#46
Re: Appropriate use of reputation points
I agree with many of the comments that have been posted above me ... but one of the points that I find to be most truthful is this one:
Personally, i'm not a fan of giving out too many rep points but if I really find or read something that captivates my attention and that I think deserves rep points ... then I will award them (regardless of the topic). I don't like to give negative points either because I am a firm believer in that everyone is at free to say what they wish and I'm not a judge to be judging anyones words or ideas! Unless, I read something that is truly offensive overall (not just because I seem to think so) then I will award negative points! Which is what brings me to my point ... EVERYONE IS DIFFERENT ... and therein we all think differently ... so judging someone elses posts on our standards is not what I believe should be done! I think we should all view posts as exactly what they are -- individual posts from individuals who have their own ideas and personalities! And again when and if a post is truly offensive then measures should be taken! Second thing, someone who has a few bars (perse 2 or 3) should not be considered someone who's posts are not AS GOOD as the posts of someone who has a lot of bars. Which brings me to my next quote: Quote:
We shouldn't fret over this subject, instead we should think this way: Quote:
Ok, this is long enough so I will end it .. but just remember: Wether you have many green dots or few green dots ... the real represantation of you is what you think of yourself and who show it! I hope not to have offended anyone with MY ideas and I hope nobody thinks that I took their ideas with the quotes used above! |
#47
I try to abuse the rep system to it's fullest, you know, giving random points to all my friends, that sort of thing.
Errmmm... did I say abuse? I meant use. Those two are kinda confusing, y'know? Cory |
#48
Yes, I a resurrecting an old thread, but I have a reason:
It seems like some new users are getting red dots quickly these days. I can understand if this user is being blatantly inappropriate and they deserve to get some negative rep. However, I see some new users who are getting slapped with negative rep for making a the typical newbie mistakes, such as not searching before they post or not paying attention to out-dated threads. So... users, I ask you to give these newbies a break. Although you crusty vets see these mistakes happen often, new members still need your patience. Before whacking them with some negative rep, send them some neutral rep or a PM to give them some advice. Then, if they don't listen to you, you can be more blunt by giving them your negative rep rating as you wish. Of course, how you use your rep points is up to you. Consider this a simple request. Andy B. |
#49
I forgot how wise Mr. Baker really is. I, too have noticed this trend. You so called CD veterans: take a good look at how you give out rep. I say that if you have given negative rep to more than 5 people, then you may be a bit judgmental. If you have given negative rep to more than 10 people or a total of more than 20 times, then I say you need to look inward and stop being holier than thou.
Negative rep should not be used as a training method. If I gave everyone negative rep that asked a technical question that I had answered on CD 2 or 3 years ago, then I definitely would have violated my criteria above. Newbies need to be taught, or dare I say ... mentored and not smacked upside the head with red dots. Carnegie is not just a guy's name. Look it up ... study the methods. It works. By the way, I have negative repped two times since the system has been implemented. |
#50
952 individual positive rep clicks given 5 neutral rep 18 negative rep (about 12 different people) So, I am somewhere between being judgemental and holier than thou. That works for me. Andy B. |
#51
I haven't been nearly as active as I probably should be in giving rep points. But I have noticed the high rate of negative reps among newbies lately.
I award these people positive rep points anytime I see them doing something remotely worthy. Just to reinforce good behavior. ChrisH |
#52
We can quibble over the specific number of the ratio (what is OK? 1%? 4%? 0.5%? I don't know). Everyone may have a different view of what is a reasonable negative/positive ratio. But in the end, each time you consider issuing a negative (or for that matter, positive) reputation hit you must be comfortable with your own answers to three questions: - Given the roles of both the poster and myself (as student, mentor, parent, teacher, team member, engineer, or whatever), is changing the reputation of the poster an appropriate response to their post? - If all the reputation allocations were made public, and not kept private, would I still be comfortable in making this reputation allocation? - If I had made this post and then recieved a negative reputation hit for it, would I feel it was deserved? Unless you can answer "yes" to each of those questions, then you might want to think a little more about other ways to get your message across to the poster before you hit the "add to reputation" button. -dave |
#53
I'm not worthy...
I'm not worthy... Thanks to all three - Andy, Paul, and Dave - for this reminder. The bottom line is that we want more and more people in FIRST so they have a chance to be inspired and understand the culture-changing mission. Our primary role should always be to educate and mentor those that come after us. Both patience and persistence are necessary. As my good friend Paul Kloberg (NJ Sr. Mentor) says, "Fun Is Required, So Tolerate." |
#54
Just added up my reps given. I gave 104 positive 3 neutral and 1 neg to a member of my own team that stepped out of line. I do regularly pm people that I might have bad repped rather than give neg points. I have found that most people take positive to this approach. We are here to both learn and teach. Let's try to be positive.
#55
I would say that instead of giving out negative reputation points for newbie mistakes, give neutral reputation points or PM the user instead. That way, the message comes across, but it is constructive instead of demeaning. However, if somebody who has been here for a while and steps majorly out of the forum rules (IE Spams, trashes another member, etc), then I think it is okay to give negative reputation. That's how I go about it, anyways.
-Daniel |
#56
I would also like to make a plea for mercy when a rookie makes an inappropriate comment and then evrybody piles on them and their rep is left in the trash heap. If I come across something like that I do not give them negative rep. I dispute thier claim or scold them but they don't deserve a blleding red dot becasue of their lack of judgement. Wouldn't it be just better to simply correct them instead of everybody administer a poison pen beat down on them?
#57
I was under the impression that negative rep from a well known poster was frowned on so I don't remember giving any negatives. I have taken the "PM a nice message first" approach and give the abuser a chance to clear it up privately. I have gotten a little harsh on occasion in a PM and luckily the victim responded by PM and we came to quite a good rapport after that. There are those occasions where even the PM doesn't work. I advocate disconnect (virtual excommunication) for those that don't start to get it on the first message.
#58
I dont bean someone with a negative rep hit unless they are breaking the serious rules of the forum (like posting masked profanity) or being abusive
on many ocassions I have used the rep points to send a note to someone, telling them I dont agree with what they are saying, but I give them positive rep anyway, because sometimes it takes real guts to say what you want to say knowing it might not be popular. If someone is speaking their mind, they might be wrong, but I dont want to discourage someone from speaking up. I have gotten the most red hits from people who dont like my sense of humor. How ironic is that? Would you really want someone in the FIRST community to have a 'bad reputation' because you dont get their jokes, or you dont think they are funny? There is a golden rule I learned several years ago for reviewing someone elses work. For each negative thing you have to say, you must say three positive things first. People get demoralized quickly if you only have negative things to say to them, esp when it comes from a supervisior, manager, team leader or a mentor. Last edited by KenWittlief : 05-21-2005 at 03:46 PM. |
#59
OK, I'm a complete ninny and I need to ask andy and Steve...
Where's the info to add up your own rep given?? I really need to know if I'm a jerk or not ![]() |
#60
Wetzel *Edit* Whoops, wrong user again. ![]() |
| Reputation points | SilverStar | CD Forum Support | 73 | 05-26-2004 01:14 AM |
| Fantasy FIRST suggestions for next year | Joe Ross | Fantasy FIRST | 39 | 04-14-2004 12:13 AM |
