Go to Post While FIRST's goal is to inspire young people, it will be much easier to do that if we also inspire all the older people as well. - E. Wood [more]
Innovation First International, Inc.
Pete's Coney Island II
ADVERTISEMENT
Unread 09-19-2005, 10:14 AM
muy dificil muy dificil is offline
FRC #1611
muy dificil is an unknown quantity at this point
Ah progrmming is hard
progrmming is muy dificil
Unread 09-19-2005, 10:23 AM
sciguy125 sciguy125 is offline
Electrical Engineer
AKA: Phil Baltar
FRC #1351
sciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond repute
Send a message via AIM to sciguy125 Send a message via MSN to sciguy125 Send a message via Yahoo to sciguy125
Re: Ah progrmming is hard
Did you have a particular problem you need help with or were you just making a general comment?
Programming isn't that hard once you get the hang of it. It has a steep learning curve like math. One day your trying to figure out 1+1, then the next day they throw x and y at you. Once you understand what x and y represent and learn to think in terms of functions, it's as easy as pi.
-----BEGIN GEEK CODE BLOCK-----
Version: 3.12
GE/S/P a-- e y-- r-- s:++ d+ h! X+++
t++ C+ P+ L++ E W++ w M-- V? PS+ PE+
5- R-- tv+ b+ DI+++ D- G
------END GEEK CODE BLOCK------
Unread 09-19-2005, 10:25 AM
FRC #1611
thanks i appreciate it
Unread 09-19-2005, 01:03 PM
Problem with microprocessors is: they do exactly what you tell them to do
instead of what you want them to do!
Unread 09-19-2005, 02:43 PM
Mark McLeod's Avatar
Mark McLeod Mark McLeod is offline
Itinerant Programmer
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Mark McLeod has a reputation beyond reputeMark McLeod has a reputation beyond reputeMark McLeod has a reputation beyond reputeMark McLeod has a reputation beyond reputeMark McLeod has a reputation beyond reputeMark McLeod has a reputation beyond reputeMark McLeod has a reputation beyond reputeMark McLeod has a reputation beyond reputeMark McLeod has a reputation beyond reputeMark McLeod has a reputation beyond reputeMark McLeod has a reputation beyond repute
You'll spend most of your time trying to figure out exactly WHAT you told it to do!
"Everyone you will ever meet knows something you don't" - Bill Nye
Unread 09-19-2005, 07:57 PM
Andrew Blair's Avatar
Andrew Blair Andrew Blair is offline
SAE Formula is FIRST with Gasoline.
FRC #0306 (CRT)
Andrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond repute
Send a message via AIM to Andrew Blair Send a message via Yahoo to Andrew Blair
One muy no-no...Keep your robot battery charged when working with code. You'll have an emotional breakdown trying to find out the problem with the code, only to change the battery and find it working fine.
Reading makes a full man, conference a ready man, and writing an exact man.
-Sir Francis Bacon
"Any intelligent fool can make things bigger, more complex, and more violent. It takes a touch of genius -- and a lot of courage -- to move in the opposite direction."
-Albert Einstein
Unread 09-20-2005, 09:26 AM
TotalDomination TotalDomination is offline
FRC #1611
TotalDomination is an unknown quantity at this point
Yes, right now we are trying to program the EDU bot and having problems downloading the program to the interface.
Unread 09-20-2005, 09:40 AM
FRC #1611
Unread 09-20-2005, 09:45 AM
FRC #1611
Yes i know, we press the program button and turn the LED orange like it is suppose to be, but when we go to download the program onto the interface the LED resets and starts blinking again.
Unread 09-20-2005, 09:56 AM
Dave Scheck's Avatar
Dave Scheck Dave Scheck is offline
FRC #0111 (WildStang)
Dave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond repute
I'm assuming that you're talking about the Program State LED. It will turn orange when the Program button is pressed. When you start downloading to it, the LED will flash. Is this what you're seeing? What do you see at the loader side? There should be a progress bar that shows the status of your download.
Unread 09-20-2005, 09:57 AM
FRC #1611
No it just brings up a download error message.
Unread 09-20-2005, 10:00 AM
Try holding the Program button on the RC down, then clicking and holding down the Download button on the loader. Release the Download button then immediately release the Program button. We've had problems in the past with older laptops not being able to download and this usually solved it.
Also, are you sure that your serial cable is good and that it is properly seated in the programming port?
Unread 09-20-2005, 01:26 PM
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Ryan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud of
Sometimes hitting the reset button helps as well...
Unread 10-03-2005, 09:17 AM
FRC #1611
Ok now this is not working, we switch cables, we have tryed so many times to press the program button and at different times, but it will still not program
Unread 10-03-2005, 10:26 AM
JamesBrown JamesBrown is offline
Finally An Engineer
FRC #3280
JamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond repute
Well I rember exactly a year ago when i was on a rookie team with the exact same problem. It gets better, since them I have learned a third programming language and written 6 different auton codes for the bot, This time last year I could do little more than program a TI 83 in a dummed down version of basic, once you get it it just keeps coming.
Now to solve your problem (or atleast to help) are you uasing a laptop or desk top. With a laptop make sure it sees the port your using, with a desktop dont bother fighting with it if you have acess to another computer use that instead, I have an HP and an Emachine at home with Identical processors, memory and operating systems, however I can only load code from my HP and not my parents Emachine, go figure. Have someone take it home and try, It seemed to me that the edu rc is far more tempermental than its FRC counter part.
Like I said I was in the same place last year, I had no mentor help and no experience (I don't know what your mentor situation is like) If you need more help then PM or Email me. I'd be more than happy to give you a hand, also if you have a phone with free long distance Id be happy to give you my cell number let me know. Email is James_brown830@yahoo.com
James
Partitioning my hard drive for redhat mechanicalbrain Chit-Chat 2 09-18-2005 06:25 AM
Trouble booting Linux from hard drive after CD install edomus Technical Discussion 2 11-01-2004 07:03 AM
Are you hard core or not? Joe Johnson Championship Event 7 04-25-2002 10:05 PM
How hard is it to pull a goal? Ken Leung General Forum 19 01-17-2002 07:09 PM
