OCCRA   [more] Florida Regional : 109d 06h 00m ...
Go to Post I believe that your career should support your dreams. - Tytus Gerrish [more]
Team 47   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
HEXBUG Nano
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Delphi
ADVERTISEMENT
Old 11-03-2009, 09:42 AM
robself705 robself705 is offline
FRC #0706
robself705 is an unknown quantity at this point
Robotic T-Shirt Cannon
This is our cannon.
http://www.youtube.com/watch?v=xKCwbomY82c
We have 4 compressors, 3 batteries, 4 cim motors, we are using a 3/4 in gate valve modified with a pneumatic piston to release the air. The video is of a shot at 20 psi. We have shot up to 200 feet before and can shoot 10 shirts in one load.
Old 11-03-2009, 05:08 PM
Stephen of REX Stephen of REX is offline
FRC #1727 (REX)
Stephen of REX is an unknown quantity at this point
Re: Robotic T-Shirt Cannon
That robot fires compressed win! How many shots from one tank, how long to recharge? I love the treads and overall clean white design.
Also, how exactly is your gate valve seated? My team uses a 1" gate valve with a cylinder, like yours. But It keeps jamming closed due to the pressure closing it.
Unfortunately I cannot approve of the PVC air tank.
Go REX 1727!
Old 11-03-2009, 07:32 PM
reversed_rocker's Avatar
reversed_rocker reversed_rocker is offline
Team Leader / Programmer
FRC #0706 (Cyberhawks)
reversed_rocker is an unknown quantity at this point
we just finished it so we didnt have time to work out the details. How many shots on each tank depends on how quickly the pneumatic valve opens and closes, thats a simple thing to change in the code but we havent had time to find the perfect value. So far it looks like we can get about 2 shots per charge, but it starts filling air as soon as it fires and it only takes about 3-6 seconds to go from fully empty to fully charged.
note: the shot in the video was taken at 20 psi with a leaky pbc joint. before we had the turret mounted to the tank treads we were shooting at 60 psi. the video of the turret is on cheif delphi/youtube somewhere...
Old 11-03-2009, 08:50 PM
FRC #0706
I know there is a lot of debate on PVC for pressure fittings but we have done the research, read all of the hazards and found tests that approve the schedule 40 pvc 3in that we are using has a SAFE working pressure of 200 psi. We rarely go above 60psi. In addition the burst pressure in tests shows that the pvc wont burst until 700 psi. I understand all of the concerns but a lot of the horror stories come from tanks that have been beat around, dropped, improperly glued, etc. Ours is securely mounted and cant be dropped or hit easily. We have considered building a copper tank but for the time and money required we will stick with the pvc. If we note anything unusual about it we will definitely switch. We have had much discussion about this issue. I will be doing a more in depth review of our robot when time permits.
Old 11-03-2009, 09:58 PM
squirrel's Avatar
squirrel squirrel is offline
parent
AKA: "Mister Forbes"
FRC #1726 (N.E.R.D.S.)
squirrel has a reputation beyond reputesquirrel has a reputation beyond reputesquirrel has a reputation beyond reputesquirrel has a reputation beyond reputesquirrel has a reputation beyond reputesquirrel has a reputation beyond reputesquirrel has a reputation beyond reputesquirrel has a reputation beyond reputesquirrel has a reputation beyond reputesquirrel has a reputation beyond reputesquirrel has a reputation beyond repute
The pressure ratings for liquid probably should not be used for air, though.
I suggest you change the tank material...even if the risk is low, you're gonna get lots of flak from concerned people here, and some of them have hair raising horror stories....
Old 11-13-2009, 03:33 PM
Bruceb Bruceb is offline
Bruceb can only hope to improve
If you put a restrictor valve on the close side of the piston valve you can make the valve close slow enough so it does not jam.
Bruce
T-Shirt cannon pnuematic set ups Tanis Pneumatics 62 07-21-2009 11:16 PM
pic: TEAM 343's t-shirt cannon DRAKE343 Extra Discussion 14 04-20-2009 06:58 PM
pic: T-Shirt Cannon at Purdue's Homecoming jtdowney Extra Discussion 10 11-08-2007 07:48 PM
IRI T-shirt cannon Kyle Love Off-Season Events 6 07-17-2007 12:09 PM
pic: 549's t-shirt cannon and ballon inflator w/ horn griff549 Extra Discussion 2 05-06-2007 12:36 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
