Parallel Processor
Does anybody know what is a good parallel processor to use, where I can get it from, and whether it come with code? My team (1414) is thinking of using parallel processing but we need some outside input, does anybody have any experience wiht parallel processors and what is best? Thanks...
Re: Parallel Processor
You probably mean coprocessor not parallel processor. There are many choices. You could use a basic stamp. It was the processor in the old robot controller. However, your team would have to figure out how to handle the communications between the robot controller and the co processor. Do you have a Mentor that could help?
As for our team, we have used a Motorola HC08 series microcontroller on our robot for the last 3 years. It's a pretty simple processor to design a circuit for and all the tools you need to program it are available for free. |
What is your purpose for using a second processor?
I need to double-check with my team members and get back to you; but I am pretty sure that we are going to be using one processor for steering and driving, and another for the arm or whatever extension is needed
All you need to do is just make another function to handle the arm. A coprocessor would create a lot of work (debugging communications, etc.); it seems like it would be overkill in this instance.
I don't see any reason you need a coprocessor for these tasks. The processor built into the controller is more than adequite for basic robot controlling. The only reason for a coprocessor is if you are doing very sophisicated navigation, feedback control loops etc. Last year we had a coprocessor to handle all of our navigation. We chose to use another PIC because we were already familiar with them and so that code snippets could be interchanged between the RC and our coprocssor. Specifically we used a PIC18F252. Again unless you are doing something very special and have some sort of experience with embedded design and programming i would strongly caution against a second procssor.
Ok. we need a coprocessor for a faster response time. With the current FIRST processor, the response to a touch sensors feedback is 30ms. We need to bring that down to 10 or 15 at most. Also we will use the basic FIRST CPU for the drive system
and we feel we need more processing power for the autonomous mode line tracking and also for handling the sensor feedback during arm control. As the arm moves, the forces change with the angle and hence we need to crunch quite rapidly the angle as per a potentiometer output and the power output of to the motor. Equally, when the arm is stopped at any position other than straight down or straight up, we need to apply a variable amount of motor breaking to resist the force of gravity. We learnt that the FIRST CPU was not up to the frequency of calculations we require to make the programming work properly. |
#10
You might look at http://kronosrobotics.com/xcart/customer/home.php. The Dios chip is of the pic 18f family. They sell carrier board kits to make it easier to hook every thing up. They also have some app notes on a rs485 interface that may help with the communications issue. The chip is programed in basic with support for inline assembler if you need it. There are coprocessor functions in the language but, you would have to duplicate them on the robot controller. Still not sure you really need a coproc. The items you mentioned don't sound that intensive. As for the arm being back driven, worm gears are very good at preventing this. Both the van door and window motors are worm designs. We choose the window motor last year with additional reduction and had no problem with back driving. Our arm could reach the tall goal and place the ball when our drivers where on. I always prefer to handle problems with mechanical design instead of trying to correct deficiencies with programming.
Gary Deaver |
#11
Your problem isn't the speed of the processor, but the structure of your program. Have you read the Programming reference manual?
Default_Routine will only be called every 26ms. Process_Data_From_Local_IO will be called every program loop, which will be much more often (the PIC is actually quite fast). You can also use a timer to call your routine at a fixed rate, such as 100hz. Even then, the PWMs won't be updated unless you use the fast PWMs. Definetly read through ALL the documentation, and if you still have questions, ask. The PIC should be more then fast enough for what you want to do. Even if it wasn't, a coprocessor wouldn't help at all the way your program is written now. |
#12
The topic of optimizing code to run faster is a huge one, but one big piece of advice I can give you is do not use floating point operations and try not to use division. Also, use 8bit operations whenever possible. With some clever math, you can very often do what you want without using floating point operations.
#13
Our simple wheel speed sensor was polled in Process_Data_From_Local_IO(), and the code kept up just fine with a signal that changed every 8 ms under normal conditions. I didn't put in any instrumentation to measure the timing precisely, but I did verify that Process_Data_From_Local_IO() ran at least twice every four milliseconds. |
#14
The processor will not be the bottleneck in reading your touch sensors. You MAY have problems with the speed controllers and especially the relays. They relays take time to switch and the speed controllers take time to send a signal to. The relays update immediately, but they take time to switch. Typical relays take anywhere from .5msec for small reed relays to 50msec and up for large power relays. I don't know the specific activation and release time for the relays inside he spikes, but looking at similar relays i would guess from 15-25msec. The speed controllers have another problem. It takes between 1.0 and 2.0 msec just to send a command to the speed controllers. There may also be a latency between when the speed controller revieves a signal and when it outputs. Let me ask you this: What is soo critical about these touch sensors that they must be responded to soo quickly? The some care and code trickery, you should be able to run everything you mentioned above on the RC alone with a good safety margin. Last edited by Rickertsen2 : 10-25-2004 at 05:56 PM. |
| Nintendo DS & NVIDIA's New Processor | Raven_Writer | Chit-Chat | 5 | 09-24-2004 07:47 AM |
| Parallel Motor Connection | Don Wright | Electrical | 12 | 03-30-2004 08:23 PM |
| QBASIC, Parallel Ports, and Windows XP | Venkatesh | Electrical | 1 | 03-21-2004 06:07 PM |
| Working in Parallel | dubya404 | 3D Animation and Competition | 7 | 01-28-2003 10:48 AM |
| IBM Unveils 64-bit PowerPC Chip | Joe Matt | Chit-Chat | 37 | 10-18-2002 07:34 AM |
