Go to Post There can be a fine line between intimidation and inspiration when it come to the elite in FIRST. Those teams who have committed to setting the bar for excellence in ways that change the culture, help to draw that line and deepen it. - JaneYoung [more]
VEXpro
Cross the Road Electronics
ADVERTISEMENT
Unread 01-12-2006, 09:08 AM
Unglued Unglued is offline
AKA: Andrea Valenzuela
None #0865 (Warp7)
Team Role: Animator
Unglued is on a distinguished road
Send a message via AIM to Unglued Send a message via MSN to Unglued
just a reminder to remove everything expensive and fragile around ball shooters
please remember to remove all measuring equipment around the ball shooter(or anything that's expensive and fragile)
you can watch our mistake here
Unread 01-12-2006, 12:45 PM
Rombus's Avatar
Rombus Rombus is offline
Not the Shape!
AKA: Rick Kosbab
FRC #1278 (B.E.A.R.S.)
Rombus will become famous soon enoughRombus will become famous soon enough
Send a message via AIM to Rombus
Re: just a reminder to remove everything expensive and fragile around ball shooters
interesting use for a lathe!
Resident College Student for:
Team 1278 "B.E.A.R.S."
Better Engineered Antonomous Robotic Systems
'06 Team Quote: "B.E.A.R.S. Dont sleep untill the season is over!"
Unread 01-12-2006, 12:46 PM
generalbrando's Avatar
generalbrando generalbrando is offline
Build, Break, Repeat
AKA: Brandon Mensing
FRC #0246 (Overclocked)
generalbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to behold
Send a message via AIM to generalbrando
Also, look out for fire sprinkler heads. Set off one of those and you'll have a wet 'bot (not to mention an evacuation).
Lead Mentor of Team #246, Boston University Academy and Boston University, Overclocked
www.burobotics.org
Unread 01-12-2006, 01:35 PM
Mark Pettit's Avatar
Mark Pettit Mark Pettit is offline
Addict
FRC #0991 (The Dukes)
Mark Pettit is a name known to allMark Pettit is a name known to allMark Pettit is a name known to allMark Pettit is a name known to allMark Pettit is a name known to allMark Pettit is a name known to all
If an object is within range and it is expensive, necessary, unreplaceable, or able to be hurt/maimed, then that is the object that the projectile is going to hit 9 times out of 10.
Be careful! Be safe!
Mark Pettit
Team #991 - The Dukes
Brophy College Preparatory
Phoenix, Arizona, USA
THE DUKES: Humans Competing In The Unlimited Class
Unread 01-12-2006, 01:56 PM
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Send a message via AIM to Madison
Where are your mentors? I can't believe that anybody let you do that.
This is the first (and, if this stuff keeps up, last) time FIRST has allowed high-speed projectiles in years. Please use some common sense, people.
--Madison--
...down at the Ozdust!
Build season blog:
http://teamxbot.blogspot.com/
Unread 01-12-2006, 02:02 PM
Aburame Shino's Avatar
Aburame Shino Aburame Shino is offline
Professional Gamer
FRC #0093 (N.E.W. Apple Corps.)
Aburame Shino will become famous soon enoughAburame Shino will become famous soon enough
I was going to ask the same thing. A lathe is not a toy, and anything flying off of it can cause some serious damage. You should've had one of the mentors watching what you were doing.
At least nobody got hurt.
Chat with other people visiting the website you're on! Install yakalike today! (Firefox only)
Unread 01-12-2006, 02:53 PM
None #0865 (Warp7)
Team Role: Animator
a mentor was in the next room over and knew what we were doing.
we have regular use the lathe everyday almost, we all know how to use it, and how dangerous it could be.
i don't see why it's so unbeleivable about attaching the wheels to a lathe. it's simular to what we would have used motor-wise the only difference would be we would
we were testing to see if 1400 rpm was enough, the one wheel didn't get the wheel too far, however once we added the second wheel it got much more distance and 'channeled' the ball forward.
we should have had a system to put the ball in the same way everytime, if we did the ball wouldn't have hit the side of the wheel and gone sideways.
bottom line is we should have taken better care and moved everything out of the way, and not just everything in front of it. balls can bounce, and just not go where they'rre intended to.
Unread 01-12-2006, 09:20 PM
in between teams
AKA: Luke Van Oort
Don't forget that the robot counts in this too. A richochet (while not likely with foam balls) could happen. Test in open areas, which have the added benefit of letting you see if anyones coming into the line of fire. (No, "Oh! I didn't see you around the corner!"
