Go to Post If my shop was snowed in and my unfinished robot was sitting in there, I'd dig it out with a plastic spoon or melt it out with a Bic lighter if I had to. Every hour counts. If there's a will, there's a way to make it happen. - sanddrag [more]
Go Back   Chief Delphi > Technical > Motors
Innovation First International, Inc.
Tormach
ADVERTISEMENT
Unread 01-27-2012, 02:28 PM
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Re: paper: Simple Motor Calculator
Originally Posted by bmlarson12 View Post
WOW!!! How did you do this? I have been looking for a graph of the information so I could get the general values, but this is far better!
If you assume that the speed vs torque and the current vs torque "curves" are straight lines (which is the standard assumption for almost all the motors used in FRC), then most of the equations are fairly straightforward to solve explicitly.
For example, at the rated voltage and for a given torque tau, you can find the speed as follows:
speed = free_speed*(1-tau/stall_tau)
some of the other calculations, for example solving for efficiency or finding voltage when given rpm and torque, are a bit trickier, but not too bad.
I'm glad you discovered it and hope you find it helpful.
Unread 01-27-2012, 03:37 PM
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
wireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond repute
Send a message via AIM to wireties
Ether == Awesome - any chance you'll part with the source so I can compile a Linux version?
TIA
Unread 01-27-2012, 06:31 PM
Ether's Avatar
Rookie Year: 1969
It would be good to have a Linux version.
I'll pull out the formulas and post them.
Give me a couple of days.
Unread 01-27-2012, 06:41 PM
wireties's Avatar
Principal Engineer
AKA: Keith Buchanan
If it was a windows console app, it will probably just compile and run quickly with minor changes. You can send the source if you want.
Unread 01-30-2012, 10:08 AM
Ether's Avatar
Rookie Year: 1969
Here ya go.
Unread 01-30-2012, 01:15 PM
wireties's Avatar
Principal Engineer
AKA: Keith Buchanan
Here ya go.
I'm a busy guy - no time soon to re-write the program, not with work for 3 customers in process and being in the middle of build season. I apologize if I was not clear. I was offering to take your source and re-compile to create a Linux executable. No disrespect intended but I don't need the formulas ;o). I'm an EE and have been designing opto-mechatronic embedded control systems for 30 years - I know the formulas.
Thanks anyways.
Unread 01-30-2012, 02:35 PM
Ether's Avatar
Rookie Year: 1969
Of course. I thought you were after some of the more arcane calculations, like solving for operating range given operating volts and desired minimum efficiency*. I've never seen that published anywhere.
Anyway, unless you have an old copy of Kylix the source wouldn't serve the purpose intended.
Oh well, the equations are out there for anyone who might be interested.
*it's not as useful as other calculations, I know, but I included it because it's interesting to play around with and may provide some insight
Unread 01-30-2012, 02:38 PM
wireties's Avatar
Principal Engineer
AKA: Keith Buchanan
Well, it just so happens that I do ... BTW, FIRST Team 1296 very much appreciates all the great advice you regularly disperse on CD!
Unread 02-21-2012, 12:28 AM
Ether's Avatar
Rookie Year: 1969
There have been a number of occasions recently where I wanted to calculate a motor's applied voltage given rpm and amps. To make this more convenient I added another option to the motor calculator.
I have also changed the display to show waste heat watts instead of input watts, since that seems to be of somewhat more interest. Input watts is easily calculated by adding output watts and waste watts.
Unread 01-12-2013, 04:56 PM
Ether's Avatar
Rookie Year: 1969
Simple Motor Calculator by Ether
New version just uploaded. Includes VEX MiniCIM and BAG motors.
Unread 01-26-2013, 12:13 PM
Ether's Avatar
Rookie Year: 1969
Motor Calculator has just been updated to include the now-legal Banebots M5-RS555-12 motor.
The new version (MCALC_2013b) is at the bottom of the list of attachments.
