Go to Post Legend has it that Brandon installs the server in a bulletproof case shortly before Kickoff. That way, when the server explodes, the damage to surrounding things is minimal. - Billfred [more]
VEXpro
GODUC
ADVERTISEMENT
Unread 11-14-2007, 08:29 AM
whytheheckme's Avatar
whytheheckme whytheheckme is offline
AKA: Jacob Komar
whytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond repute
Send a message via ICQ to whytheheckme Send a message via AIM to whytheheckme Send a message via MSN to whytheheckme Send a message via Yahoo to whytheheckme Send a message via Skype™ to whytheheckme
Segway from KOP?
Looking at this guy's site:
http://tlb.org/scooter.html
and the stuff he used, a DIY segway could be built completely from the KOP (except maybe some of the frame.)
Going down the list:
Code:
Motors	 Brushless servo motors with neodymium magnets. "The highest-power motors for their size and weight ever put into mass production".	 Conventional DC motors with gearbox, widely used in powered wheelchairs. $286 each from National Power Chair or from Robot MarketPlace.
CIMs
Gearbox	 "Like a precision Swiss watch". Engineers designed the "meshes in the gearbox to produce sound exactly two musical octaves apart."	 Part of the wheelchair motor above. When going up a ramp, they sound kind of like the starter motor on my old Dodge Dart. Rrrrr-rrrr-rrrr-rrrr.
Banebots planetary
Batteries	 2, 60-cell custom-designed NiMH packs producing 72 volts. "the highest power of any currently available chemistry".	 20, 6-cell NiMH packs made for RC cars. They have "IDEAL SOLUTION FOR RC TOY" printed on them.$15 each from Powerizer.
Robot battery (maybe something smaller would be needed)
Wheels	 Wheels are "sophisticated engineering-grade thermoplastic." Tires by Michelin, with a "unique tread compound (a silica-based compound instead of traditional carbon-based materials)".	 Wheels are stamped steel. I think they're made for utility trailers. Tires made by Cheng Shin tire works. They make startlingly loud squelching sounds on tile floors. Tire and wheel are $79 each from NPC, and hubs are $20 each.
KOP wheels should work, maybe something bigger?
Controller	 "Sophisticated controller boards from Delphi Electronics" with "Texas Instruments digital signal processor, monitoring the entire Segway HT system and checking 100 times per second."	 An 8-bit microcontroller from Atmel, running code written in C using floating point arithmetic. It sends speed control commands out the serial port at 9600 baud in ASCII to the motor driver. $10 from Digikey.
FRC controller would be overkill. VEX controller could be used.
Or spend 10 bux for this controller (the problem with this would be the lack of interface for the Victors, whereas FRC or VEX would work directly)
Motor Driver	 "a set of 12 high-power, high-voltage field-effect transistors (FETs)".	 The controller has 16 MOSFETs and can handle way more current than my batteries can supply. Made by RoboteQ, it's $485 from Robot MarketPlace. It's a popular part for use in Battlebots.
IFI Victors
Gyroscope	 "packed with five solid-state, vibrating-ring, angular-rate sensors"	 One ceramic rate gyro, of the same kind that's in your camcorder (to detect your hand jiggling and stabilize the video) or RC helicopter (to stabilize the tail), and a 2-axis accelerometer to correct for drift. $149 from Rotomotion complete with the Atmel microcontroller.
KOP gyro
Structure	 Plastic and aluminum in smooth swooping shapes. "Chassis withstands 7 tons of force."	 Two pieces of aluminum plate with holes drilled in them, and a standard aluminum extrusion for the handle.
KOP metal could be used, probably other stuff would be needed though.
Safety features	 Everything is dual redundant. For example, "in the unlikely event of a battery failure, the system is designed to use the second battery to operate the machine and allow it to continue balancing until it is brought to a safe stop."	 There is no redundancy or backup system. It is not even robustly made. Loose wires literally dangle out the bottom. In the fairly likely event of the software crashing, a wire coming loose, a component failing, or the batteries running low, the wheels will stop and the entire kinetic energy of the system will be used to accelerate my head toward the ground.
Not sure about this one :p
Just an idea
Jacob
Unread 11-14-2007, 10:55 AM
synth3tk's Avatar
synth3tk synth3tk is offline
The Voice
AKA: David Thomas
synth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond repute
Send a message via Skype™ to synth3tk
Re: Segway from KOP?
