Go to Post FIRST has the power to change lives, inspire, and make dreams come true. - Jaine Perotti [more]
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
Innovation First International, Inc.
ITT Tech
ADVERTISEMENT
Unread 04-16-2012, 01:23 AM
NIhunter's Avatar
NIhunter NIhunter is offline
AKA: Nicolas Hunter
FRC #2709 (Iron M.A.W.)
Team Role: Driver
NIhunter is an unknown quantity at this point
CIM limited to one direction
We are using 4 CIM motors for a 8 inch mecanum drive. The robot goes forward normally and can strafe in one direction flawlessly. The problem occurs while moving backwards. As 2 CIM motors do not turn the other direction. We are using Toughbox Nano gearboxes if that helps. The jaguars blink red but the wheels refuse to turn. We were demonstrating the robot when we noticed the problem. So we did not have much time to troubleshoot. I will swap the pwm's and check the voltage going to the motors shortly. I was Just wondering if anybody had a problem like this and if they found a solution.
"It is better to fail in originality than to succeed in imitation."
Unread 04-16-2012, 02:27 AM
timytamy's Avatar
timytamy timytamy is offline
AKA: Tim
Team Role: Electrical
timytamy is a name known to alltimytamy is a name known to alltimytamy is a name known to alltimytamy is a name known to alltimytamy is a name known to alltimytamy is a name known to all
Re: CIM limited to one direction
I suspect that when you mounted the CIMS, they somehow managed to be a few degrees out, this can cause a gearbox to seize and would explain your problems.
I'd dismount the CIMS from the tough boxes, test them, and remount. This will tell you if it's a problem localised to the CIMS, or your drive train.
Tim
Systems | Electrical
FIRST® TEAM 3132
Thunder Down Under
Sydney, Australia
Unread 04-16-2012, 06:00 AM
Chris_Elston's Avatar
Chris_Elston Chris_Elston is offline
Controls Engineer
AKA: chakorules
None #1501 (Team THRUST)
Chris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond repute
Send a message via AIM to Chris_Elston Send a message via Yahoo to Chris_Elston
Read this thread:
http://www.chiefdelphi.com/forums/sh...44&postcount=3
See if that's your issue.
Team T.H.R.U.S.T. 1501
Download all of our past robot's source code here:Repository
Favorite CD quote:
"That can't be their 'bot. not nearly enough (if any) rivets to be a 1501 machine." ~RogerR: Team #1369
Unread 04-16-2012, 08:14 AM
Broadcast Eng/Lead Robot Inspector
AKA: Big Al
NI,
The Jaguars do have a failure mode where they only operate in one direction. The first check is to lift the robot and operate the joysticks to see if it works.
Season Eighteen, what a spectacular year! It's has been a bumpy ride. All is better now, new parts are working fine. Champs were spectacular!
Unread 04-16-2012, 09:27 AM
silverD's Avatar
silverD silverD is offline
FRC #2052 (KnightKrawler)
silverD is an unknown quantity at this point
Make sure the limit switch jumpers are seated properly. If the jumpers are not shorting the pins, the jag will not allow the motor to spin in the direction of the open circuit.
Unread 04-16-2012, 09:55 AM
btslaser's Avatar
btslaser btslaser is offline
AKA: Brian Selle
btslaser is on a distinguished road
We have a Jaguar that only commands voltage in one direction. I tried re-flashing it but it didn't help. Is there a way to reset it?
Unread 05-16-2012, 07:48 AM
greasemonkey's Avatar
greasemonkey greasemonkey is offline
If we have it i know where it is
AKA: Fred Parker, fredword, fredwardo, phred, frederick
FRC #3467 (windham windups)
greasemonkey is an unknown quantity at this point
this happened to us this year for us the problem was a couple of bad jaguars have you tried changing them out? if it is not that then it ma be that your cims are bad or mounted incorrectly.
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
