paper: Simple Motor Calculator
Re: paper: Simple Motor Calculator
I created this small app for my own use, then realized that others might find it interesting/fun/handy. Constructive criticism and error reports welcome. Note: for those looking for something more comprehensive, check out JVN's calculator. http://www.chiefdelphi.com/media/papers/2059 |
The updated version will allow you to enter a desired motor power, and it will then calculate the rpm range, the torque range, and the current range over which the motor will deliver at least that much power.
Also, if there is some reason why you want to always operate the motor at or above a certain efficiency, you can enter the desired efficiency and it will calculate the rpm range, the torque range, the current range over which the motor will operate at an efficiency equal to or greater than the entered number. |
Again, Do not stop what it is that you do best, GREAT WORK. ![]() |
I have updated the motor calculator for the 9015 (am-0912) and PG71 (am-0914) 2012 motors. The app is now 32-bit so it should now run in 64-bit Windows (XP & 7). I am re-working the floating-point error trapping and will update again when that is done. Enjoy. |
Floating-point exception handling added. MCALC32c. Works in 32-bit or 64-bit Windows. Scrollable window. Includes 9015 (am-0912), PG71 (am-0914), and fc12-20 motors. |
For anyone who has downloaded MCALC32, please be advised that the specs for the PG71 gearmotor are in dispute1. As soon as this is settled, I will update the calculator. Sorry for any inconvenience. 1 http://www.chiefdelphi.com/forums/sh...ad.php?t=99488 Last edited by Ether : 01-08-2012 at 06:41 PM. |
Motor Calculator build MCALC32g 1/9/2012 350p Now supports the following motors: CIM FP0673 FP2719 FP9012 FP9015 RS395 RS540 (not legal for 2012 but included) RS550 RS775-12 RS775-18 am-0912 am-0914 DensoL DensoR Denso AE235100-0160 Last edited by Ether : 01-09-2012 at 06:18 PM. |
Here's a copy-and-paste ticker tape output from the motor calculator. If you disagree with any of the specs please let me know. Thanks: Code:
Motor Calculator build MCALC32h 1/9/2012 643p
CIM FR801 001, AM802 001A @ 12.00 volts:
@ free (no load):
oz-in Nm rpm rpm% amps watts out watts in eff%
0.0 0.000 5310 100.0 2.7 0.0 32.4 0.0
@ stall:
343.4 2.425 0 0.0 133.0 0.0 1596.0 0.0
@ max power:
171.7 1.212 2655 50.0 67.8 337.1 814.2 41.4
@ max efficiency:
42.8 0.302 4648 87.5 18.9 147.1 227.3 64.7
FP 00801-0673 @ 12.00 volts:
@ free (no load):
0.0 0.000 20770 100.0 0.8 0.0 9.8 0.0
@ stall:
75.4 0.532 0 0.0 108.7 0.0 1304.4 0.0
@ max power:
37.7 0.266 10385 50.0 54.8 289.5 657.1 44.1
@ max efficiency:
6.0 0.043 19110 92.0 9.4 85.2 113.3 75.2
FP 000968-2719 @ 12.00 volts:
@ free (no load):
0.0 0.000 16100 100.0 2.0 0.0 24.0 0.0
@ stall:
57.5 0.406 0 0.0 63.0 0.0 756.0 0.0
@ max power:
28.8 0.203 8050 50.0 32.5 171.1 390.0 43.9
@ max efficiency:
8.7 0.061 13665 84.9 11.2 87.9 134.7 65.2
FP 000968-9012 @ 12.00 volts:
@ free (no load):
0.0 0.000 15600 100.0 1.0 0.0 12.0 0.0
@ stall:
59.5 0.420 0 0.0 63.5 0.0 762.0 0.0
@ max power:
29.8 0.210 7800 50.0 32.3 171.6 387.0 44.3
@ max efficiency:
6.6 0.047 13861 88.9 8.0 68.0 95.6 71.1
FP 000968-9015 @ 12.00 volts:
@ free (no load):
0.0 0.000 15600 100.0 1.3 0.0 15.0 0.0
@ stall:
63.7 0.450 0 0.0 70.0 0.0 840.0 0.0
@ max power:
31.9 0.225 7800 50.0 35.6 183.7 427.5 43.0
@ max efficiency:
7.5 0.053 13761 88.2 9.4 76.4 112.3 68.1
M3-RS395-12 @ 12.00 volts:
@ free (no load):
0.0 0.000 15500 100.0 0.5 0.0 6.0 0.0
@ stall:
16.7 0.118 0 0.0 15.0 0.0 180.0 0.0
@ max power:
8.3 0.059 7750 50.0 7.8 47.8 93.0 51.3
@ max efficiency:
2.6 0.018 13107 84.6 2.7 24.9 32.9 75.9
***NOTE*** RS540 is not legal for 2012
RS540 @ 12.00 volts:
