Go to Post FIRST is about so much more than what happens on the field, and sometimes we forget that. - Lil' Lavery [more]
VEXpro
Delphi
ADVERTISEMENT
Unread 05-14-2012, 07:31 PM
O'Sancheski's Avatar
The Tank Has Arrived
AKA: Joe Sanchez
FRC #0229 (Division By Zero)
pic: 6WD Sheetmetal Chassis
Unread 05-14-2012, 07:40 PM
IanW's Avatar
IanW IanW is offline
Rookie Mentor
AKA: Ian
FRC #0997 (Spartans)
Re: pic: 6WD Sheetmetal Chassis
It looks really good.
I'd say the lightening pattern is rather conservative, so if you're pressed for weight, you could probably take some more out.
Looks like you might have more rivets than you really need on the gearboxes, but better to have too many than too few I suppose.
This may be something you intentionally didn't add, but you may want to consider a bellypan for reasons ranging from enhanced rigidity to convenient location for electronics.
My only other thought was that you might want to add more overlapping/connecting material at the corners. I have modeled a couple drivetrains like this, but have never built one of them, so I will defer to someone with more experience on this aspect.
Website
Facebook
Unread 05-14-2012, 07:43 PM
2185Bilal's Avatar
2185Bilal 2185Bilal is offline
Driver, Ld. Programmer, Electrical
AKA: Bilal Majeed
FRC #2185 (Ramazoidz)
2185Bilal will become famous soon enough
Send a message via Skype™ to 2185Bilal
That desgin, but i think chaining only the lower 4 wheels so the bot can turn better
RAMAZOIDZ
2009 Toronto West Regional - Regional Winners
2009 Waterloo Regional - Regional Winners
Unread 05-14-2012, 07:46 PM
AKA: Joe Sanchez
I am planning on adding cross supports over and under the gearboxes for added rigidity.
Ummm. I'm not quite sure what you are saying here. I stated that I dropped the center wheel 1/8"
2012-20XX: Division By Zero 229/Integration By Parts 4124
2011-2012: Aces High 176
2008-2011: Team Paragon 571
Clarkson University: Class of 2016
Unread 05-14-2012, 07:59 PM
BJC's Avatar
BJC BJC is offline
Simplicty is Complicated!
AKA: Bryan Culver
FRC #0033 (The Killer Bees)
Tip: If you dropped the center wheel 1/8" you will have 1/4" of rock in your chassis because it will not sit as it does in your CAD. If this is the case and you actually want 1/8" of rock I suggest either raising an outer wheel 1/8" or dropping the center only 1/16"
Regards, Bryan
Float like a butterfly, Sting like a bee
-------------Team 33--------------
"The losers are the ones caught up in that afternoon rush hour. The winners drive home in the dark."-Neal Boortz
Unread 05-14-2012, 08:03 PM
apalrd's Avatar
apalrd apalrd is offline
Embedded Programmer
FRC #0033 (Killer Bees)
A few questions:
-What size rivets are they, and at what spacing?
-Why the 0.090" 5052? We looked at 5052 this year, but decided to go with 0.063" 6061 (and later decided we should have gone with 0.050" 6061). A thinner material would be lighter, and 6061 0.063" is strong enough for a FIRST robot with bumpers.
-Any details on the shifter, specifically the ratio and shaft design?
And finally, any plan to remove the transmission in vehicle if you ever have to? It looks like it would be very, very difficult to work on anything inside the transmissions as it is now. Even though it would possibly weigh slightly more, you could pocket out the space of the transmission side plate that is integrated into the frame, and put another plate over it. The transmission would then be a single assembly bolted into a hole on the frame.
Kettering University - Electrical Engineering
Kettering University SAE Teams
Chrysler Powertrain - Controls and Calibration
Unread 05-14-2012, 08:16 PM
Ekcrbe's Avatar
Ekcrbe Ekcrbe is offline
Cursed by the Semifinals
AKA: Erik Boyle
FRC #0068 (Truck Town Thunder)
Team Role: Operator
Ekcrbe has a brilliant futureEkcrbe has a brilliant futureEkcrbe has a brilliant futureEkcrbe has a brilliant futureEkcrbe has a brilliant futureEkcrbe has a brilliant futureEkcrbe has a brilliant futureEkcrbe has a brilliant futureEkcrbe has a brilliant futureEkcrbe has a brilliant futureEkcrbe has a brilliant future
Seconded. We had a sticking transmission at Worlds, so we took the whole thing out and put in our spare in a few minutes. Definitely an important consideration.
2012 Championship Newton Division Finalists--Thanks 330 and 639 for the Full Court Press!
Back
To
Back
2013 Kettering University District Chairman's Award Winners!
Unread 05-14-2012, 08:23 PM
AKA: Joe Sanchez
Answers are in bold.
