Go to Post Another human taking a job that a robot could do... - Ryan Simpson [more]
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
Innovation First International, Inc.
ADVERTISEMENT
Unread 06-18-2012, 08:08 AM
tilky's Avatar
tilky tilky is offline
AKA: Ryan Thielke
FRC #3137
tilky is an unknown quantity at this point
dashboard rules
is there any rule defining how the dashboard has to be programmed, or are you allowed to use a UDP connection where the robot sends a string that contains all of the info that is needed on the dashboard, and then you just write a normal vi (and make it an exe) which breaks down the string and acquires the data. would this work, or does the FMS prevent this from happening?
Unread 06-18-2012, 07:00 PM
Greg McKaskle Greg McKaskle is online now
no team (Team NI)
Re: dashboard rules
There isn't a rule, but you need to use an approved TCP or UDP port. There are conventions for how data is passed, but you are free to go your own path.
Greg McKaskle
Unread 06-18-2012, 07:56 PM
tilky's Avatar
AKA: Ryan Thielke
FRC #3137
Re: dashboard rules
approved as in not already taken?
Unread 06-18-2012, 08:36 PM
Itinerant Programmer
Re: dashboard rules
Approved as in not blocked by the field system and dedicated for other uses.
For port restrictions on the playing field see Team UPDATE - 2012-01-20
http://frc-manual.usfirst.org/TeamUpdates/0#term 103
This could change year-to-year so just be prepared to switch ports if necessary.
"Everyone you will ever meet knows something you don't" - Bill Nye
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
