#16
Re: Section 8.3.3 Illegal Gearboxes and Chassis
while an entire COTS gearbox from a prior year's 'bot seems to be disallowed, what about the components that its made of? specifically, i'd like to pull the guts out of our old AM shifters, and use them in our latest design; all the basic parts are available individually from AM.biz (and i suspect we'll need some additional/replacement parts), so if i list the individual parts on my BOM, would this be within the letter and spirit of the rule(s)?
#17
This is were we will need better answers from FIRST. I would also ask the question : Why can someone use a design from last year but someone that works on one in the off season is not allowed to use that design? I can understand that it must be built during "BUILD" season, but why would FIRST stiffle the inspiration and creativity that they are trying to promote. I guess that there is the same issue with those that worked on getting the camera to work and cannot use what they have designed (I know that it has to be reprogrammed as builders must rebuild). |
#19
-dave |
#20
so, do you feel that the term "gracious lawyer" might be an oxymoron?
#21
Back to topic: my interpretation is similar to Tristan's. I would like very much to have a 2007 Q&A response on this very soon. It would not be any fun to inspect Paul's robot if (1) he proceeds as outlined above and (2) I still concur with Tristan's reasoning on March 1st. We need the GDC to resolve this one before any of us waste a lot more time. |
#22
A. Off-season/prior season designs and drawings. B. Off-season purchased mechanisms. C. Previous year components and mechanisms. 10 different people asking 30+ different questions might not work as well. |
#23
I nominate Tristan.
#24
Here is the question I posted to the Q&A forums although it has not shown up yet:
With that said, then why have rule R24? Commercial off the shelf components are covered every other place in the manual so why this special rule? It makes abosolutely no sense!. |
#25
what about mechanisms from previous seasons that were developed but not used
#26
The Lab Rats (Team 1748) had to purchase AndyMark transmissions before kickoff because if we waited to order them through the Baltimore City School System we wouldn't get them until after build season.
We only opened the box with our AndyMark transmissions on the ninth (after kickoff). We are a second year team in Baltimore City. We can't afford to buy another set of transmissions identical to what we just opened in order to say we purchased them after kickoff. It seems like we met the intent of the rules and are getting caught up in legalities. I'm hoping that FIRST will allow us to use the transmissions we purchased but did not open until after the kickoff. My students want to finish designing our drivetrain and they need to know what they can use. Last edited by gabrielse : 01-11-2007 at 10:45 AM. |
#27
You took something of a risk in purchasing before Kickoff. They could have switched to VEX type parts or some other motors completely unsuitable and you would have been stuck, but fortunately for us all this is not the case. There is the question of whether or not this is a "pre-designed solution". Since you are making your own choices as to wheel size, gearing etc. I'd say it is not. The AM gearbox could be used to power an arm or robot lifter in addition to a drive system so it is generic enough in my mind that this is not a concern. So turn your guys loose. |
#29
I tried posting a question about a similar situation to the Q&A, but I don't seem to be having much luck with the Q&A fora this year. Hopefully we can get a ruling quickly so the design process can continue. |
#30
FIRST says they want a team in every school funded by the states. If they're serious about that, they need to get their heads out of the clouds and look at how their policies and rules actually affect these minimally funded school teams. As it is, it seems they've drafted their rules to force teams to spend all their time hunting sponsors before they can do any actually interesting engineering. At the very LEAST, FIRST could have warned teams, OFFICIALLY, that mechanisms bought preseason would be disallowed. Despite Dave being high up there, no one is going to take his vague warnings on CD as seriously as an Email Blast from FIRST. This wouldn't have affected the game a single bit and would've given time for debate and consideration prior to it becoming an actual issue. Last edited by Kevin Sevcik : 01-11-2007 at 01:57 PM. |
| KOP Gearboxes and noises | David Sherman | Kit & Additional Hardware | 8 | 01-29-2006 01:37 PM |
| Drive train and gearboxes | Naveen | Technical Discussion | 15 | 01-16-2006 05:08 PM |
| Motors and gearboxes in the kit | Kam1310 | Technical Discussion | 1 | 03-09-2005 05:43 PM |
| Error - section 'UTIL_LIB' can not fit the section. Section 'UTIL_LIB' length=0x00000 | BookerT | Programming | 13 | 01-27-2005 09:49 AM |
| Error - section 'UTIL_LIB' can not fit the section. Section 'UTIL_LIB' length=0x00000 | BookerT | Programming | 0 | 01-25-2005 07:17 PM |
