Go to Post If you have time at a competition, stop and thank some of the people wearing the crew shirts. They are working very hard to make sure the competition goes as smoothly as possible. - Greg Young [more]
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
VEXpro
ITT Tech
ADVERTISEMENT
Unread 07-02-2012, 03:57 PM
gyroscopeRaptor's Avatar
gyroscopeRaptor gyroscopeRaptor is offline
Registered ConfUser
FRC #3633 (Catalyst)
gyroscopeRaptor has a spectacular aura aboutgyroscopeRaptor has a spectacular aura about
Spikes not working (Solved)
We are working on the robot for the 3rd of July parade and our spikes are not working. We are using one to control a compressor and one to activate a valve. We had the spike that was controlling the compressor working, but it has stopped working oddly. It has an orange light. We have tried using two other spikes for this and the valve spike, but the other two only show an orange light and do not react.
edit1: The lights on the sidecar change.
Unread 07-02-2012, 04:04 PM
BigJ BigJ is online now
AKA: Josh P.
BigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond repute
Re: Spikes not working - URGENT
A spike showing an orange light means it's not getting signal. Did you change your code?
See also: a search for "spike orange light"
http://www.chiefdelphi.com/forums/sh...orange+lig ht
http://www.chiefdelphi.com/forums/sh...orange+ligh t
Unread 07-02-2012, 04:07 PM
Electrical/Programming Mentor
FRC #2177 (The Robettes)
What is the Digital Sidecar (DSC) doing? There are two small LEDs next to each of the relay ports that should light up to show which direction it is signaling.
If those aren't turning on, check the following:
- Code
- Power LED's on the DSC - all of them should be lit up
- Try replacing the DSC.
If they are coming on but the Spike isn't responding, try the following:
- Get a multimeter and probe the DSC output. You should be able to see the pins switch voltages with the lights.
- If the pins look good, plug the PWM cable back into it and probe the other end of the cable, where it plugs into the Spike.
- If the cable looks good, check how you're inserting it into the spike. Make sure it goes in straight, push a little bit to make sure it sits fully, and ensure ground is on the correct side (check that it matches ground on the DSC!).
Unread 07-02-2012, 04:08 PM
cgmv123's Avatar
cgmv123 cgmv123 is offline
Professional Peon
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Team Role: Electrical
cgmv123 is a splendid one to beholdcgmv123 is a splendid one to beholdcgmv123 is a splendid one to beholdcgmv123 is a splendid one to beholdcgmv123 is a splendid one to beholdcgmv123 is a splendid one to beholdcgmv123 is a splendid one to behold
Check your fuses.
Since the robot doesn't have to be competition compliant you can replace all your fuses with auto-resetting breakers. The same ones that go into the power distribution board.
Also make sure you have the spikes plugged into the relay portion of the sidecar, not the PWM/Servo/Jaguar/Victor portion.
I don't get it. We followed all the instructions exactly. Why doesn't it work?
2013 FIRST Championship Curie Division (#breakthecurse)
2013 Wisconsin Regional Chairman's Award
2012 FIRST Championship Archimedes Division
2012 Wisconsin Regional Engineering Inspiration Award, Woodie Flowers Finalist Award (Lead Mentor Ben Senson), Semi-Finalist (1732/1714)
2011 Wisconsin Regional Innovation in Control Award
Unread 07-02-2012, 04:11 PM
Also, if you can make pictures of the important parts available - PDB, DSC, Spike - while in operation (aka LED's on the DSC lighting up when it should be triggered), it could help diagnose. Ensure you have things properly labeled, so we know where the power from the PDB is coming from, which side of the Spike it's going into (double check this, don't assume!), which port each spike is connected to, etc. Something could jump out at us that we wouldn't think to tell you just from a problem description.
Unread 07-02-2012, 04:15 PM
Fan of Canadaland
FRC #0048 (Delphi E.L.I.T.E.)
Send a message via AIM to Travis Hoffman Send a message via Skype™ to Travis Hoffman
Are the PWM cables running between your Spikes and the Relay Outputs on the Digital Sidecar fully seated? Are they oriented correctly? For red/white/black cables, the black wire should correspond to the (-) pin on the Sidecar and the pin labeled "B" on the Spike.
