#16
Re: manual control of a victor?
A goto statement in a subroutine is kinda like the hyperspace button on a video game - you have coded yourself into a deadend, and there is no other way out
thats not good. The golden rules that each discipline of engineering have come up with over the years are the result of many painfull and expensive blunders and mistakes. When you find yourself tempted to break one, its a red flag that you didnt think things through before you started writing code, or drawing schematics, or designing your logic. On military projects they have many of the same rules. If you dont follow them your project will be rejected at your next design review, and they dont grant exceptions either :^) |
#17
![]() Last edited by Mark McLeod : 11-02-2005 at 02:45 PM. |
#18
I personally have never encountered a good reason to use a goto in my own work. I have, however, seen enough cases where even the best, most well-thought out designs will run into certain practical limitations that sometimes cause us to have to do things in a way that is less than ideal. This can often be the case, for example, when writing code that interacts directly with hardware. Tight timing constraints or poorly-done hardware interfaces (on external chips) can put you in a corner where a nice elegant software design just won't work. This tells me that there most likely are cases that I have not seen yet where the use of a goto might be justified. (Sorry to original poster for continuing to take this tread off topic... ) |
#19
It has amazed me that engineers from all over the world somehow know the golden rules that apply to their profession, and they are not afraid to point out to you (during a design review) that 'this is a problem, you should never do this'. Seriously, I though Dr Eric Schmidt at Suny Buffalo came up with "Dr Schmidts Golden rules of digital design", because he shared them with us as if they were his own children, in a hushed tone, almost as if they were sacred. but somehow, everyone seems to know them :^) |
#20
Ken,
You are just plain wrong. According the the Wikipedia's entry on the 555, "Still today, Samsung in Korea manufactures over 1 billion units per year (2003)." Ken that is BILLION with a B. You don't get to a Billion units with yahoos and hobbyists. Can you mis-use the 555? Yes, of course. Would it be unacceptable to use a 555 in a billion dollar satellite project? Yes, of course. Can they be put to great use by hobbyist, toy manufacturers, and others who are willing to live with their inherent limitations? Yes, of course. Is a blanket condemnation of using 555s anywhere under any circumstances just plain silly? Yes, of course. This is not to say that "golden rules" are not useful. But if I have the choice between understanding the reasons for rules and blind adherance, I am going to advocate understanding the rules. I am going to go even further. In answer the the question that started this this thread, it is hard to argue that the best solution for the problem as presented is anything other than heading down to the local Radio Shack with $10*, buying a 555 and a few extra goodies and building a circuit that works as desired within 15 minutes of arriving home. I am getting my undies all in a bunch because I believe with every fiber of my being that Engineering is an Art. It is a beautiful, wonderful, delightful art. There are laws of physics, useful rules of thumb, and cold hard economics that come into play to be sure but at its core Engineering is Art. For these artists, there is no substute for sound engineering judgement. Joe J. *For an additional few buck he could have put in all in a nice pretty box to boot! Last edited by Joe Johnson : 11-02-2005 at 09:47 PM. |
#21
In particular, I needed a PWM stream with two specific pulse widths, and used two 555's as one shots, fired by logic that picked which one based on if I needed a "1" or a "0". The logic was driven by clocked logic that followed all the "golden rules", but the 555 was far and away the easiest way to get the two pulse widths. Took 10 minutes to put it all together, which was far less time than I spent listening to various design engineers tell me I needed a PIC, or a FPGA, or ..... (all of which, in addition to having the added time of writing the software, in the spaceflight test world have the added burden of having to place all of the code used into configuration management, so the <$1 PIC now costs considerably more to use once in a test fixture). There is almost always more than one solution to any engineering problem. One part of elegant design is picking the one that makes the most sense for a particular design problem, even if that means "breaking" some normally established "rules". Last edited by Jeff Pahl : 11-02-2005 at 09:12 PM. Reason: finally learned how to get the quote right |
#22
your examples of being able to put together a one shot circuit quickly and easily assumes you already have experience with 555 timers, or similar devices, and you dont have to consult a data sheet to look up the equations, figure out whether to use ceramic or electolytic or tantilum caps, variable resistors, carbon, wire, precision resisitors, to get the performace you need under all conditions
I could equally argue that with my 10 years of experience using PIC chips I can pull a PWM or timer subroutine out of my existing libraries, compile the SW in a minute or two, and all I need is power and gnd to the 8 pin PIC chip, and it will be producing a very accurate, very precise waveform in a matter of minutes and with the in-circuit programablilty of PIC chips, I can change any of the parameters faster than you can unsolder and solder caps and resistors. I dont know where those 1 billion one shot chips are going each year. I can honestly say that in my 20 years of electrical and computer design experience, on both military and commercial products, I have never used one, and I have never seen any product at any of the companies Ive worked for use one either. |
