Go to Post You know FIRST is on the level of sports when you can give predictions like sports casters do. :) - RoboMaster [more]
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
Innovation First International, Inc.
ProCare Services
ADVERTISEMENT
Unread 02-02-2008, 12:44 PM
DPTeam270Driver's Avatar
DPTeam270Driver DPTeam270Driver is offline
Deer Park Driver
FRC #0270 (Falcon X)
Team Role: Driver
DPTeam270Driver will become famous soon enoughDPTeam270Driver will become famous soon enough
Gear Tooth sensor Programming
hello,
there is a discrepensy within our team
one of our members wants to put 2 gear tooth sensors on both of the motors(one on each). he says that they will be in sync with eachother( in case one motor is slower than the other). is this possible to be done with programming
or will they automattically sync eachother.
-team 270
Unread 02-02-2008, 12:47 PM
psy_wombats's Avatar
psy_wombats psy_wombats is offline
AKA: A. King
FRC #0467 (Duct Tape Bandits)
psy_wombats has a spectacular aura aboutpsy_wombats has a spectacular aura aboutpsy_wombats has a spectacular aura about
Re: Gear Tooth sensor Programming
Are you putting gear tooth sensors on four driven wheels, two on each side, or are you putting two gear tooth sensors on two driven wheels, one on each side?
Either way, if you're trying to look to synchronize motor speeds with code, you could always try 2 PID loops for each side of the drivetrain. If you mean trying to find values for distance with many gear tooth sensors, taking the average should suffice.
I guess clarification would make it easier to answer the question.
Unread 02-02-2008, 12:49 PM
usbcd36's Avatar
usbcd36 usbcd36 is offline
AKA: "DOS"
FRC #2399 (The Fighting Unicorns)
usbcd36 is a jewel in the roughusbcd36 is a jewel in the roughusbcd36 is a jewel in the rough
There are ways to do this with sensors, however, the motors will not "automatically" turn at the same speed.
If your programmer really knows what he's doing, he'll be able to do this, given some time (PID for position control, PD for velocity control, etc…). If he doesn't, he can probably find the information here.
Also, if you haven't corrected the problem with the gear tooth sensors (which involves switching two tiny resistors on one of the boards), you won't get anywhere with them.
Unread 02-02-2008, 04:16 PM
Deer Park Driver
Team Role: Driver
we were going to put the sensors on the gear boxes so it would count the gear teeth in there. there is a mount for them there(on the plexi side).
to clear up some info,
and we are going to send in the sensor to get it fixed
Unread 02-02-2008, 04:55 PM
Gamer930's Avatar
Gamer930 Gamer930 is offline
Team 930 and 171 Alumni
AKA: Justin
Gamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to behold
The holes on the Lexan Sides are slightly off we have noticed. . . We ended up making our own holes on the metal side and using some short standoffs.
2010 to Present, Volunteer
2005 - 2010, Team 171 College Mentor
2002 - 2005, Team 930 Student
Gear Tooth Sensor marco_alchemy Electrical 7 02-06-2008 08:54 AM
Gear Tooth Sensor Maria*61806* Electrical 0 01-30-2008 08:07 AM
Gear Tooth Sensor Nathan Programming 4 01-12-2008 02:09 PM
Gear Tooth Sensor nukem Programming 9 02-04-2006 07:21 PM
Gear Tooth Sensor Talha Electrical 1 01-23-2006 08:29 PM
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