NEOFRA / Time Warner Cable Warren G. Harding FLL Regional Partner
Unread 07-02-2012, 04:23 PM
Registered ConfUser
Smile Re: Spikes not working - URGENT
Thanks to everyone for your advice. It turned out that the PWM cable was not working properly. Who knows how many times it has been pushed in and out over a year and a half? Thanks again.
Unread 07-02-2012, 05:31 PM
akoscielski3's Avatar
Happy Birthday! akoscielski3 akoscielski3 is offline
Mechanical, CAD Designer, Driver
AKA: Aaron Koscielski
FRC #0772 (Sabre Bytes)
akoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond repute
Thanks to everyone for your advice. It turnd out that the PWM cable was not working properly (who knows how many time time it has been pushed in and out over a year and a half). Thanks agian.
This is exactly why I Hate PWM's. They always break or fall out. we actually started hot glueing ours in this year. but they break all the time, so idk if its worth it...
77WHO 772!!!
Mechanical Leader • CAD Designer • Operator Driver
2013 Deans List Finalist Waterloo Regional
Sabre Bytes 77who FACEBOOK PAGE
My Facebook
Unread 07-02-2012, 05:43 PM
CalTran's Avatar
CalTran CalTran is offline
Officially an Alumni :/
Send a message via Skype™ to CalTran
LIKE. We did the exact same thing. They had somewhat less breaking, but turned into an absolute pain for on the fly changing of the victors/jags.
"You know you've been in robotics too long when you start talking to your tools." "Well, you've been in robotics CLEARLY too long when they start talking back"
Theory is when you know everything but nothing works. Practice is when everything works but you don't know why. On our team, theory and practice comes together. Nothing works and nobody knows why.
Unread 07-02-2012, 06:38 PM
Registered ConfUser
We epoxied our cables in on our robot this year but the connectors are becoming worn and we had to scavenge cables from 2011 and 2012. They'll be epoxied later tonight. Thanks to everyone, and we will have pictures and video of our EOD robot after the parade.
Unread 07-02-2012, 06:41 PM
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
How does the hot glue affect the device? Any downside other than having to clean out the glue in order to replace the cable?
He who started the hashtag #omgChiefDelphi
R.C.'s Avatar
R.C. R.C. is offline
Ramping Up for the 2013 Season!
AKA: Owner, WestCoast Products & Design LLC
FRC #1323 (MadTown Robotics)
Send a message via AIM to R.C.
We've had some issues seating the PWM connectors but after they are seated. They are strain relieved and then hot glued. Never touched them since Our FIRST regional.
Rich, its really easy to just take off the hot glue, like 5 minutes worth of work.
-RC
Unread 07-02-2012, 07:09 PM
Registered ConfUser
There may be some residue from the adhesive. We used epoxy, and there is definitely some residue that may have made it harder to reseat and that caused this problem to begin with. That said, the upsides (keeping a compressor working through a match vs. having it unseated and fail) far outweigh any downsides, and 99.9% of situations the cables should be glued or epoxied into their seats on both ends.
Unread 07-02-2012, 09:12 PM
ratdude747's Avatar
AKA: Larry Bolan
ratdude747 has a brilliant futureratdude747 has a brilliant futureratdude747 has a brilliant futureratdude747 has a brilliant futureratdude747 has a brilliant futureratdude747 has a brilliant futureratdude747 has a brilliant futureratdude747 has a brilliant futureratdude747 has a brilliant futureratdude747 has a brilliant futureratdude747 has a brilliant future
Send a message via Skype™ to ratdude747
Another reason I like CAN... If the cable works, it will work virtually forever... Even if somebody messes up and snaps a clip, all that is needed is another clip which can quickly crimped on. Not to mention that you can never get a cable backwards and aside from the left black Jag port of the first Jag (serial CAN), you cannot get the wrong port ever. Now if they only made competition legal CAN relays... that IMHO would be awesome.
1747 Harrison Boiler Robotics 2008-2010
2783 Engineers of Tomorrow 2011
How to wire CAN bus on a budget
Unread 07-02-2012, 10:06 PM
apalrd's Avatar
apalrd apalrd is offline
Embedded Programmer
FRC #0033 (Killer Bees)
We use clear silicone bathroom caulk (it comes in a nice toothpaste-ish tube) for all PWM and other signal wire connectors, plus black duck tape on the radio. It's fairly sticky, and fairly easy to remove.
Kettering University - Electrical Engineering
Kettering University SAE Teams
Chrysler Powertrain - Controls and Calibration
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
