#16
Re: autonmous corner or center
i read there is a white light that is used to score the balls in the corner goals. would it be possible to track the corner goals using the camera?
I am asking because using dead reckoning to find the corner goals might prove to be difficult. |
#17
I think that with the cameras, there is potential for chaos during autonomous.
But, I guess it will all work out in some way ![]() |
#18
PS The camera won't track the corner goals, trust me. PPS Listen to Tom, he's a bright guy. |
#19
It depends on what your robot is good at. If you have no mechanism for shooting, you won't try for the center. Our group has decided to focus on the corner goals, both in autonomous and in normal play.
#23
Both goals being on the field should not be much of a problem, since it is unlikely that you will be pushed onto the wrong side of the field, and your robot will know what position it is starting in.
The green targets are roughly 10ft above the field, and if you are using Kevin's 2006 CMUCam code, you will be able to easily get the angle of your tilt servo, that angle becomes theta, from that you can do Tan(Theta) = (10/X) and solve for X. That reduces to X = (10 / Tan(Theta)). The field is 54' long, if you are >28ft away, you know that you are shooting onto the other side of the field. It's not perfect, but it's unlikely that your robot will be pushed onto the wrong side of the field, and turned around. This is why it makes sense to have an onboard navigation system. I’d really like to see our team design a bot capable of shooting into the center goal, the only real issue I can see is the hardware shooting device not being consistent enough to depend on it. |
#27
The camera is absolutely esential to this game during both auton and manual mode. Thats the only way to constally keep track of the goal. Otherwise you would have to stop and postion the launcher so the ball goes into the hole. Think of doing this manually form over 30 ft away toward the other end away form you?
Realtime trig and projectile motion calculations!!! |
#29
Yes, the camara would be nice to use in the manual 2 minutes, but then you are relying totally on the camara. our team was thinking of something where the camara would give some kind of feedback, whether or not the position of the "cannon" would make the shot.
#30
Center goal. All 10 in less then the 10 seconds.
![]() I just don't know how to do it yet. Wetzel |
| Center to Center Distance for 2002 Chaiphua and Cluster gear | sanddrag | Motors | 1 | 07-20-2005 06:36 AM |
| Pre-Shipping Scrimmage at the North Montco Technical Career Center | OZ_341 | Off-Season Events | 1 | 02-05-2004 10:59 PM |
| Blue Man Group FIRST get-together? | Gui Cavalcanti | Chit-Chat | 11 | 09-16-2003 05:11 PM |
| Full list of teams & competitions | archiver | 2001 | 14 | 06-23-2002 11:52 PM |
| KSC Results | archiver | 2000 | 2 | 06-23-2002 09:19 PM |