@ free (no load):
0.0 0.000 17200 100.0 0.9 0.0 11.2 0.0
@ stall:
32.6 0.230 0 0.0 36.8 0.0 441.6 0.0
@ max power:
16.3 0.115 8600 50.0 18.9 103.8 226.4 45.8
@ max efficiency:
4.5 0.032 14841 86.3 5.8 49.1 70.2 70.0
RS550 stall torque changed to 70.5 oz-in per 2012 FRC specs
M5-RS550-12 (-B) @ 12.00 volts:
@ free (no load):
0.0 0.000 19300 100.0 1.4 0.0 16.8 0.0
@ stall:
70.5 0.498 0 0.0 85.0 0.0 1020.0 0.0
@ max power:
35.3 0.249 9650 50.0 43.2 251.5 518.4 48.5
@ max efficiency:
8.0 0.057 17105 88.6 10.9 101.4 130.9 77.5
M7-RS775-12 @ 12.00 volts:
@ free (no load):
0.0 0.000 7300 100.0 1.1 0.0 13.2 0.0
@ stall:
61.1 0.431 0 0.0 30.0 0.0 360.0 0.0
@ max power:
30.6 0.216 3650 50.0 15.6 82.5 186.6 44.2
@ max efficiency:
9.8 0.069 6127 83.9 5.7 44.5 68.9 64.5
M7-RS775-18 @ 12.00 volts:
@ free (no load):
0.0 0.000 13000 100.0 1.8 0.0 21.6 0.0
@ stall:
112.8 0.797 0 0.0 86.7 0.0 1040.4 0.0
@ max power:
56.4 0.398 6500 50.0 44.3 271.2 531.0 51.1
@ max efficiency:
14.2 0.100 11363 87.4 12.5 119.4 149.9 79.7
am-0912 (CCL 9015) @ 12.00 volts:
@ free (no load):
0.0 0.000 16000 100.0 1.2 0.0 14.4 0.0
@ stall:
60.6 0.428 0 0.0 63.8 0.0 765.6 0.0
@ max power:
30.3 0.214 8000 50.0 32.5 179.4 390.0 46.0
@ max efficiency:
7.3 0.052 14070 87.9 8.8 76.1 105.0 72.5
Specs for am-0914 (PG71) motor are disputed.
Update will be posted when available.
am-0914 (PG71) @ 12.00 volts:
@ free (no load):
0.0 0.000 84 100.0 1.3 0.0 15.6 0.0
@ stall:
4140.0 29.235 0 0.0 26.8 0.0 321.8 0.0
@ max power:
2070.0 14.617 42 50.0 14.1 64.3 168.7 38.1
@ max efficiency:
739.3 5.221 69 82.1 5.9 37.7 70.3 53.7
DensoL 262100-3040 @ 12.00 volts:
@ free (no load):
0.0 0.000 84 100.0 1.8 0.0 21.6 0.0
@ stall:
1501.1 10.600 0 0.0 21.0 0.0 252.0 0.0
@ max power:
750.5 5.300 42 50.0 11.4 23.3 136.8 17.0
@ max efficiency:
339.5 2.398 65 77.4 6.1 16.3 73.7 22.1
DensoR 262100-3030 @ 12.00 volts:
@ free (no load):
@ stall:
1501.1 10.600 0 0.0 18.6 0.0 223.2 0.0
@ max power:
750.5 5.300 42 50.0 10.2 23.3 122.4 19.0
@ max efficiency:
357.4 2.524 64 76.2 5.8 16.9 69.6 24.3
Denso AE235100-0160 @ 12.00 volts:
@ free (no load):
0.0 0.000 5300 100.0 1.0 0.0 12.0 0.0
@ stall:
18.4 0.130 0 0.0 7.0 0.0 84.0 0.0
@ max power:
9.2 0.065 2650 50.0 4.0 18.0 48.0 37.6
@ max efficiency:
5.0 0.036 3846 72.6 2.6 14.4 31.8 45.2
#10
Team Update #2 (2012-01-13) added FP-9012 to [R48] and kept FP-9013. The motor calculator supports the FP-9012. As soon as specs for FP-9013 become available I will add them to the calculator. Last edited by Ether : 01-13-2012 at 08:30 PM. |
#11
The motor calculator has been updated with the latest (1/16/2012) lab data for the am-0914 gearmotor. I decided to incorporate 2 separate sets of motor specs for this gearmotor: one for brand-new (unused) gearmotor, and... since the lab data indicated a significant difference. ** ACTUAL GEARMOTOR PERFORMANCE PROBABLY LIES SOMEWHERE BETWEEN ** Links to the 3 lab report PDF documents can be found at the bottom of this web page. If you have even a passing interest in motor testing, you will find this interesting reading. DOES ANYONE HAVE SPECS FOR THE FISHER-PRICE FP-000968-9013 ??? Last edited by Ether : 01-17-2012 at 10:24 AM. |
#12
Motor calculator has been updated to MCALC32t and includes:
The calculator now gives the user the option to select which specs to use for am-0914, since there are 3 different sets of specs (explained in the am-0914 options menu). |
#14
MCALC32aa adds a UserDefined motor to the motor selection menu. EDIT: MCALC32ab adds exception handling to user-defined motor input Last edited by Ether : 01-19-2012 at 05:15 PM. |
#15
WOW!!! How did you do this? I have been looking for a graph of the information so I could get the general values, but this is far better!
