Go to Post It is sad when the robots do not perform as we designed them. It is sadder still, when they perform well, but they are not victorious. However, it is most saddening when they win at a competition, and competitors are unwilling to acknowledge the teamwork and good fortune of the alliance. - Bill Moore [more]
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
Innovation First International, Inc.
Delphi
ADVERTISEMENT
Unread 12-20-2005, 02:03 PM
Mike's Avatar
Mike Mike is offline
has common ground with Matt Krass
AKA: Mike Sorrenti
FRC #0237 (Sie-H2O-Bots (See-Hoe-Bots) [T.R.I.B.E.])
Mike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond repute
How to ask a question
Well, the new season is coming and there are going to be an abundance of new threads started asking questions. Here is some info that you should provide that may help people answer your questions:
Detailed description of what is happening that shouldn't be.
Instead of saying "The robot doesn't work when I run code X." Compare what IS happening, to what SHOULD be happening.
eg: The robot's arm is moving to the third position when it should be lowering.
Well commented, understandable code
This should be your normal coding style, but if not please revise the sections of code that you post. We didn't write the code, so we have no idea what you are attempting to accomplish with a certain line.
Hardware setup
Is your left side of the drive train connected to PWM port 1? Is the arm potentiometer connected on analog 1 or 2? All of this needs to be specified.
Feel free to add onto this post.
-Mike
Unread 12-20-2005, 03:32 PM
Andrew Blair's Avatar
FRC #0306 (CRT)
Re: How to ask a question
I agree with what you said completely, and would like to thread expand this a little more broadly past programming.
Heres a good tip, supplementing what Mike already said: Give examples, examples, and more examples! All too often ( I've done it, I should know) there are posts and threads that go "how do I do this"? How should I lift the tetra? Should I use wheels or tracks? All very good questions, but a bit too general, with no other info. Say for example,
"How are teams holding on to the tetra? We have a spear design that works alright, but what would you suggest as an alternate design?"
Oh, and specific thread titles. Instead of "why is this stuck?", title it " Fisher Price Gearbox Binding" Just helps with some confusion entering the thread.
These tips are all over the place, but Maybe not in one, question asking thread. Does anyone have a link?
-Sir Francis Bacon
-Albert Einstein
Unread 12-21-2005, 09:40 AM
Cuog's Avatar
Cuog Cuog is offline
Registered Linux User: 390661
AKA: Alex
FRC #0422
Send a message via AIM to Cuog Send a message via Skype™ to Cuog
I would like to add that under the readable code act of Yesterday 03:03 PM that variables and classes are easily identified, when looking at your code i dont know the difference between what x, y, z and asdet all mean give varibles meaning,
Also try to space code out if there is a block of code that is an algorithm(sp?) or accomplishes a particular purpose, double space above and below it(comments are great too) and single space inside the block that makes the outside readers life much easier
In addition when you are here for a problem try to give a timeline of what you have tried and how it has worked
ex: I changed this equation to calculate arm positition so that it should move right and now its even less accurate
Thanks,
Cuog
KK4KQO
Join us in FIRSTchat
IRC: irc.freenode.net #firstchat
Unread 01-17-2006, 09:41 AM
Mike's Avatar
AKA: Mike Sorrenti
Spelling and Grammar
We aren't asking for much here. Theres no need for your post to read like a 16th century Shakespearean sonnet. Just some basic spelling and grammar. An example:
Originally Posted by Bad
Hei,
our program teams desined a custommly made analog 2 digi converting system. but the refrence voltage dosn't always stay the same, wich makes us take bad readngs. plz hlp.
Originally Posted by Good
Hello all,
Our programming team has recently made a customized version of the Analog to Digital Converter. However, as the battery dies down the reference voltage changes... which causes inaccurate readings. Has any other team overcome this obstacle? Thanks.
-Mike
Unread 01-29-2006, 10:27 PM
Finally An Engineer
FRC #3280
If you call a function from some where else in your code be sure to post it to. It is impossible to find an error that relates to "do_this_now(do_it_when, Do_it_how)" if we dont know what that function is. Also even though the function may compile fine there is no gauruntee that it isn't what is causing a problem.
