pic: Shifter Fix
Re: pic: Shifter Fix
the sound Pnumatic shifting makes happy
I'll second the servo issue.
Simply: servo shifting super shifters stinks. I couldn't resist all those S's. The servos cannot shift under any type of load. The sometimes can't pull it out of gear when your robot isn't moving, and often will not go into gear at all. We just installed a pneumatic system on the bot last night so we can shift. |
Q,
would you be willing to list the part numbers you used to couple and mount the encoder? We've also been having some reliability problems with the encoders and are looking into alternatives now. Thanks. |
The encoder carries the same electrical specifications as the one that andy mark put on from the factory, minus being open frame and suceptible to any shocks/misalignments/runouts in the main drive shaft of the transmission. The part number of this US Digital encoder is S4-250-B. That is, an S4 fully assembled encoder, 250 counts/rev, Ball bearing shaft. The specific coupler is from McMaster (since we needed it quick) but could be obtained for less money from Helical (about $6 from them, $22 from mcmaster) is a 9861T609 coupling. This is a flexure coupling that goes from a 3/8" to 3/8" bore, 1" in length. If you want even more isolation from vibration/runout/whatever in the transmission, get a larger coupler with the same bores. The longer the coupler, the more isolated, however, the more weight/size. Let me know (in this thread) if you have any problems or further questions. -q |
| pic: FVC 2013 Gear shifter | gdo | Extra Discussion | 16 | 04-27-2007 02:25 PM |
| pic: 1732's 2 servo shifter | John Wanninger | Extra Discussion | 1 | 03-04-2007 11:27 PM |
| pic: team 1029 shifter | bjimster1 | Robot Showcase | 4 | 02-21-2006 10:23 AM |
| pic: AM shifter mount close up | falconmaster | Extra Discussion | 2 | 01-18-2006 07:27 PM |
| pic: Vex 2 Speed Mesh Shifter | Matt Krass | Extra Discussion | 11 | 10-17-2005 08:58 PM |
