Go to Post I didn't say it bad English, though. Grammatically, it's perfectly proper. - Greg Ross [more]
Go Back   Chief Delphi > Technical > Programming > WindRiver C++
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
VEXpro
Delphi
ADVERTISEMENT
Unread 01-14-2011, 01:43 AM
Diserasta Diserasta is offline
4 Hours of sleep a day on avg.
AKA: Samouil
FRC #3132 (Thunder Down Under)
Diserasta is an unknown quantity at this point
No Robot Code
Our team has started programming and we have come across a problem. We are using WindRiver C++ and when we deploy our code, the driver station does not recognise the code we deploy or it's not even being found. Was there any specific name the program has to have to be recognised, because to remember having this problem last year, and it having something to do with this.
Thanks in advance!
In .h
RobotDrive *ted;
RobotDrive *tedDrive;
In .cpp
DriveTrain::DriveTrain (RobotDrive *ted){
tedDrive = &*ted;
Yo dawg, I heard you like pointers, so I put a pointer in yo pointer, so you can de-reference your pointer while you point to yo pointer.
Unread 01-14-2011, 03:28 AM
no team (Team NI)
Re: No Robot Code
The correct interpretation of the No Robot Code light is that no robot code is running and responding to the protocols in place. The DS has no way to know what is on the disk of the cRIO, and it doesn't try to manage that anyway.
You may want to use an ftp program or even Windows File Explorer to ftp to the cRIO and look at the info on the startup program. You can then rebuild and deploy and see if it is updated. If not, your build is failing in some way.
Another debugging technique is to use the serial cable or netconsole to see if your program starts and promptly exits -- a possibility when using C++.
Greg McKaskle
Unread 01-14-2011, 07:48 AM
AKA: Samouil
Re: No Robot Code
Greg McKaskle
Thanks for the info. It was just me being stupid after all, I reflashed with this years cRIO image and it works fine. Dunno what it was 0.o. But problem solved, so all is good.
In .h
RobotDrive *ted;
In .cpp
tedDrive = &*ted;
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