A few questions:
3/16" at 1/2" spacing
I decided on .09" 5052 because that's what I've seen many teams use and since it was my first sheetmetal chassis I thought that would be a good starting point.
The shaft is made custom on a lathe/mill. I will try to upload a pic of the actual shaft but it is not letting me put an attachment in this post.
I am going to pocket out the flanges above the transmissions. I am also probably going to remove the rivets attaching the transmission to the chassis and replace them with bolts for easier removal.
Unread 05-14-2012, 08:37 PM
akoscielski3's Avatar
Mechanical, CAD Designer, Driver
AKA: Aaron Koscielski
FRC #0772 (Sabre Bytes)
Over All GREAT Looking Chassis!
But I still have things that I would recommend you change to improve it
- I would change your lightening holes to Triangles rather than circles. It will help you lose more weight and can be stronger.
- I love the way you have the supports on the transmissions. But it will still torque your side plates. You will want to put some sort of cross braces of some sort. It could be just bottom braces though, just to pull in the bottom of the transmissions. TRUST ME! They will torque and your chassis WILL be warped. But Then again Bottom and Top braces will be better.
- Good job with the extended Top flanges. It will help keep your side plates in line properly.
- If I am looking at this correctly. Why are your axles live with that type of Chaining? you only need Live axles if they are passing threw plates (the wheel is on one side of the plate, and the sprocket is on the other). You will save weight if you change to Dead Axles. The only one that must be live is the middle wheel because it is direct driven.
Great job for your First Sheet-metal Chassis!
77WHO 772!!!
Mechanical Leader • CAD Designer • Operator Driver
2013 Deans List Finalist Waterloo Regional
Sabre Bytes 77who FACEBOOK PAGE
My Facebook
Unread 05-14-2012, 08:52 PM
2185Bilal's Avatar
AKA: Bilal Majeed
Cool Re: pic: 6WD Sheetmetal Chassis
ohh im sorry, i was saying that i really like the design but i would only chain four wheels, and in the front put like omni-wheels so the turn ability is increased. Like the way the u have it now, it will turn but not as fast as it could
RAMAZOIDZ
Unread 05-14-2012, 08:56 PM
smistthegreat's Avatar
smistthegreat smistthegreat is offline
Making the Transition
AKA: Brian Smist
FRC #0229 (Division by Zero)
smistthegreat is a splendid one to beholdsmistthegreat is a splendid one to beholdsmistthegreat is a splendid one to beholdsmistthegreat is a splendid one to beholdsmistthegreat is a splendid one to beholdsmistthegreat is a splendid one to beholdsmistthegreat is a splendid one to behold
As has already been stated, the center wheels are dropped to ensure smooth turning. Generally, to improve turning performance, you can either drop the center wheels or add omnis at one or both ends. Doing both is not necessary.
Results with 229/4124 as a mentor:
Regional wins: 1 BAE '13 w/ 610 and 3609
Results with 1507 as a student:
Regional wins: 3 FLR '09 w/ 188 and 174, FLR '12 w/ 191 and 3951, Buckeye '12 w/ 340 and 3015
Regional finalists: 1 Pittsburgh '11 w/ 48 and 1541
Division wins: 1 Newton '09 w/ 121 and 177
Proud 1507 Alum.
Unread 05-14-2012, 08:58 PM
Gregor's Avatar
Gregor Gregor is online now
Looking for a Team
AKA: Gregor Browning
Team Role: Student
Would you recommend the multiple powered omnis or the drop center?
FLL 2010 Glen Ames Robotics-Student
FLL 2011-xxxx Glen Ames Robotics-Mentor
FRC 2012-2013 Team 907-Scouting Lead, Strategy Lead, Driver
Add me on Facebook
How I came to be a FIRSTer
<Since 2011
Unread 05-14-2012, 09:02 PM
MICHAELABICK MICHAELABICK is offline
Mechanical Captain, Drive Captain
AKA: Michael Bick
FRC #1836 (Milken Knights)
MICHAELABICK is a name known to allMICHAELABICK is a name known to allMICHAELABICK is a name known to allMICHAELABICK is a name known to allMICHAELABICK is a name known to allMICHAELABICK is a name known to all
That is not true. A drop center will act as if there is not an extra 2 wheels. In other words, it will act as if it is a 4wd with a smaller wheelbase.
Unread 05-14-2012, 09:24 PM
AKA: Joe Sanchez
The only live axles are the center shafts which are direct driven off the transmission. The outer 4 wheels are dead axles with a 22T #35 chain sprocket.
Unread 05-14-2012, 09:26 PM
Okay I am looking at it wrong then. What are the circle on the outside wheels, that to me look like bearings?
77WHO 772!!!
My Facebook
