Go to Post [You know you've overdosed on FIRST when...] When you discover that the cure to the swine flu is "oink oink BOOM!" - Katie_UPS [more]
Go Back   Chief Delphi > Technical > intelitek easyC/REC information > REC/Learnmate
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
VEXpro
ITT Tech
ADVERTISEMENT
Unread 03-19-2008, 10:29 AM
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
Intelitek CNC Motion - Virtual CNC Machines
CNCMotion integrates interactive 3D simulation with CNCBase machine control software for dynamic simulation and graphic tracking of Intelitek's CNC mills, lathes and router.
CNCMotion simulates the entire machining process in real time-accurately reflecting the movement of machine components and tools, and the form of raw materials changing into finished parts.
The virtual machines in CNCMotion respond to errors and environmental conditions in the same way as safeguards on real machines prevent injury and damage. Safety measures include halting NC program execution upon impact or axis limit, and warnings of unsafe hardware conditions (e.g., safety shield open, tool missing, tool impact on the cross-slide or holding device).
As a powerful visualization tool, the software enables testing and debugging of programming, as well as full machine setup, prior to actual CNC machining and turning.
The simulation includes fixturing with all available Intelitek hardware options. For example, simulated stockholding options for the Super proLIGHT 1000 machining center include a 52-piece hold-down set, machinist vise, low profile clamping kit and two air vises. Simulated tooling options for the Super proLIGHT 1000 include flat end mills, ball end mills and drills, along with R-8 tooling, quick-change tooling, and automatic tool changing (ATC).
The realistically simulated CNC machines give students and machine operators valuable experience before they begin working in a CNC workshop.
Download a Demo of CNC Motion
Note: When Installing Select "CNC Motion for Super Prolight" and Select "Default Setup" for Machine Serial Number
For a demonstration or additional information please contact Intelitek Sales at 800-221-2763.
CNC 3D printer sciencenerd Technical Discussion 5 08-06-2007 12:32 PM
CNC Machines DEAL234 Technical Discussion 17 02-07-2007 03:30 PM
What machines are you using? (CNC, lathes, mills, 3-in-1 machines?) MrB Technical Discussion 17 11-03-2006 10:55 AM
Help - G-Code Circular Motion for CNC Milling sanddrag Technical Discussion 15 08-18-2004 10:00 PM
To CNC? Or not to CNC? phrontist General Forum 21 03-26-2004 12:45 PM
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