#23
I can say in my 20+ years working for one major medical imaging company, among the dozens of other thing GE is into, that I have seen multiple systems and circuits, from various vendors and corporations, that do use 555's. I guess my point is: Until you have seen everything, every situation, every design, every possibility, making blanket statements and setting hard and fast rules, with no room to bend, is just not a good idea. BTW, I did a quick Google search and found a great little 555 circuit that will suffice perfectly to generate a 1 to 2 ms pulse at a period of 17ms. One 555, one cap, one pot and a resistor. It even had charts on the site for the mathematically impaired to help decide what component values to use. Don't get me wrong, I understand the Prof.'s reasoning for doing things his way. He has every right and privilege as a Prof. to do so in his class room. But unless he meets the "Until you have seen everything, every situation, every design, every possibility...." rule, his ways outside the class room aren't always the best ways. |
#24
taking a step back from this discussion, Dr Schmidt taught the senior level Digital Design class
the focus of my career has been digital design and programming and the 555 timer and other one-shot chips are analog devices so this is really a discussion of the merits of digital systems vs analog systems - and the merits of hybrid digital/analog systems so from Dr Schmidts persepective, he was correct. Analog timers have no place in a digital design class, and they have no place in a digital system (ie, you would never plop down a 555 timer to generate the CAS and RAS signals to an SDRAM bank on a pentium motherboard, you would use digital counters and state machines I concede that if you are designing an analog system, then things like one shot timers are acceptable and Im certain that analog designers have their own set of golden rules but back to the original question of this thread, I think the debate that has been raging here is really a question of which approach is better, a digital or an analog solution? BTW, part of the problem is that the PWM control of the victors is a carry over of the PWM of radio control model servos. Originally all RC systems were analog, but now here we are with these digital FIRST controllers interfaced to Victor speed controllers, with a legacy-analog PWM signal format. :^) Last edited by KenWittlief : 11-03-2005 at 12:40 PM. |
#25
Ken and Joe,
Let us not forget that no matter what the individual benefits or pitfalls, I can go down to the local Radio Shack and pick up a 555 usually with a schematic on the back and have something useful, albeit inaccurate, within an hour or so. I would love to use a PIC, but don't have any at a local store or my junkbox or even at work. And the fishing timer I built for my wife's aunt, works great and no one cares if it times out at 15 minutes or even at sixteen minutes. As long as it times out and reminds us to move on to a new spot, everyone is happy. BTW, I used a dual 555 to make a really annoying alarm output for my Heathkit digital clock. It has lot's of distortion, dual frequencies and darn near knocks me out of bed at 4:44 AM each morning. (for an audio guy, the distortion does the trick) My wife likes that better than having 220 volts hooked up to the bedsprings. |
#26
15 minute fishing timer? thats an interesting idea. How does it let the fish know its time to move to a new spot? :^)
#27
I don't know but it works really well. I haven't caught a fish on their lake yet. As a matter of fact I was presented with a plaque two years ago with the words "Fish laugh at the mention of your name".
#28
![]() Worst case, the fish won't laugh any longer. They'll be deaf and never hear your name mentioned again. ![]() |
#29
If it is the latter and you just want to buy something off the shelf, may I suggest the FMA Direct Servo Lab. You can get it from Tower Hobbies (http://www2.towerhobbies.com/cgi-bin...?&I=LXJVD9&P=0) or other hobby places for less than $35. It is really useful for testing Victors and test driving motors connected to a Victor (and power) without having to have the whole IFI control system hooked up. It also will "read" the PWM signal from the IFI Robot Controller which can be very useful to see how the joystick and code are responding. You can even hook it up in line between the RC and the Victor. Works great, I highly recommend one. If you get one you will need to get a cheap RC battery as well if you don't have one. Another COTS option that is a little less expensive (~$20) is the Astro Flight Servo Tester (http://www2.towerhobbies.com/cgi-bin...&I=LXVK79&P=0). I don't personally have one of these but it should do what you want (manually control the Victor) but it will not "read" the PWM signal from the RC like the FMA Direct Servo Lab. Now everyone can get back to discussing the pros and cons of a 555... |
| Concept of PID explained | ConKbot of Doom | Technical Discussion | 11 | 01-27-2008 12:11 AM |
| Victor Input / Motor Control | Jack | Electrical | 5 | 12-01-2004 02:23 AM |
| Manual override of compressor software control | willross | Pneumatics | 15 | 02-18-2004 11:51 PM |
| Autonomous to Manual control? | Lint_Ninja | Programming | 5 | 02-16-2004 09:48 PM |
| Non-variable Victor Control | Madison | Technical Discussion | 16 | 01-31-2002 03:35 PM |
