OCCRA   [more] Florida Regional : 109d 06h 06m ...
Go to Post "So Ken Patton, Paul Copioli, and John V-Neun walk into a bar..." - John V-Neun [more]
Team 47   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
HEXBUG Nano
The Sams Family
ADVERTISEMENT
Thread Tools Rating: Thread Rating: 9 votes, 5.00 average. Display Modes
Old 06-09-2004, 08:37 PM
gearing up for the season!
FRC #0968 (RAWC)
Re: World's Fastest R/C Car, anyone?
Matt you make it sound so easy. It will be quite difficult to make all those components work together but it can indeed be done. As for the horsepower of that engine, I've read sever articles claiming that the way manufacturers come up with that rating is different between each company and it is not a uniform system of measurement/testing. Your 6 step plan would make a pretty fast car. How fast? I don't know. One thing is that nitro engines can not run at WOT for too long or they'll break the con rod or sieze or blow a gasket or whatnot, not to mention possibly overheat. But it might be possible for just getting to top speed and back down really quick. It would depend on the gearing. Also, the speed and power you can get on them depends largely on several factors such as air temperature and humidity, fuel composition, etc. You would need some really good tires and a body and components because of the forces involved with such high speeds.
Even with all the challenges, I would like to try this.
What does everyone think of a dragster style car with just a really fast electric motor with a pinion, an axle with a spur and wheels, a _______ load of batteries?
Or would a pan car type car be better or would a sedan?
Is larger better or no?
So many questions.
Mentor/Machinist/"Engineer", Team 968 RAWC, 2007-present.
www.rawc.net
Old 06-09-2004, 08:46 PM
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
Originally Posted by Tristan Lall
Try a 600 cc motorcycle engine, converted to run nitromethane! I could see 200+ HP being possible. (But the conversion probably wouldn't be easy....)
needs to be under 2 ft long
Team 1257
Old 06-09-2004, 09:11 PM
Fold em oval!
Originally Posted by sanddrag
Not enough torque. Need I say more? Actually, I shouldn't jump to such a conclusion. You never said what size wheels you were using. But assiming you wanted to go 112 mph, you would need a wheel approximately 2" in diameter on the 19670 rpm drill shaft. Now, at stall the wheel would only be able to exert approximately 7.9 lbs of force on the ground. As motor speed goes up, torque goes down. So, I reckon moving at 112 mph (near 19670 rpm), you will have very little torque, certainly not enough to counter the air resistence.
Well, there is a really simple explanation to why you are almost definitley wrong in your reasoning. Unless the drill is much less efficient in (input/output and output/weight), then a direct drive configuration is probably precisely what you are looking for. If a motor, batteries, and chasis can go at 111 mph, then a motor with an output/weight ratio anywhere near the ones used in the 111 mph car would, in at least some configuration, be able to travel at 111 mph also. Using your calculations, we see that to achieve this with just a drill motor and a wheel, we need to actually use larger wheels and therefore less force at the wheel because that is using the free speed which is no where near the peak power output (and therefore a very bad output/weight ratio). Using the formula for drag in a non-compressing fluid:
D=(1/2)*CD*A*r*V2
we see that the drag force of such a car (assuming it is a sphere with radius 10cm)
= (1/2)*(0.5)*3.14*(0.1 m)2*(1.2 kg/m3)*(49.6m/s)^2 = 23.2 N or ~5lb.
The drill at max power is at ~10k rpm therefore requiring about 4" wheels and outputting about 7.9/(2*2) = ~2 lb. (divided by 4 because double size wheels and half stall torque). $@#$@#$@#$@#, maybe I should have made those calculations before starting to write this . Seriously though, I think this result shows that is reasonable to have the drill motor going at 111 mph on direct drive, especially because of the highly overestimate drag (a sphere the size of a basketball?).
Team 1257
Old 06-09-2004, 09:29 PM
FRC #0968 (RAWC)
I somewhat screwed that up didn't I? Of course you can never get more power out of a motor and gearbox than you can out of just the motor itself. But what I was thinking is that the drill motor wouldn't have enough power to reach those kinds of speeds. But perhaps it is indeed possible. The RC motors spin at more like 28,000 rpm but the drill motor I believe has more torque.
Anywhoo, we can sit here and engineer this all day but I think untill one of us gets off our chair and starts making it we'll never know if its possible.
/me rummages through old RC parts
EDIT: /me kicks self for selling carbon fiber pan car chassis I once had.
www.rawc.net
Old 06-09-2004, 09:35 PM
Fold em oval!
Haha! Yes! That's the real engineer attitude! I wonder what sorta power source you can use that can give you such a high power/weight ratio (not energy/weight, lithium would suck in this case). Considering it runs for only a few seconds, maybe even capacitors?
Team 1257
Old 06-09-2004, 09:53 PM
Billfred's Avatar
Billfred Billfred is offline
may now have worked with everyone.