Hehe, we could have an off-season KOP Segway event!!! We've got all the parts from our robots since we started in 2002, so a few bucks here and there and we could make a couple.
The difference between theory and application is that in theory, theory and application are the same; In application, they are not.
Unread 11-14-2007, 11:59 AM
EHaskins EHaskins is offline
Needs to change his user title.
AKA: Eric Haskins
no team (CARD #6 (SCOE))
EHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond repute
Send a message via MSN to EHaskins Send a message via Skype™ to EHaskins
http://web.mit.edu/first/segway/
They didn't use a VEX or FRC controller, but its mostly KOP parts.
Eric Haskins KC9JVH
Unread 11-14-2007, 10:30 PM
Custom User Title
Send a message via AIM to Tom Bottiglieri
Its been done before. Why not use those parts to build an eco-friendly racing kart? That way you can be green and fun.
Why is everyone on these boards so obsessed with Segways?
Unread 11-14-2007, 10:35 PM
Billfred's Avatar
Billfred Billfred is offline
Next Year Starts Now
AKA: @WmLeverette, @LosPollosLocos, @SCRIW...
FRC #2815 (Los Pollos Locos)
Send a message via AIM to Billfred
Theory 0: Something about that guy who invented it.
Theory 1: It's a semi-interesting software challenge.
Theory 2: FIRSTers are exposed to Segways far more than the general public, but many lack the funds to purchase one. Since all high schoolers are invincible*, the safety and redundancy features of the Segway don't quite justify the added cost over building it themselves.
Theory 3: The amount of parts people are able to liberate from a team's cache may be suited more to a two-wheeled form of transportation.
Theory 4: We're used to skid-steer robots. The theory transfers somewhat to Segways, without any pesky steering.
* </sarcasm>
Personally, I'm waiting for a team to make their competition robot use Segway-esque drive.
William "Billfred" Leverette - Gamecock/Jessica Boucher victim/Facebook-er
Billfred's World Tour: USC Kickoff Palmetto CMP Robot Rodeo Manchester Kickoff Florida Palmetto CMP Capital Clash USC Kickoff FVC Orangeburg Florida Peachtree Palmetto CMP Mission Mayhem Exploding Bacon Vex Event Duel on the Delaware CalGames USC Kickoff Florida Chesapeake Palmetto CMP BattleCry Mission Mayhem Brunswick Eruption 6 Clemson Kickoff Chesapeake Palmetto CMP IRI TNT Greenville Tech Scrimmage Bayou Palmetto CMP IRI GRITS TNT Bayou Palmetto CMP IRI Citadel Kickoff Peachtree Palmetto CMP IRI TNT SCRIW Citadel Kickoff Peachtree Palmetto Championship IRI SCRIW II Chapin Kickoff Palmetto South Florida (43,212.5 miles)
Season number 10. Still on a mission from Bob.
Unread 11-14-2007, 10:51 PM
Custom User Title
[/size]
That would be cool, no doubt.
Maybe its just me, but I wouldn't be able to put so much work into something that's been done before. I wish anyone who tries this the best of luck though; I'm sure its implementation is much more challenging than it looks.
Unread 11-15-2007, 09:23 AM
colin340 colin340 is offline
AKA: colin nobles
FRC #0340 (G.R.R)
colin340 has much to be proud ofcolin340 has much to be proud ofcolin340 has much to be proud ofcolin340 has much to be proud ofcolin340 has much to be proud ofcolin340 has much to be proud ofcolin340 has much to be proud ofcolin340 has much to be proud ofcolin340 has much to be proud of
http://tlb.org/eunicycle.html
ditch the other wheel
Welcome to Spaceship Earth!
Easy C, Missing from KOP? MarkVH easyC for FRC 14 01-09-2006 04:48 PM
Pillow Block from KOP 2004 Don Wright Technical Discussion 2 01-23-2005 04:21 PM
Who is missing stuff from KOP? Matthew_H Kit & Additional Hardware 52 02-05-2004 06:52 PM
Receiving missing parts from KOP shyra1353 Kit & Additional Hardware 7 01-29-2004 11:58 PM
