#16
Re: Another chapter to the 6WD vs. Mecanum debate
Thanks for the input! |
#17
Picking one of them revolves entirely upon your team's strategy for this year's game. |
#18
I've literally never seen a mecanum "juke 6 wheel drives all day long". Not saying it can't be done... just saying I really, really want to see video of it. Partly for "proof" and partly because it would be really cool to watch.
#19
You will see a difference in pushing performance due to the traction capabilities of the wheels used, not so much the power available.
The mecanums are usually a hard roller material, which will not provide much "grip" into the carpeted surfaces. Assuming the 6WD is using some sort of treaded wheel it will have more traction onthe carpet. Think about walking across the playing field in your slick soled dress shoes. You can move, you can run, but you can also push your foot out to the side and it will slide across the carpet. In a pair of softer soled athletic shoes, you can also move and run, but if you try to push your foot out to the side it will take more force to do so. The mecanum is like the dress shoe, the treaded wheel is like the athletic shoe. |
#20
As previous leader of the 449 Drive Team for two years, I'd like to put in a few good words for mecanum.
First off, there is almost no power loss in forward/backward movement in a mecanum drive - the rollers do not move unless you are strafing. The fact that mecanum is "less powerful" is a common misconception - mecanum is *not* omni holonomic, and the only difference in power is the difference in coefficient of friction with the floor between the roller material and the material of your six wheel drive wheels. Mecanum's only real weakness with respect to being pushed is from the side, which in this game isn't all that important as the other robots are not allowed to interfere with your goal scoring. Last year during the DC regional we had some issues with ball manipulation that forced us to change our strategy during the quarterfinals to "go into the front zone and push the defensive bot out of the way," which we were able to do with no problems at all. Secondly, strafing is *amazingly handy," especially in a game like this years in which staying lined up with a goal is crucial to success. Thirdly, it is not particularly complex. One your team invests in writing/acquiring decent drive code, building a mecanum drive is as trivially easy as building a normal four wheel tank drive. Well, perhaps a wee bit more, as you need to have one gearbox per wheel. Fourthly, mecanum is also fairly robust - we have lost rollers and drive belts and still been able to play the game fairly well, as even a mecanum missing the strafing capability can turn better than a standard 4wd. You really don't even have to adjust that much for it on the controls. We were able to traverse the bump last year as well as any other robot at the competition without mucking up our drive in the slightest. And finally, I am amazed at how AndyMark's mecanum wheels have improved over the years. We had very few maintenance problems with our rollers last year, and the main issue we had (difficulty in adjusting the connection to each roller) seems to have been fixed on this years generation of 6'' mecanum wheels. Last edited by Oblarg : 01-21-2011 at 12:39 PM. |
#21
or rotating.
Keep in mind just because there's no "at the goal" defense doesn't mean there is no defense. |
#23
Now a Swerve Drive can Juke 6WD's all day long - and that's cool to watch. |
#24
My mouth got ahead of my brain again - I meant that mecanum drives more or less will always have less max pushing force ("lower traction") than a 6wd wheel, even if both were coated with roughtop tread.
#26
Would mecanum even work with the kind of tread that AM sells for traction wheels?
#27
Based on what Ether said two posts earlier I would say yes. |
#28
Making a roughtop mecanum wheel would be an award-worthy feat, indeed.
Still, in a roughtop vs. roughtop pushing battle, the 6WD would STILL always beat the mecanum drive...because maximum tractive force for the mecanum drive IS influenced by the fact that there are passive rollers. Read Ether's white papers - they explain it all. |
#29
No, I don't mean maximum force. I know mecanum wheels do start skidding before 6wd drive, but honestly I *rarely* see a pushing match actually reach that point in competition, and with the pinning rules in place it's even more of a nonissue now than it has been in previous years. And yeah, the rollers turn while rotating, but it's not as if someone hitting you from the side will cause you to start spinning. Quote:
People put way too much store in "If we end up exactly head to head and are pushing each other, my robot will win out." That's not a realistic situation. In the context of an actual competition, in which your goal is not to push head to head with other robots, mecanum is not at a significant disadvantage in terms of being pushed. Take into account the fact that defense isn't allowed to push you while you're scoring, and the best way to get into the scoring zone will probably be dodging the defensive robot rather than pushing it (in fact, are you even allowed to push another alliance's robot into your scoring zone?), and I really don't see what the benefit of a 6wd is. |
#30
I have seen Mecanum drives pushed directly backwards by a 4 or 6 wheel drive despite trying to push forwards. There is definitely a disadvantage to mecanums whenever there is pushing. I think the advantage to 6wd is pretty obvious and pretty much common knowledge, it is simple, reliable and easy to manuever. There is a reason that the majority of teams on Einstein every year seem to be 6 or 8wd Last edited by JamesBrown : 01-21-2011 at 03:41 PM. |