AKA: The "f" is lower-case. :)
FRC #2815 (Los Pollos Locos) & FRC #1398 (Keenan Robo-Raiders)
Send a message via AIM to Billfred
Nah...it has to still be able to run afterward.
The 111 mph record run, IIRC, was done on about 24 sub-C cells, all wedged into an Associated L3O. So I don't think that using Sub-C cells is a death sentence...unless you're dealing with some insane high voltage (like a hybrid car's batteries).
William "Billfred" Leverette - Gamecock/Jessica Boucher victim/Twitterer/Facebook-er/Flickrer
Billfred's World Tour: USC Kickoff Palmetto Championship Robot Rodeo Manchester Kickoff Florida Palmetto Championship Capital Clash USC Kickoff FVC Orangeburg Florida Peachtree Palmetto Championship Mission Mayhem Exploding Bacon Vex Event Duel on the Delaware Cal Games USC Kickoff Florida Chesapeake Palmetto Championship BattleCry Mission Mayhem Brunswick Eruption 6 Clemson Kickoff Chesapeake Palmetto Championship IRI Tempest 'N Tampa Greenville Tech Scrimmage Bayou Palmetto Championship IRI GRITS Tempest 'N Tampa (30894.5 miles, running out of signature space, and still on a mission from Bob.)
Old 06-09-2004, 11:31 PM
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
I thought someone would bring that up.
If I really wanted to be picky, I'd point out that there was no (stated) restriction on how wide the thing was--so mount it in a transverse arrangement.
Also, if you slightly tilted a standard v-twin or a very compact 4 , you should be able to make it fit within 2'. Problem solved.
And if that's too big, use an 85 HP competition go-kart engine. (Uses 100 octane racing fuel, no less, so it's a little safer....)
Old 06-10-2004, 12:17 AM
ebmonon36's Avatar
ebmonon36 ebmonon36 is offline
AKA: Eric Bredehoeft
FRC #1018 (Robodevils)
ebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud of
Send a message via AIM to ebmonon36
I think that the speed record is for cars using the rc car race people sanctioned (im forgetting the acronymn) parts so I think go cart engines are out. The one that set this record if I recall correctly was build by Associated employers and could have gone much faster if it hadn't crashed into the wall at the track they were racing it on. ....it would put my Kyosho Turbo Ultima (circa 1987ish) to shame.
Eric
Old 06-10-2004, 12:39 AM
FRC #0968 (RAWC)
Eric
You ever heard of a Panda Danny Thomson's Stadium Racer? Probably not. It has a little Thunder Tiger .10 engine adapted for the truck. It is the most POS RC car I have ever owned. Its brake is a piece of cork bonded to a brass strip that is bent over by the servo and rubs on the clutch bell. I bought it because it was only $50 brand new in the box and it was old and rare. It has a really cool body though...
Ah, I love RC cars. They are so much fun sometimes.
Just a quick story on the importance of failsafe mechanisms. I was once driving my Traxxas Nitro Stampede with my JR XR3 FM radio. The AA battery holder in the radio had a crack, but once it was put in the radio it all seemed to sandwhich together okay and it still worked fine. Well, this one particular day, I had the engine all tuned up for maximum performance. Just as I was making a full speed run dead center down my street, the craked part of the battery case in the remote breaks even further, the transmitter batteries lose contact with the terminals, the radio loses power, and the servos stay in their WOT and dead ahead positions and the truck takes off screaming dead down the middle of the street at 30+mph. It goes a full block until it comes to the intersection where it crosses the street and runs head on into a curb at full speed. But that is not all. It bounces off and makes a right and goes up the other street. At this point, I can't see it because it is no longer on my street but I can hear it's engine still screaming at WOT. After it goes up a block, it hits a curb again, somehow makes a U turn and starts heading back down the block it went up. Finally the front end is falling apart and it veers to the right back into the curb it hit the first time where it finally flips over. I thought that when flipped over, it would run out of gas and the engine would shut off, but no. From being so shaken up, the fuel is all filled with air bubbles and the engine is runing in an extremely lean condition. As I ran up to it, one tire was stuck against the curb but the other was in the air and it looked like a pizza cutter it was spining so fast. It must have been stretched out to 10" in diameter. The engine was screaming at such a high pitch and rpm I thought it was going to blow. It was the loudest sound I had ever heard in my life. When I was finally able to shut off the engine by putting my thumb over the air filter, there was the greatest silence I had ever heard in my life. Luckily, it somehow managed not to hit any houses, parked cars, mobile cars, animlas, or people.
And that my friends is why it is important to have failsafe mechanisms.
www.rawc.net
Old 06-10-2004, 01:50 AM
Scooter's Avatar
Scooter Scooter is offline
Galactic Doughnut!!
