OCCRA   [more] Florida Regional : 109d 08h 11m ...
Go to Post It would be a lot easier if students would quit being so magnificent. Really. - JaneYoung [more]
Team 47   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
Need it now?
University of Detroit Mercy
ADVERTISEMENT
Old 02-06-2008, 08:04 AM
Qbranch's Avatar
Qbranch Qbranch is offline
is back at Illinois.
AKA: Alex Suchko
FRC #1024 (Kil-A-Bytes)
pic: Shifter Fix
Old 02-06-2008, 08:06 AM
Tytus Gerrish's Avatar
IGAB, ADHD, and Dislexic
AKA: Ty
Team Role: Tactician
Send a message via ICQ to Tytus Gerrish Send a message via AIM to Tytus Gerrish Send a message via MSN to Tytus Gerrish Send a message via Yahoo to Tytus Gerrish Send a message via Skype™ to Tytus Gerrish
Re: pic: Shifter Fix
the sound Pnumatic shifting makes happy
"Let's just say i am the one that gives firefighters, paramedics, and law enforcement a job"
tytusg@gmail.com
Keep It Simple Stupid
Old 02-06-2008, 12:22 PM
Tom Line Tom Line is offline
Autonomouse
FRC #1718 (The Fighting Pi)
I'll second the servo issue.
Simply: servo shifting super shifters stinks.
I couldn't resist all those S's. The servos cannot shift under any type of load. The sometimes can't pull it out of gear when your robot isn't moving, and often will not go into gear at all.
We just installed a pneumatic system on the bot last night so we can shift.
Old 02-06-2008, 02:11 PM
Guy Davidson Guy Davidson is offline
AKA: formerly sumadin
FRC #0008 (Paly Robotics)
Guy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to behold
Send a message via ICQ to Guy Davidson Send a message via AIM to Guy Davidson Send a message via MSN to Guy Davidson
Q,
would you be willing to list the part numbers you used to couple and mount the encoder? We've also been having some reliability problems with the encoders and are looking into alternatives now.
Thanks.
Old 02-06-2008, 03:10 PM
Qbranch's Avatar
AKA: Alex Suchko
Unfortunately, the bracket that actually mounts the encoder we burned out on our PlasmaCAM table (yes, it's true, something from the back of a popular science magazing that works most the time). The bolts, nuts, washers I assume are self explanatory beyond their being #10-32. Honestly I don't know exactly how long the bolts are, I dug for them in the "Box of No Return" in the shop, same with the nuts and washers.
The encoder carries the same electrical specifications as the one that andy mark put on from the factory, minus being open frame and suceptible to any shocks/misalignments/runouts in the main drive shaft of the transmission.
The part number of this US Digital encoder is S4-250-B. That is, an S4 fully assembled encoder, 250 counts/rev, Ball bearing shaft.
The specific coupler is from McMaster (since we needed it quick) but could be obtained for less money from Helical (about $6 from them, $22 from mcmaster) is a 9861T609 coupling. This is a flexure coupling that goes from a 3/8" to 3/8" bore, 1" in length. If you want even more isolation from vibration/runout/whatever in the transmission, get a larger coupler with the same bores. The longer the coupler, the more isolated, however, the more weight/size.
Let me know (in this thread) if you have any problems or further questions.
-q
2008 Championship Rockwell Automation Innovation in Control Award Winners
Electrical Engineer Illini
Old 02-06-2008, 04:32 PM
in between teams
AKA: Luke Van Oort
We aren't running Super Shifters, but we are using AM Gen2 Servo Shifters, which have a very similar shifting action. We had the symptoms you describe when we tried to shift before we added some oil (I think we actually used thread cutting oil) to the dog and the shaft it slides on. After that and a little tweaking of the points the servo shifts to, the transmissions shift reliably and pretty quickly. Under heavy load, they take about one second to shift, but they do shift reliably (the only times we've missed shifts were when the servo was going to the wrong point); under light loads, the time drops well under a second. We haven't had a chance to try it out yet, but we have added some code to cut motor power for about a tenth of a second (we'll probably change that to a quarter or half a second of reduced power instead of a tenth of none), which should make shifting a bit faster.
Team 1219: 2009 - Mentor
pic: FVC 2013 Gear shifter gdo Extra Discussion 16 04-27-2007 02:25 PM
pic: 1732's 2 servo shifter John Wanninger Extra Discussion 1 03-04-2007 11:27 PM
pic: team 1029 shifter bjimster1 Robot Showcase 4 02-21-2006 10:23 AM
pic: AM shifter mount close up falconmaster Extra Discussion 2 01-18-2006 07:27 PM
pic: Vex 2 Speed Mesh Shifter Matt Krass Extra Discussion 11 10-17-2005 08:58 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
