Go to Post Sleep is for the weak - TEntwistle [more]
Go Back   Chief Delphi > Technical > Electrical > CAN
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
VEXpro
Chief Delphi Alumni
ADVERTISEMENT
View Poll Results: CAN Success
Yes, Right away 6 31.58%
Yes, With a few problems 6 31.58%
Not yet 6 31.58%
We bricked it 1 5.26%
Voters: 19. You may not vote on this poll
Unread 01-30-2010, 05:58 PM
seannoseworthy's Avatar
seannoseworthy seannoseworthy is offline
FRC #2200 (MMRambotics)
seannoseworthy is a splendid one to beholdseannoseworthy is a splendid one to beholdseannoseworthy is a splendid one to beholdseannoseworthy is a splendid one to beholdseannoseworthy is a splendid one to beholdseannoseworthy is a splendid one to behold
Send a message via MSN to seannoseworthy Send a message via Skype™ to seannoseworthy
Success with CAN
Who got thier CAN working right away and did your updates work.
Unread 01-30-2010, 11:20 PM
simpsonboy77 simpsonboy77 is offline
AKA: Garrett Dicken
FRC #0041 (RoboWarriors)
simpsonboy77 has a brilliant futuresimpsonboy77 has a brilliant futuresimpsonboy77 has a brilliant futuresimpsonboy77 has a brilliant futuresimpsonboy77 has a brilliant futuresimpsonboy77 has a brilliant futuresimpsonboy77 has a brilliant futuresimpsonboy77 has a brilliant futuresimpsonboy77 has a brilliant futuresimpsonboy77 has a brilliant futuresimpsonboy77 has a brilliant future
Send a message via AIM to simpsonboy77
Re: Success with CAN
Team 41 got their CAN working within the first week and a half (if my memory serves me correctly). We managed to get it moving, but only on kPercentVoltage, we tried writing our own kCurrent, but never tested it fully. We put the current control aside to try getting the speed to work with encoders, currently not working though.
We did brick one jaguar today so I am looking into using a JTAG to unbrick it.
**Note I have a high suspicion you may have to set the address before updating the firmware. Even if it responds on 1, change it.** We flashed about 10 jaguars, with the 86 firmware, and then again when 87 came out.
I voted yes but with problems.
Theory is when you know everything but nothing works.
Practice is when everything works but no one knows why.
In a lab, theory and practice are combined, nothing works and no one knows why.
Unread 01-31-2010, 12:08 AM
TRay TRay is offline
FRC #1817
TRay is an unknown quantity at this point
Got all of ours flashed (12 gray, 4 black). Main problem we had was the serial to black jag cable wasn't right..... like 3 times...... Only had one problem other than that. I forgot to push the user button on one of the gray ones and it somehow set the ID to 0. So when it was on a connected CAN bus it would constantly blink yellow fast. Figured out a weird workaround but its now fixed. (Did it with just the black jag and the bdc-comm software)
Tried to run the example CAN code earlier but it didn't work. Then I remembered I was missing the "FRC_BlackJagBridgePlugin.out" on the RIO. Gonna put it on in tomorrow. I'll let you know how it goes.
Unread 01-31-2010, 11:23 AM
dyanoshak dyanoshak is offline
Texas Instruments
AKA: David Yanoshak
FRC #2158 (ausTIN CANs)
dyanoshak has a brilliant futuredyanoshak has a brilliant futuredyanoshak has a brilliant futuredyanoshak has a brilliant futuredyanoshak has a brilliant futuredyanoshak has a brilliant futuredyanoshak has a brilliant futuredyanoshak has a brilliant futuredyanoshak has a brilliant futuredyanoshak has a brilliant futuredyanoshak has a brilliant future
Could you have updated with the wrong firmware? If so here might help.
-David
Unread 02-01-2010, 11:34 PM
AKA: Garrett Dicken
I appreciate the thought David, but we only have grey jaguars, and all the rest flashed fine with the firmware I used. I went back and double checked and I only downloaded the gray firmware, not the black.
