Go to Post week 7: check to see if the pets are still alive, ask significant others to take us back, do 6 weeks worth of make-up homework, and ask my boss for another extension. - Tim Baird [more]
Go Back   Chief Delphi > Technical > Programming > WindRiver C++
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
VEXpro
Tormach
ADVERTISEMENT
Unread 01-10-2009, 03:25 PM
7-11number1 7-11number1 is offline
ROAR.
FRC #1711 (RAPTORS)
7-11number1 will become famous soon enough
Getting Started in Windriver C/C++
Can anyone point me to a good "Getting Started" resource for Windriver C/C++ FRC programming? We have our physical control system completed, device's IP'ed, but are stuck on compiling, downloading, setting the Team Number in the IDE workspace preferences etc... The FRC manual was not complete and trails off on page 84.
If someone even has a simple step-by-step 1,2,3 text file for getting a project going I would appreciate it. I am starting to get stressed out, due to lack of progress, I had hoped to be driving today...... Also, if anyone knows of sample source for setting up I/O, reading joysticks, that would be appreciated as well.
Thank you, thank you, thank you!
-Michael George
Mentor - Team #1711
Traverse City, MI
Unread 01-10-2009, 04:16 PM
Stimpy1901 Stimpy1901 is offline
AKA: Bobby
FRC #2348 (Cool Geeks)
Stimpy1901 will become famous soon enough
Re: Getting Started in Windriver C/C++
Compiling: Project->build project
This will create a .out file and place it in the project folder under another folder (mine is PPC603gnu) under debug (e.g. \visiondemo\PPC603gnu\visiondemo\debug\visiondemo. out
1. Set up connection:
a) Target-> New Connection->Select: Wind River VxWorks Target Server Connection.
b) set the target location to the 10.xx.yy.2; Kernel image: select file and browse to c:\windriver\WPILib\vxWorks
c) click finished
If you are connected to the cRIO (either through the DS or directly), windriver should connect (in the remote systems window, you should see your new connection).
2. Window->Preferences: On left menu of preferences, click FIRST Download Preferences; enter team number and navigate to the .out file you want to download (note: you will need to change this file each time you want to upload a different file--with a different name--to the cRIO).
3. FIRST->Download
4. Reboot the cRIO and use the DS toggle to enable/disable programs
I know this is in a document somewhere...but I cannot remember where.
NOTE: Thanks to others on CD, I found out that if you right click on your VxWorks connection in the remote systems window, go to Target Tool->target console, select okay (I haven't played with the settngs), you will get a console window with any printing commands.
NOTE: be sure to update the cRIO with the latest firmware (version 7) from: http://first.wpi.edu/FRC/frcupdates.html
Hope this helps!
Last edited by Stimpy1901 : 01-10-2009 at 04:25 PM. Reason: missed info about compiling
Unread 01-10-2009, 08:26 PM
Itinerant Programmer
A later version of that guide came with the latest Wind River V1.2 update.
Look for it on your PC at C:\WindRiver\docs\extensions\FRC
The Guide will grow and improve with each new update.
"Everyone you will ever meet knows something you don't" - Bill Nye
Unread 01-10-2009, 08:46 PM
comphappy comphappy is offline
AKA: Brennan Ashton
FRC #2605 (A2D_16)
comphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to behold
Send a message via AIM to comphappy
Chapter 3 of the control system manual will be your friend for getting the team number and updates applied.
http://www.usfirst.org/uploadedFiles...s-Rev-0-5a.pdf
The userguide is a very limited help unfortunately, our programming team sat down today and wrote a good portion of our autonomous code with the camera. You will find that this:
http://www.virtualroadside.com/WPILib/annotated.html
Will be your friend as well as the individual source files. We worked almost exclusively off of them.
While I am encouraging teams to use C++ as it has more features for debugging (the NI guys will argue with me about that but I have yet to see a real example) you will at this point need to have a solid understanding of classes, inheritance, and types, especially what an enum is.
There are also a lot of FIRST examples under File->New->Example->VxWorks Downloadable Kernel Module Sample Project
Not none of this will work right until you have applied the WPILib, NI, and DS updates.
A2D Solving the Imaginary Error Function...
Getting Familiar with Programming in WindRiver kyungjin WindRiver C++ 35 01-17-2009 12:04 PM
Programming - Getting Started Mark McLeod Programming 80 04-16-2008 10:37 PM
FPGA getting started Rickertsen2 Electrical 4 09-10-2005 11:52 AM
Getting Started Cheese Head Programming 4 10-09-2002 09:24 PM
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
