#16
Re: Optical Encoders
When I try to upload the image it says:
Upload Errors aDSC_0142.jpg: Attachment in Progress. Can be deleted here. But I've sat here 5minuets and nothing has happened. |
#17
How large is the file you are trying to upload. |
#18
I have to agree with an earlier poster that there isn't a really good spot to mount the optical encoder. However, do you have a sensor that you could use to count the sprocket teeth or chain links as they go by? Hrm ... probably overthinking things...
#19
#20
An RS775-12 free speed is 7300 rpm, and an RS775-18 free speed is 13,000 rpm. You numbers don't add up1. 1assuming the pronoun "it" in your post refers to the immediately preceding proper noun, i.e. the gearbox output shaft Last edited by Ether : 05-05-2012 at 05:01 PM. |
#22
The Banebot motor-18v (http://banebots.com/p/M7-RS775-18) has a 17040 rpm. After the P60 gearbox with a 16:1 deduction goes on (http://banebots.com/pc/P60K-S7/P60K-44-0007), it has a 1065 rpm. Then the 32 tooth chained to 10 tooth sprocket makes it 3408 rpm.
#23
I just found this. http://banebots.com/docs/EN-G0361-KT-Assembly.pdf . Is this the way to go?
#24
Factor in the loss of efficiency from the geardown/gearup transmission and it's less than that. Last edited by Ether : 05-05-2012 at 05:26 PM. |
#25
I would speculate that they do have the room to mount the encoders he linked to. It's mounted to X bar and should be able to slide back an inch or more.
Jengles, those encoders would be a good option. Although less costly options exist, those may require more work to get them installed. Another consideration: at 128 pulses per revolution, times about 1000 RPM, 128,000 pulses per minute is a lot of data. In software, there is a way to count only every "Nth" pulse (like every 8th pulse for example) that will allow your software to not have to spend all its time counting pulses. Have your programmers look into how that's done, as they'll need to learn how eventually.... |
#27
#28
Hi,
I am looking into a similar option for my team involving encoders. We tried to implement some during build season but due to mechanical inaccuracies, we couldn't get them to fit on and read correctly. (We don't have a machine shop and use hand tools to make all our parts in house.) The banebots encoders that go on the gearbox would fit in nicely with our system, but I was wondering if they would provide an accurate enough reading for wheel speeds being attached to the gearbox rather than the axle. We have a similar setup with live axles, and chained banebots motors with attached gearboxes. We would use the encoders to vary the wheels speeds automatically. We already have a camera set up for alignment. I'm just wondering if the speed read at the gearbox can be used in the code with some adjustments for friction losses accurately. I don't do programming so I can't answer a lot of questions personally on how we wrote the code for the set up we tired to implement earlier. Thanks! -Anna |
#29
I had something similar happen, where I wasn't allowed to upload attachments. If you contact the CD staff they can assist. (I think it has something to do with rampant spam-botting.)
Anyway, here's what ours look like. |
