#76
Re: The 8.2 (or 8.3) Battery Voltage Bug
-Kevin |
#79
IFI appears to be working on this, and has sent me an updated linker script which I am going to test to see if this corrects the issue. I'll let you know how testing turns out.
#80
-Kevin |
#81
We were running our practice robot tonight and ran into a very similar problem. In the middle of running the robot manually, the inputs stopped working and the OI displayed 8.6v. After cycling power on the robot, it worked fine. Could this be another manifestation of this issue? We are using the 2005 controller and easyC.
#82
I dont have our 2006 controller or any parts with me. But anyone who had this issue please post what you find after using this new linker script.
#83
As for 18f8722_2.44.lkr, if you try to use it as provided, you get a "Error - section '_entry_scn' type is non-overlay and absolute but occurs in more than one input file" from the linker, which requires that you comment out the first "FILE" line in the .lkr script. After that, IFI Loader won't upload it, giving an "invalid address : 0x20 (Correct Range: 0x800-0x7fff)" error. |
#84
-Kevin |
#85
Well programmers, there is upshot to this. For once there is a programming problem that might not be our fault!
What leads people to think that this is a problem with the linker script? It seems to me like there is a good chance this could be a master proc problem. Its interesting to note that 8.2/8.3 volts is very near 127 when you convert it using that little forumula. Is it possible that the RC and OI are somehow loosing synchronization and reading the wrong parts of the packets? Maybie some structure or array is being manipulated incorrectly? Make sure you are using the newest version of IFI loader. I had some bizarre similar problems from using an old version. I have also had weird errors from USB->serial converters. Rule these things out first. Last edited by Rickertsen2 : 03-07-2006 at 08:57 PM. |
#86
And our laptop is still old enough to have a serial port... But yes, both of these are worth ruling out. |
#88
Although, the fact that the Master processor is now communcating with the radio and arena controller may have something to do with it.. but this would have shown up last year if this were the case. Does anyone know if the master processor was upgraded too? Or is it still an 8520? If its the 8772, why haven't we seen another release of the firmware after the new IFI libraries were released? I somehow doubt that the user processor is at fault here.. so the linker script is worthless. |
#89
![]() EDIT: DeviceNull, I did some snooping and I think you may be right about the encryption, although there's no way to be absolutely sure. There sure are a lot of unsubstatiated rumors about that AC to RC link floating around! ![]() Last edited by Eldarion : 03-08-2006 at 01:16 AM. |
#90
as our robot is in the crate heading from Portland to SanJose. I did try building the hex file with the beta <linker> script, however, and note that there is a large number of differences in the hex file, relative to the one generated prior to copying the beta <linker> into place. If IFI fixed a bug in the linker script with their change, our code was stepping on this bug in lots of places. We will learn the score, for sure, during the practice day at the SanJose regional... Eugene Last edited by eugenebrooks : 03-08-2006 at 10:48 AM. |
| Reading battery voltage in software | RbtGal1351 | Programming | 17 | 10-21-2007 12:07 PM |
| How to obtain battery voltage from within EasyC | DavidSJohnson | easyC for FRC | 2 | 02-13-2006 11:05 PM |
| battery voltage compensation | Rickertsen2 | Programming | 5 | 10-17-2005 09:12 PM |
| RC Circuits | Melissa Nute | Math and Science | 3 | 01-25-2004 04:02 AM |
| Battery Chargers | Neal Probert | Electrical | 46 | 02-16-2003 09:31 PM |
