#16
Re: RS775 Gearboxes
Then try to precisely place a tube on a rack with that rotation rate. I haven't done it, so maybe I'm talking out of my butt here... but that seems pretty darn fast! ![]() |
#17
Re: RS775 Gearboxes
What's wrong with 180 degrees in one second in this game (specifically)? You have half (or all) of the field to drive before you are in position to score, after all!
#18
Re: RS775 Gearboxes
Re: RS775 Gearboxes
It's far too fast to be easy to control, in my opinion. Most arms have about 90-100 degrees of travel. I"m thinking 45 degrees per second is much more reasonable.
#20
Re: RS775 Gearboxes
With some degree of automation (PID, specifically) and the proper control systems, you could go with a much faster speed without losing much control.
#21
Re: RS775 Gearboxes
Why, in the age of quadrature encoders and with targets at a set height, would you be subjecting your lifting arm to human control (beyond 'this is the height I want)?
#22
Re: RS775 Gearboxes
Why subject your robot to a potential sensor failure when you can train a monkey (or a student, if monkeys are lacking) to put the tube at the right height every time?
#23
Re: RS775 Gearboxes
![]() I know there are a lot of great programmers in FIRST. I also know that teams are always pushed right up to a deadline, and the software teams get very little time to test. I also know a slow arm is a lot easier to stop, and if your arm is going 180 degrees/second and you miss a limit switch for some reason, something is going to break. There are a lot of great teams in 2007 that didn't actuate at anything close to 180 degrees/second. There probably are some that did too, but I'm a lot more comfortable with a slow arm that I can fall back on a human to control, than needing a relatively complex piece of software to control. Why would you use an encoder? It is simpler to use a potentiometer since your are limited to probably less than one revolution, no? |
#24
Re: RS775 Gearboxes
A. Trimpots drift. Encoders don't.
B. The same idea could be replaced with "why do this in the age of the limit switch?" and the objection is the same (though with slightly different hardware and software, without quite so much elegance). C. With 20 minutes of LabView training, I was able to bring an arm up to whatever height I wanted to by pushing the appropriate button. D. If you haven't made things autonomous, then you can't score in autonomous... |
#25
Re: RS775 Gearboxes
Banebot just emailed me back:
Hello, The new CIM-U-LATOR gearbox and P60 mount for the RS775s will be available for order Wednesday. Thank you, BaneBots Sales Jason Law |
#26
Re: RS775 Gearboxes
On the BaneBots page, it says they'll be offering a 64:1 and a 256:1 for the 775. Really? Nothing in between those ratios?
#27
Re: RS775 Gearboxes
Can you explain (in non-EE terms, preferably) how big of a problem this is in FRC style applications? In my six years of robot building we used potentiometers many times in the feedback loop for rotation, and many more times in our Operator Interface. We never had a problem, and none of my EE mentors ever mentioned it as a potential issue in our many hours of gremlin chasing. Did we dodge a bullet, or is this a case of "it only really matters when you're building spacecraft"? Thanks!
#28
Re: RS775 Gearboxes
We were the "oooh, neat, fire!" robot that year. |
#29
Re: RS775 Gearboxes
I would imagine that they may be the only packages for the RS775 that they offer off the shelf, but in years past swapping motors between BB transmissions was just a matter of ensuring you have the correct Mounting Block for the Motor and series of Transmission - so you should be able to buy a P60 with the desired ratio and swap the mount, right?
#30
Re: RS775 Gearboxes
4:1, 16:1, 64:1, and 256:1. |
