hoping that this is a program for those who want to use Linux? I suppose I fail to understand the differences between this program and what FIRST and NI have given us.
Drove:
2012 TARDEC, MARC, IRI, Kettering Kickoff
2013 Kettering, Troy, Bedford, MSC, Galileo
Team 2337 GitHub
Hard work beats talent, when talent doesn't work hard.
Unread 04-11-2012, 01:33 PM
After going through DLL Hell and back, I have a prealpha build for win32 here: http://mason.homeunix.org/axisviewer...8b59d0e6df.zip
There's probably a bunch of bugs, so if someone would like to test it, that would be awesome
I'll work on cleaning up the build system on windows later as right now I have to hard-code things to get everything to build properly.
@kenavt: There were a few motivations for me making this program.
1. I don't like having to go into the web interface for the camera, grab a snapshot, open it up, process it, repeat the process to see if it works, etc. So of course the logical thing to save 30 seconds of time (for a programmer) is to spend hours on a program that grabs the stream from the camera and processes it in real time
2. Since the source code is available (and will be made more pretty soon) for the image processing, I'm hoping that anyone who wants to look at the calculations for HSL and the thresholding (and maybe more algorithms in the future) can just open the file and learn from that. You can't do that with NIVision.out (unless you use objdump! - no random NI person who's reading this, I did not disassemble your proprietary code)
3. I like having applications that are crossplatform and lightweight. I personally use linux for all of my development, robotics included, and I prefer to have native builds of my toolchain and development tools.
So, in essence, convenience, open source, and portability provided the reason for writing the program.
Unread 04-11-2012, 07:16 PM
no team (Team NI)
Did you just call me random???
But seriously, I am happy to see you creating your own implementation of the algorithms and making your own tools. Feel free to compare them to the NI results, and if you want to disassemble the NI stuff to see how it does its thing, I'll back you all the way.
I did my own HSL implementation last year and based it on the Foley and VanDam implementation. I know, I know, reinventing the wheel, but as long as you don't fool yourself, building wheels is not a bad hobby. I implemented my HSL algorithm in LV just to see what the performance and implementation would look like. Again, let me know if I can help.
Greg McKaskle
Unread 04-11-2012, 08:28 PM
I know you read the forum a lot, but I don't know if you're the only one.
Sounds awesome!
I'm the king of wheel building; i even have my own kernel (it doesn't work though )!
Unread 04-11-2012, 08:42 PM
Ok, so an update:
The latest code sould work with both gtkmm 2 and 3. I was able to get a working build with version 2.22 on mingw32. I haven't tested it much since the revision i originally posted, though.
Im hoping to develop a bunch of tools - though you arent supposed to reuse robot code year to year, tools dont fall under that requirement. Im still a team member (till June at least) so i dont see any conflict with the spirit of the competition.
Shameless plug: working on build scripts for gcc 4 with rvalue references, lambdas, enhanced libraries, and more fun stuff (see WindRiver C++ forum- busy testing that out).
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
