#46
Re: Optical Mouse Navigation
I will soon post pictures of my counters and sensors (which I think should void any of this discussion because of their simplicty.) Everything has been tested except for the robustness of the sensors on a running robot. |
#48
Hmm reading that I thought the Logitech Mx 1000 Mouse could be very interesting for a project like this since its about 20x better then any optical mouse beacause it's actually really using a laser but I couldn't find it at the pages of the authorized resellers
...Who wants to look at it: Logitech Mx 1000 |
#50
UPDATE: You're in germany? I wasn't aware that there was a team there yet... that's uber cool. Last edited by phrontist : 01-04-2005 at 09:57 PM. |
#51
Sorry to get off topic, but is this project being doen by someone who does stuff at DW college? If so, just wondering, becuase my dad was talking about you doing it, if not, then you should sollaberate with the guy who is doing it, because he seems to know alot about it... It is posted on these forus somewhere...
#52
My Highschool is competing for the first team this year but we got some good suport/sponsoring on our site so I hope we can get a decent robot together : ). Youl'll probably hear more from me in the next team since I'll probably have some questions (especally regarding programming/etc. soon). I just had a look at the default code from 2004 so far and no chances to trie anything out but it didn't seem horrible difficult to me (at least the standard functions/etc.). We'll probably have a little Testrobot for the club from tomorrow on which has the same chip so I can start playing around with it, which will probably cause the first question soon (or may not, if it's googleable : ) ... Ok bye guys, Felix "the_undefined" Geisendörfer |
#53
An optical mouse works by tracking offsets in the image at the sensor. The image at the sensor is a scaled representation of the carpet being viewed. The scale factor varies with distance from the carpet. If the distance is not kept perfectly consistent, the resulting measurements are likewise not consistent. |
#54
Accumulation of small deltas?
Devil's Advocate here again...
Is there a findamental problem with using an optical mouse? The mouse reports a delta distance since the previous frame, as best as it can determine by performing a correlation between the current and the previous frame. But any fractional part of that measurement is not carried forward to the next measurement, and is lost. For example, let's say you were trying to get the robot to move perfectly straight, but it was moving very slightly to the right, so slightly that the X axis change was less than one pixel of the mouse's imager per frame, say 1/3 pixel. The mouse will output zero change (because the best correlation would be "zero" offset). On the next frame the mouse again compares the frame with the previous frame, and again the motion is so slight (1/3 pixel, not 2/3 because we only compare adjacent frame pairs) that the mouse again reports zero change. But the robot is moving steadily to the right. Our program accumulates the deltas to measure position, but zero plus zero plus zero will be zero -- the slight drift to the right is never observed. Compare that with a pair of wheel encoders. The difference between the two wheel encoders might be only 1/3 tick, but the error is "remembered" mechanically, so that the next time the difference is 2/3 tick, and finally the third time one side reports an extra tick compared to the other side, and the drift is detected. The lack of memory for fraction pixel offsets seems fundamental to the optical mouse. Am I missing something? Is the resolution so high that my example would result in a trivial guidance error over the length of the field? If I knew the effective "size" of one pixel (on the carpet) I could calculate the potential error accumulation. -Norm |
#55
Re: Accumulation of small deltas?
While I can't give you an exact figure (after optical modification), I'm using a chip with 800 dpi resolution. Even if that is reduced 10 fold, it's still many, many times more precise AND accurate than encoders. Your arguement is not a logically flawed one, but this is happening on such a small scale, I think it will actually be more straight than gyros or encoders. We'll see! ![]() |
#56
I think the bigger issue will be different surfaces, which will have to be accounted for by using banner sensors to detect changes. This will be interesting. At the very worst, infrared and ultrasonic sensors are precise enough that they could be mounted near the optical sensor and used to scale data live. I really don't think it will come to that though. |
#57
I am *not* using the mouse to give me lateral distances (call it the x-axis offset distance) in part for the reasons you have stated. Rather, I am using a rate gyro to tell me how much rotation the robot has experienced in the most recent time interval. I use the mouse to give me just the y-axis offset, i.e., distance traveled. A little trig and a couple of approximations later I can calculate a lateral offset which *is* accumulated. The real question is: How much error will accumulate during autonomous mode using the <whatever> navigation system, and is it so much that the <whatever> navigation system is not reliable? Obviously all of these different systems have their individual strengths and weaknesses. If during the (presumed) 30 seconds of autonomouse mode (good grief, I don't believe my fingers just typed that - but I like it!) - if during that time period the robot is only off by a couple inches then I will be ecstatic. [ I calculate that my refitted mouse should have a 1/4" resolution. We'll see if that holds up or not... ] The wheel encoder system we used last year had about a 6 inch resolution. I know that much greater resolution is possible using wheel encoders, but that's what we had. So if the optical mouse works better, then great. If it doesn't work better, then maybe we all learned something. |
#58
Re: Optical Mouse Navigation with GP5
I have been performing a experiment to validate optical mouse sensing with off the shelf robotic componets.
My work started with writing a custom PS/2 driver with an HCS12 microcontroller from motorola. Basically using a standard SPI interface I was able to communicate between the mouse successfully. http://iarc1.ece.utexas.edu/~lynca/m...I_oscopeTests/ the code released is not meant for a PIC but can serve as a guide on implementing communication between a mouse and SPI port. contact by email for the project which is still under development, http://iarc1.ece.utexas.edu/~lynca/m...dia/FIRST/src/ My solution was not simple and easily transferable. Therefore I was determined to find something better for the robotic community. I discovered Al William here near my area who had implemented a much more elegant PS/2 driver on a chip he call PAK XI (earlier version pak6). http://www.awce.com/pak6.htm Testing pictures, http://iarc1.ece.utexas.edu/~lynca/m...a/FIRST/PAKXI/ I also tested above, the gp5 with great success, I have misplaced my hyperterm outputs but email and I'll provide picture evidence if requested. http://www.awce.com/gp5.htm In all, the drivers can be implemented with any PIC (including RC) but an offboard processor streaming serial port commands of x and y is a very quick solution (GP5 through programming port). I have a Microchip project which does so but the code is messy at the moment, please email me a code request if curious. thanks for your time, ~Andrew Lynch for in depth look at PS2 driver for a PIC http://www.computer-engineering.org/ |
#59
Well with my season over I am now working on some non FIRST related robotics projects. The first (and more relevant to this discussion) of these is trying to build a robot that can navigate our school, and build a sonar map which it can use for plotting routes between its location and its destination. The robot will be based around a PC running linux. Right now I am just toying with the idea of trying to use an optical mouse for measuring travel.
As far as mounting height why dont you just use a regular optical mouse mounted on one of the skinny pneumatic rams with a regulator regulating the pressure down to say 10 psi. Then you mount the ram such that it is not fully extended when the mouse is on the ground, so the mouse will always be being gently pressed on the ground. Then if you encounter terrain that is unsuitable for the mouse (put a sonar range finder pointing at the ground in front of the mouse to detect bumps) you simply retract the ram until you are back on flat ground. Just a thought. |
#60
| External Lens for optical mouse | gnormhurst | Electrical | 4 | 01-07-2005 07:07 PM |
| Looking for Mouse part | Mr. Lim | Electrical | 3 | 12-27-2004 07:56 PM |
| Optical Mouse / Ball Mouse | Clark Gilbert | Chit-Chat | 26 | 07-22-2004 01:17 PM |
| Optical Sensors Used as Encoders? | uvabrad825 | Technical Discussion | 22 | 05-03-2004 01:22 PM |
| IS THIS RIGHT?!?!? | RebAl | General Forum | 22 | 03-31-2002 12:07 AM |
