White Paper Discuss: Nothing But Dewalts
Thread created automatically to discuss a document in the White Papers.
Nothing But Dewalts by Joe P |
Re: White Paper Discuss: Nothing But Dewalts
Great! Thanks Joe and Joe. I'm disappointed to see that its a bit more work than I had thought, but after the additional testing that OCCRA gave it, I think we can be assured that its up to the job.
I thought Joe Johnson had said that he had interfaced the drill motors with it, too. Is this true? Finally, what exactly does Lou Odin provide in this kit of his? The aluminum and plastic plates for the Chiaphua, neccesary bolts, and the modification of the sun gear? What kind of lead time can we expect during build? Again, thanks for the great work. |
The kit id Drawing 1,2, 3, and 5. You have to send him the carrier gear to be modified. Yes you can interface the drill motors however we didn't do it in this paper because they may not be in this years kit. |
Great paper - thanks so much for those details. Have any of you done any testing to determine the motor "curves" (torque/speed/current data) for the various motor/transmission assemblies at different reduction settings (1st, 2nd, 3rd gear)?
Is there any reason that the Globe and Fisher Price versions are shown without a shifter?
This is Very Cool. Thanks joe for the whitepaper. even though this maybe be time consuming, its definitely worth it. and its not even that much money only 65 dollard. Again, Thanks Joe.
I did it on the Chiaphua and didn't want to repeat it over again in the paper. |
Page 17 - Step 3. for the Fisher Price - The distance from the top of the pinion gear to the front of the motor case should be 0.72 inches. not .072 inches. Had a bad day with decimal points. |
#10
We just got a prototype chassis running with the CIM Dewalts. We haven't had time to think about this yet. Maybe someone on Team 47 has done some work on this, I don't know? |
#11
Why did you decide to throw out the first stage of the DeWalt for the CIM interface? Did you find a problem with using an input pinion as in the other arrangements?
So these modules were attached to the robot only by the aluminum clamp? Did you ever have problems with slippage? Thanks for sharing this paper. I had been looking to discard the yellow clamshell, but I'm impressed by your use of it. |
#12
I'm not sure what their reason to discard the first stage for the CIM was, but there is a very good reason I can think of. The gearbox is surely designed for a very high rpm, low torque motor (like the drills from our kit of parts) and the CIM probably has 2 or 3 times the torque of the motor it was designed for. A mas produced gearbox like this is most likely engineered down pretty close to the specs its needed for. It wouldn't take 2 or 3 times the torque.
#13
My notes say the advertised output torque for the 18V XRP drill is 500 inch-pounds = 56Nm. The stall torque of the CIM (at 107A) is 2.2Nm. So the CIM put through the 46:1 reduction of first gear represents a 101Nm output, or just about twice the number DeWalt puts on the box.
I know someone out there was building CIM-Bosch-DeWalt combos in the off season, and I'm under the impression that the DeWalts survived that fine. Does anyone know if they were using the full reduction? |
#14
Great paper Joe, thanks for posting it. Hopefully more teams can have shifters with this method, since it is so much easier and cheaper than building one from scratch. Edit: Jim, I believe that Andy Brockway and Team 716 were the people trying out the XRP transmission with the FP and Bosch motors linked. Last edited by Ryan Foley : 01-02-2005 at 11:20 AM. |
#15
Although I am aware that the CIM outputs only .79Nm at 40A, it must be remembered that our 40A breakers can actually sustain upwards of 80A for short durations. Using the 40A number, even with all three stages we remain well under rated torque for the transmission. In my calculation I used the stall current to be conservative. I am curious what the real maximum momentary load from a CIM motor is, once you factor in our breakers and our non-ideal voltage source. |
| White Paper Discuss: Users Guide to Autodesk Inventor | CD47-Bot | Extra Discussion | 2 | 12-18-2006 05:45 PM |
| White Paper Discuss: Comparison Paper for Teacher Involvement | CD47-Bot | Extra Discussion | 1 | 11-13-2004 12:09 AM |
| White Paper Discuss: Karthik's Championship Event Data | CD47-Bot | Extra Discussion | 20 | 04-13-2004 08:17 AM |
| White Paper Discuss: 948 Assembly Slideshow: 1.5 months in 45 seconds | CD47-Bot | Extra Discussion | 1 | 03-24-2004 09:37 PM |