If the problem is a compiling error copy and paste the error straight from mplab, it is very difficult to find out why the code wont compile if all you tell us is "It says something about something being called twice"
Also while Mike said "Theres no need for your post to read like a 16th century Shakespearean sonnet" I would be impressed if you did post in the form of a sonnet (even more so if you could code in sonnet form).
6 Teams 7 Years
3594 (2011)
3280 (2010)
1665 (2009)
1350 (2008-2009)
1493 (2007-2008)
1568 (2005-2007)
Unread 01-29-2006, 11:19 PM
SoftwareBug2.0's Avatar
AKA: Eric
FRC #1425 (Error Code Xero)
SoftwareBug2.0 is on a distinguished road
Maybe we should have a contest that runs from ship date to nationals to do exactly that.
Unread 01-30-2006, 06:47 PM
Astronouth7303's Avatar
An inspired alumnus
AKA: Jamie Bliss
no team (previously 904 (D-cubed) and 1227 (Techno-Gremlins))
Send a message via ICQ to Astronouth7303 Send a message via AIM to Astronouth7303 Send a message via MSN to Astronouth7303 Send a message via Yahoo to Astronouth7303
Cool Re: How to ask a question
Might even qualify for the IOCCC!
Unread 03-25-2006, 08:41 PM
Mike's Avatar
AKA: Mike Sorrenti
Heh, cool little thing I found that relates to the whole sonnet thing. It's called the Shakespeare Programming Language and is a language that is designed so when you write programs, they look like plays.
http://en.wikipedia.org/wiki/Shakesp...mming_language
-Mike
Unread 07-20-2006, 05:31 PM
TheOtherGuy's Avatar
TheOtherGuy TheOtherGuy is offline
Unregistered User
AKA: Kevin Forbes
FRC #4183 (Bit Buckets)
TheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond repute
Hello all,
I know I'm kindof new to programming, but it might help if when you are showing people your code, you could point out the problem with a different color.
ex.
blah blah blah
blah blah
blah blah blah
blah blah
blah blah
and if you are responding to someone's problem with code that you fixed you could do the same thing.
Unread 07-20-2006, 11:54 PM
Send a message via AIM to Alan Anderson
That could be less useful than you think. If you can correctly identify where the problem is, you can probably fix it. The trouble is that, most of the time, the problem is that the person trying to make the program work doesn't know where the problem is.
Unread 02-03-2008, 06:29 PM
ShotgunNinja's Avatar
ShotgunNinja ShotgunNinja is offline
Vice-President, SCOE Robotics
AKA: Nicholas Iannone
no team (SCOE Robotics)
ShotgunNinja is a jewel in the roughShotgunNinja is a jewel in the roughShotgunNinja is a jewel in the roughShotgunNinja is a jewel in the rough
Also, wouldn't it help to actually tell the person what IDE they are using (MPLAB, ROBOTC, EasyC ) or, if they aren't using any, then say that.
2006-2007: My FIRST Experience - School Mascot for Team 1652 at the Wisconsin Regional
2007-2008: FIRST Year on the Team and already in Overdrive - Programmer for Team 1652 (Robot Mafia) at the Wisconsin Regional - Finalists
2008-2009: Senior Year is Lunacy! - Lead Programmer on Team 1652 (Robot Mafia) - Midwest Regional (Semifinalists), Milwaukee Regional (4th Seed) AND Rookie Team 2970 (eSchool eBots) - Milwaukee Regional (3rd Seed, Finalists), Minneapolis North Star Regional (5th Seed, Winners, Rookie All-Star winners), Championship Newton (7th Seed, Semifinalists)
2009-2010: To be continued... as a Mentor?
I still have the original 2007-2008 FIRST IR sensor prototype. It's sitting on my bookshelf.
Question of the Week!!! (6/14/04) Andy Grady General Forum 23 07-01-2004 02:54 PM
Question of the Week [05-02-04]: The Very Merry Month of May EddieMcD Rumor Mill 10 05-05-2004 01:02 PM
MIM's question of the day on programming. Gene F Programming 3 02-24-2004 03:32 PM
A question about control system options computhief263 IFI Control System 7 02-04-2004 01:46 PM
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