I looked into using the bdc-comm utility, but it appeared that it could only be used if the black jaguar is the entry point into the CAN bus. We are using the 2can adapter.
EDIT: Is it possible to make a custom cable that on 1 end plugs into the serial port on a computer, and the other end plugs into the CAN on the corrupt jaguar? Also does anyone have experience with the JTAG and jaguar?
Last edited by simpsonboy77 : 02-01-2010 at 11:39 PM. Reason: added what is next to edit
Unread 02-02-2010, 05:58 PM
ozrien's Avatar
ozrien ozrien is offline
Omar Zrien
AKA: Omar
FRC #0217 (Thunder Chickens)
ozrien is just really niceozrien is just really niceozrien is just really niceozrien is just really niceozrien is just really nice
I actually have reflashed gray jaguars with the CAN bootloader. I used the RDK-BDC CAN eval board from luminary micro.
http://www.luminarymicro.com/product...ation_kit.html
I think I bought mine on digikey ($219 but it came with a jag).
However make sure that you've actually bricked it. When the bootloader doesn't recognize a valid app (bad checksum or maybe black jag firmware in gray jag) the firmware stays in bootloader ready to flash another app. The problem is that when its in this state the firmware does nothing with the led so it looks like its bricked. you've probably done this already but try flashing different firmware into the problem jag, also you may want to separate it from the other jags so its the only one on the CAN bus.
After years of firmware engineering I am convinced that successful programmers must simply enjoy pain.
Omar Zrien
Intrepid Control Systems
Cross The Road Electronics - Chief Software
Team 217 The Thunder Chickens
2006 World Champions
2008 World Champions
Unread 02-04-2010, 10:36 PM
AKA: Garrett Dicken
Thanks Omar.
I tried tinkering with it today, but nothing helped. We are actually purchasing 2 black jaguars, so when they arrive I'll use the version 88 comm utility and reflash them with that recover jaguar option.
Hopefully that works, if not we are going to purchase http://search.digikey.com/scripts/Dk...me=726-1051-ND . Can you confirm if this is the correct item?
Many Thanks
Unread 02-05-2010, 04:21 PM
ozrien's Avatar
Omar Zrien
AKA: Omar
This is the package I bought....
http://search.digikey.com/scripts/Dk...CTL+ &x=0&y=0
Im not sure if the LM3S2965 eval board (your board) comes with firmware that reflashes Jags or if that firmware has been ported from that dev board.
Be sure to read the RDK-BDC User's Manual before you do anything...
http://focus.ti.com/lit/ug/spmu022a/spmu022a.pdf
It explains how to reflash firmware.
Also there are a couple of possible gotchas.
1) The JTAG/SWD Connector on the Jag is a mini 2X5 pin connector that requires a small pcb converter that goes from that to a traditional JTAG connector (this is also explained in the user manual).
2) I've noticed that some Jags ship WITHOUT the 2 X 5 pin connector and the vias where the pins go are wave soldered over so you may have to purchase the pin connectors yourself and solder them on. Peel the sticker at the bottom of the Jag and you will find a hole where the pins should be (I just remembered that I had to do this on a particular jag). I found the part no for the pins in the rdk-bdc CD for the Jaguar, which is also on LM's website. If you can't find it and can dig it up.
Omar Zrien
Who is Programming the cRIO with C++ and what success are you having? Wayne C. Programming 20 01-01-2009 03:48 PM
Success with IR remotes in Week #1? David Brinza Technical Discussion 5 03-04-2008 02:06 AM
Toltechs success with camera Andrew Schuetze Robot Showcase 9 02-17-2007 10:20 PM
any success with winches? Ben.V.293 Technical Discussion 15 01-28-2004 09:38 PM
Success with Tank Treads Yan Wang Technical Discussion 17 01-23-2004 02:53 PM
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
