Go to Post please take the time to kick me in the butt. - Andy Baker [more]
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
VEXpro
Modulox
ADVERTISEMENT
Unread 02-18-2002, 03:02 PM
gthakore gthakore is offline
#0843 (WOSS Wyverns)
gthakore is an unknown quantity at this point
programming problem
the x-axis have been switched and i want a way to reverse them
basically right now < make the robot go right(>)
and > makes it go (<)
how do i switch it
gaurav email at gthakore@hotmail.com
gthakore
Unread 02-18-2002, 04:37 PM
Mike Soukup's Avatar
Mike Soukup Mike Soukup is offline
Software guy
FRC #0111 (Wildstang)
Mike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond repute
255 - (x-axis)
Unread 02-19-2002, 07:11 AM
GreenDice GreenDice is offline
GreenDice is an unknown quantity at this point
I think you better use 254 - x instead.
Peter Liu
Unread 02-19-2002, 07:58 AM
Ian W. Ian W. is offline
College? What?
no team (Gompei and the Herd)
i had this problem with my y-axis, and tried some elaborate solution, but this is much easier. figures, you never think of the easy thing first. oh well, at least the code for the robot is stupidly easy to change.
Unread 02-19-2002, 09:40 AM
I think you would be better off with 255 - x max 254, unless you guarantee that x is never greater then 254 before that.
This will help to keep from outputing two 255's in a row which will reset the data packet and cause all kinds of interesting things to happen.
Unread 04-12-2002, 11:05 AM
FotoPlasma FotoPlasma is offline
FotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond repute
Send a message via AIM to FotoPlasma
We use some robot reversal code:
'|	The following code reverses joystick directoin				  |
'|	p1_sw_top[reverse jdriection];pwm1,pwm2[motor speed/direction]
' it'll be confusing as hell
' but oh well
'How to Swap the Iinformation in Two Variables Without Using a Third Variable!:
'or: XOR is Your Friend =)
if p3_sw_top then forwards:
'---swap right and left pwms
	PWM1 = PWM1 ^ PWM2
	PWM2 = PWM1 ^ PWM2
	PWM1 = PWM1 ^ PWM2
'---invert values of joysticks around 127
'------Thanks to Joe Ross from team 340! :D
	PWM1 = ( 254 - PWM1 )
	PWM2 = ( 254 - PWM2 )
forwards:
It's not elaborate, or even too important, but I'm really proud of it...
I played hacky sack with Andy Baker.
2001-2004: Team 258, The Sea Dawgs
2005: Team 1693, The Robo Lobos
Unread 04-15-2002, 09:36 AM
VanWEric VanWEric is offline
#0250 (Dynamos)
VanWEric is an unknown quantity at this point
impressive
I like the whole xor thing. However, i think it is easiest to just say variable = (!variable). I think that works. If you want to see some really fun manipulation of variables, take a look at one of my previous posts (one line power??). i'll have it bit optimized for next year
Unread 04-16-2002, 11:20 PM
The guarantee comes from Innovation First's code which will not allow a reading of a joystick or other pot to become more than 254.
254-x works fine, as shown in this table (in monospaced type font):
x value in :...0........127.........254 (max)
254 - x....: 254........127...........0
255 - x....: 255 ** ...128...........1
Unread 04-18-2002, 02:27 PM
jeremy562 jeremy562 is offline
Engineer
#0562 (SPARK 562)
jeremy562 is an unknown quantity at this point
Send a message via AIM to jeremy562
Here's the REALLY easy solution
Reverse the wires from the speed controller to the motor. Problem solved!
SPARK 562: Students Pursuing Applied Robotics Knowledge
2006 BAE Granite State Regional: Finalists with 319 and 176
2006 BAE Granite State Regional: Winners of Motorola Quality Award
2004 BAE Granite State Regional: 7th Seed
2004 Mayhem on the Merrimack Champions! Thanks, 61 and 1289!
Unread 04-18-2002, 02:54 PM
Greg McCoy's Avatar
Greg McCoy Greg McCoy is offline
boiler up!
FRC #3940 (CyberTooth)
Greg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond repute
Send a message via AIM to Greg McCoy
Yep, that's the fastest and most efficient way of doing it. Why make your software think more then it has to?
Fast code = good code
Unread 04-18-2002, 04:37 PM
Engineer
#0562 (SPARK 562)
hehe it would work in a simple situation where you only care about one axis.. but since in this case he also cares about the y-axis it wouldn't be that simple because swapping the motor wires would reverse both axes. He does need to do something in the software.. in this case
Unread 04-18-2002, 04:58 PM
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
At the beginning of my code, I set up a bunch of aliases for variables. (ie leftDrive VAR PWM1, etc). Then, when I run into a problem like this, I just have to change the aliases and everything else in the code changes automatically. Not easy to do for code that's already written, but something to think about next year....
Unread 04-18-2002, 05:17 PM
Jnadke Jnadke is offline
Go Badgers!
#0093
Jnadke is on a distinguished road
Send a message via ICQ to Jnadke Send a message via AIM to Jnadke Send a message via Yahoo to Jnadke
Or you can just write it to scratch pad ram...
Swap:
put 0, PWM1
PWM1 = PWM2
get 0, PWM2
Inverse:
PWM1 = ~PWM1
PWM2 = ~PWM2
The best moments of our lives fall in two categories: those that did happen and those that did not.
Unread 04-19-2002, 09:34 AM
Using 254-x Max 254 is better, but it can still cause errors. For example, if x=255, then 254-x will evaluate to -1, which in PBASIC is approx 65,000. You then take the max and get 255. While this will prevent basic run errors, it can still cause run-time logic problems.
While it's not likely that x will be 255, its still a possibility I don't like leaving. Therefore, I would reccomend the following code:
x=2254-x Min 2000 Max 2254 - 2000
Unread 04-19-2002, 09:46 AM
Can someone else confirm this, because I can swear that I have seen 255 come from a joystick.
Victor problem Andy Baker Electrical 15 06-24-2003 08:49 AM
multi-bank programming problem GregC Programming 3 02-14-2003 03:13 PM
The problem with scouting... archiver 2001 10 06-23-2002 10:49 PM
Major problem with chipphua motors aka Scott White Motors 18 03-19-2002 06:44 PM
Error found in programming for the pump and pressure switch sjharobotics Programming 4 02-06-2002 04:46 PM
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