Team 1219: 2009 - Mentor
Unread 01-12-2006, 09:35 PM
Financial Engineer
FRC #3929 (FRC #1403, FRC #3186)
Send a message via AIM to Conor Ryan Send a message via Skype™ to Conor Ryan
Safety Glasses?
Didn't see any in the video
Ask me about:
University of Dayton (especially Engineering/Business)
Or anything else about FRC, I have done almost all of it! And seen a lot of it!
Make friends on CD, you got a lot in common.
Unread 01-12-2006, 11:53 PM
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Generally, when you do something stupid and unsafe, it isn't the best idea to go and tell thousands of people on CD about it.
*2001-2004: Team 100
2005:
*Sacramento-Inspector/Referee
*UTC-Field Reset
*SVR-Inspector/Referee
*Nationals-Inspector/Referee
2006-???: Mentor, Team 254
Unread 01-13-2006, 08:10 AM
None #0865 (Warp7)
Team Role: Animator
Originally Posted by Conor Ryan
Safety Glasses?
this is true as we weren't machining anything at the time
i don't believe a flying 7" foam ball will cause too much damage, not at that speed anyways.
being a technical school the first thing we learn is safety.
Unread 01-13-2006, 08:21 AM
kaszeta's Avatar
kaszeta kaszeta is offline
FRC #0095 (Grasshoppers)
kaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of light
You were running a lathe at high speed. Things can fly off and do some pretty serious damage.
At both the machine shop our team uses and my day job, this sort of thing would've gotten you in serious trouble.
Unread 01-13-2006, 08:38 AM
Ken Leung's Avatar Unsung FIRST Hero
Ken Leung Ken Leung is offline
Dare to Live!
FRC #0115 (Monta Vista Robotics Team)
Ken Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond repute
Send a message via AIM to Ken Leung
While this might be true and you might never get hurt doing what you did, there is a slight chance that you may get hurt from using a lathe in a way that it wasn't designed to. Use it to spin a wheel to shoot a ball across the room full of machinary and tools? I highly doubt that's the real purpose of a lathe.
But that's not the issue. You guys have obviously concluded it is ok to do it, otherwise you would've have done what you've done. There's no arguing if your mentors and school administrators think that's an ok thing to do.
The issue is, don't post in this forum and show this video to the FIRST community without expecting the rest of us flooding you with messages saying "this isn't safe!!!" In a competition where safety glasses is mandatory on the playing field as well as the pit area, and when safety is an award itself, do not expect people to say nice thing about dangerous acts. Don't expect anything less from us.
So, you can learn to listen to good advice, or risk getting hurt in the future. Just don't say we never warned you .
Hardware Test Engineer supporting RE<C, Google.
1999-2001: Team 192 Gunn Robotics Team
2001-2002: Team 100, 192, 258, 419
2002-2004: Western Region Robotics Forum, Score Keeper @ Sac, Az, SVR, SC, CE, IRI, CalGames
2003-2004, 2006-2007: California Robot Games Manager
2008: MC in training @ Sac, CalGames
2009: Master of Ceremony @ Sac, CalGames
2010: GA in training @ SVR, Sac.
2010-2011: Mechanical Mentor, Team 115 MVRT
Unread 01-13-2006, 10:00 AM
Cody Carey's Avatar
Cody Carey Cody Carey is offline
AKA: C. Carey
FRC #0306 (CRT)
Cody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond repute
Send a message via AIM to Cody Carey Send a message via Yahoo to Cody Carey
Yes, It was unsafe. No they weren't wearing safety glasses, and no, there mentor wasn't present in the room. What can you expect, we're highschool kids. When we do this stuff, we learn from it and don't do it again. This thread was to warn people about their mistakes, and that's not a bad thing to do. I see where you are coming from by telling them to be WAY more careful, but by everyone saying it at the same time and in such harsh terms... you make people feel ganged up upon. Thats my 2 cent's, Sorry if you don't like it.
Sincerely ,
Cody Carey
Unread 01-13-2006, 12:35 PM
None #0865 (Warp7)
Team Role: Animator
the top speed of that lathe is 1400 rpm and the small cim we were originally going to use is 3000+ rpm
i really don't see how this could be any less dangerous than any other attempt for a prototype, we were shooting towards the classroom half of the room, where the greatest danger are rulers and vices, which could of course hurt you, everything has potential to hurt you. don't be like those people who wear plastic gloves everywhere they go, sure it keeps then safe from germs, but it really isn't necessary.
and as cody c said, we're high school kids, dumb things can be expected from us.
