Go to Post Would FIRST be as amazing if not for CD? I mean it would still be this amazing place for students and mentors to be but the explosion of innovation and gathering of people together across communities has to have been greatly effected by CD. - dodar [more]
Unread 06-22-2012, 07:48 PM
2185Bilal's Avatar
2185Bilal 2185Bilal is offline
Driver, Ld. Programmer, Electrical
AKA: Bilal Majeed
FRC #2185 (Ramazoidz)
2185Bilal will become famous soon enough
Post Joystick
hello,
so the problem is that since our robot is a 4-wheel drive, it travels pretty fast. To control the robot we are using a gamepad and the code is written so it is a tank drive. So we use the 2 joysticks on the gamepad to control each side of the robot.
And the problem is that if we just tap the joystick the robot goes flying, so we were thinking of limiting the speed to only 50%, so when the joystick is pushed fully the robot will only travels half speed.
So how do i do that in java
plz help
RAMAZOIDZ
2009 Toronto West Regional - Regional Winners
2009 Waterloo Regional - Regional Winners
Unread 06-23-2012, 11:29 AM
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Re: Joystick
Our standard tank drive regular runs at 50% max speed with a turbo button that boosts it to 100%.
Basically you multiply the joystick output by a constant to send a range of -0.5 to 0.5 to the motor controller. When the turbo button is pressed you double the value. If then statements would work.
My programmer hates it when I look over his shoulder, but I probably could get the code snippets if you want.
Unread 06-24-2012, 07:35 PM
2185Bilal's Avatar
AKA: Bilal Majeed
Re: Joystick
Yes, please. That would be nice. Because i am kind of lost
RAMAZOIDZ
Unread 06-24-2012, 08:08 PM
Re: Joystick
The joystick value ranges from -1 to 1.
Multiply the joystick value by the percentage of power that you want.
e.g., .5 for 50% or .25 for 25% or .75 for 75% power
So, a joystick value of -1 (full forward) * .75 = -.75 (or 75% of full power)
Using this method will cost power on the turns as well as the straightaways though, and depending on your wheelbase/wheel stickyness/ground surface may make turning difficult.
A better answer is to change the sprocket ratio driving the wheels. Increase the sprocket sizes on the wheels to lower your speed and increase turning torque.
“It is not surprising that our common sense fails to grasp the true universe. The problem lies in assuming that our common sense represents reality.” – Michio Kaku
358 Fall 2015 Beta notes & testing results
Unread 06-28-2012, 01:10 PM
2185Bilal's Avatar
AKA: Bilal Majeed
Re: Joystick
This is what i did
Tell me if its wrong or right
    // TELOPERATED PERIOD CODE //
    public void teleopPeriodic() {
    	if (controller.getRawButton(1)){
    		drive.tankDrive(controller, 2, controller, 5);
    	}else{
        	drive.setMaxOutput(0.5);
RAMAZOIDZ
Copyright ©2000 - 2016, Jelsoft Enterprises Ltd.
