#16
Re: Does CAD get respect on your team?
Thank you all for your helpful responses. On 1250, no one even knows there is an Inventor award. I guess that tells you how important CAD is on the team.
In defense of the team, there is a shortage of computing facilities to perform this work so a single designer is doing it at home. More an exercise in documenting the design rather than design to build. As this was posted in the CAD section, I am not surprised to find that most of the responses were on a positive note. Maybe I'll try in the general forum and see what happens. Good luck with all your entries! |
#18
I believe the CAD drawings are very important to design. Our mentors however did not think it was. So when we came upon the problem of not having the right wheels because we were making the robot basicly as we went we had run into the issue and had to reorder wheels. Needless to say for all those who don't think its important there is a prime example. That and if you are really savy about using it you can model everything down to bolts and wires and can generally get to know your robot very well even if it is shipped off
#19
Inventor important to some extent. There have been plenty of times when we've saved hours of work by using Inventor. But the problem is when you make slight changes like drilling a hole here for weight, or simply throwing a part out and quickly cutting another one takes a lot less time. These quick changes put designers behind the manufacturers, and then catching up with a manufacturing team that usually has 3 or 4 times as many people on the design team it's impossible. Complete robots, including electronics, pneumatics, animations are all things that take so little time compared to Inventor. Also most teams work till the last minute, then when the robot is gone it's impossible to get measurements. All of these factors lead to the impossibility to use Inventor completely. I will say team 103 used inventor a lot. We designed every one of our prototypes, and even used it to lay out a schematic for electronics. This was due to successful communication and working along with our manufacturing guys.
#20
CAD is the oxygen for engineering. It's the baseline for all that we do -- atleast to start. It helps us see things we would not without designing.
#21
CAD? What's CAD?
Really our team is starting to use it more. Part of the problem is that we build before they can CAD an idea. As the students improve I am sure that it will become a starting point not a middle ground. |
#22
On the otherhand, quick fixes (weight holes, corner rounding, last-minute changes) are done without design work in advance, leaving the CAD team to walk into the shop everyday to ask "What did you change today?" |
#23
For us, CAD(Autodesk Inventor) was become the golden rule. It has given us two ubercool chassises that are awsome. The arms are a different story. But yes, CAD gets massive props on our team. If you have'nt done so, have you been living under a robot?!
#24
Without Cad on our team, no robot would ever be mad. For the past 3 years now the robot has been completely made on cad before made in real life. This helps do it right the first time and gives the students real life experience in designing parts for most anything.
#25
Yes CAD is very important on our team. It helps everyone see their ideas and also helps save alot of money when it's time to prototype. I personally don't do much CAD and work but I do do alot for FIRST which helps keep me on top of these skills if I ever need to use them for work.
E |
#26
sadly our robot seemed to be built before cadd was even mentioned. My son was the only one who tried to cadd but it is so hard with 7 sets of hands building and only one cadding. we took lots of pictures but overall as a rookie team cadd was not really used. now Paint on the other hand was used in the design as it is simple, clear, to the point, and everyone on the team understood it instantly. now we are working on the cadd more as a documentation of what the team went through to get what it has now.
I hope that next year CADD will take a larger part in the design but it is hard when all the kids really want to do is build. |
#27
#28
Team 213 relies on Autodesk Inventor from the beginning until the end of the season. The two student design leaders (a friend and I) are the lead Inventor modelers on the team, and are often doing most of the modeling the parts. I also teach the younger members how to use the program, and I am pleased to say that they were very enthusiastic about it. Inventor is a very powerful and useful tool that has streamlined the efficiency of our manufacturing process.
#29
On our team, if you wish to make a major modification to the robot, you must fully draw it in CAD first.
#30
| East Coast Drivers Union | Corey Balint | East Coast Drivers Union | 153 | 04-10-2006 02:50 PM |
| Top 10 seasons in FIRST History | Karthik | General Forum | 6 | 08-01-2005 10:30 PM |
| CAD on your team? | SpaceOsc | Inventor | 25 | 11-18-2004 10:14 AM |
| Kettering Kickoff | Matt Attallah | Off-Season Events | 19 | 09-27-2004 09:40 PM |