#0418 (Purple Haze)
Scooter will become famous soon enoughScooter will become famous soon enough
Send a message via AIM to Scooter
If it were me, I'd take a .46 size engine off of one of my r/c airplanes and strap that in with a little centrifugal clutch, and gear it down....just a little....these motors have decent torque and a uber high top end rpm of 20k rev/min. If you put that to a big set of wheels, you'll have one heck of a car. I would also do the steering so that it has a very small range of movement, thus increasing the controlability of the car (you could also set in dual rates on your x-mitter).
Whaddya think? Could it work?
-Bill
"Those who think that they know everything are especially annoying to those of us who do."
Old 06-10-2004, 09:39 AM
On to 2010..
FRC #2775 (Liberty Robotics)
Send a message via AIM to Greg Needel
just FYI here are the offical rules of the challenge
http://www.rccaraction.com/rc/news/car_challenge.asp
and here is the set up for the car that has the current record
http://www.rccaraction.com/rc/articles/need_speed.asp
I aslo found this RC fourm with alot of information in their thread
http://www.radiocontrolzone.com/foru...d.php?t=167401
my brain has been running circles around this project since i heard about it
Old 06-10-2004, 09:40 AM
FRC #0968 (RAWC)
I think Thunder Tiger already makes a truck with a .70 helicopter engine. It goes fast, but not 112+ fast. Perhaps that's because it is a monster truck and geared for torque.
But an airplane engine is an interesting idea. They rev almost as high as the car engines but come in much larger displacements. It may be difficult adapting a clutch though.
www.rawc.net
Old 06-10-2004, 09:59 AM
team222badbrad's Avatar
3D Printing Specialist
AKA: Bradley Rigdon
FRC #0222 (The Tigertrons)
I would not bother even using a clutch! I would just make the thing direct drive. You would just have to implement some kind of remote kill switch (micro servo?)
If I were to build anything I would definitaly built a car with an engine not a motor!
Batteries are too heavy
Old 06-11-2004, 10:18 PM
Maxzillian Maxzillian is offline
#0935 (RaileRobotics)
Maxzillian is on a distinguished road
Send a message via AIM to Maxzillian
Oooooo, it's about darn time they decided to hold an official competition. I've personally been on the r/c scene for the last 5-6 years and have seen some pretty darn crazy creations. The following being two of my toys I've hand built... although the latter has been in the works for 4 years and still isn't done and the former has a little touch up work that needs to be finished such as strengthening the rear suspension and making battery mounts to hang the packs off the side of the chassis to keep the center of gravity down.
http://www.mtsquad.com/phpbb2/viewtopic.php?t=116
http://www.mtsquad.com/phpbb2/viewtopic.php?t=59
Anywho, I can't see a drill motor propelling one of those cars past 111. The brushless motor used in the record holding car would hit RPMs past 60,000 and still have power to spare. Hence why the latest craze on the r/c scene has been brushless motors. Compared to brushed motors they're over twice as powerful, more efficient, and more reliable. However, being a nitro guy myself I always ignore the new electric gadgets. Without a doubt, if you were to build a speed car, you'd need a on-road racing engine. Considering that the newest ones touch 3-4hp and still managed over 35k, I think they'd have enough power. The problem is taking that power and harnessing it in the most efficient of ways. So, and I almost hate saying this, the best drivetrain would be a belted drivetrain. With kevlar belts, it'd just barely be reliable enough to handle that much power. However, I personally think that a 2 wheel r/c vehicle would be the way to go. If you think about it, it's the most aerodynamic, stable (at high speeds), and efficient chassis design to use considering how little rolling resistane there would be. The only problem would be keeping the bike upright during the run while keeping it in a straight line. Perhaps a gyro to control a set of balance weights and some wires hanging off the side to act as training wheels? Either way, that's my two cents on the subject.
Blah!
Old 06-11-2004, 10:47 PM
Salik Syed Salik Syed is offline
FRC #0701 (RoboVikes)
Salik Syed has much to be proud ofSalik Syed has much to be proud ofSalik Syed has much to be proud ofSalik Syed has much to be proud ofSalik Syed has much to be proud ofSalik Syed has much to be proud ofSalik Syed has much to be proud ofSalik Syed has much to be proud ofSalik Syed has much to be proud of
Send a message via AIM to Salik Syed
forget piston engines
grab yourself a micro turbo prop engine...and connect it to the drive shaft.... search for wren micro turbines and you'll find it.
Team 701
Car Bashing Fundraiser? Billfred Fundraising 22 06-14-2004 04:20 PM
Mars Rover on Car Talk! mightywombat Televised Robotics 2 05-18-2004 02:41 PM
What is Car Nack's Corner? Joe Johnson Car Nack's Corner 1 01-09-2004 09:44 PM
R/C Control types Andy Brockway Programming 43 11-24-2003 05:07 PM
Car Knack Jr. Prediction Report Card Brian Beatty General Forum 15 04-15-2003 06:01 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
