pic: Early Bird Control System
Re: pic: Early Bird Control System
So they are, in fact, having us use those huge DB-37 cables to connect the DSCs to the cRIO.
![]() Hopefully we will be allowed to replace them with ribbon cables. |
I like seeing the 2 digital sidecars. Even though most teams won't need more than 1.
In the past I've been a little critical of First for not providing value for the fees. I with draw my judgement. Dam those Jags are big!
It even includes the Wago Tool!
There is another photo pending that shows the Victor and Jaguar side-by-side. Those Jags are massive!
I just imagine having only one Waco tool means it will immediately be misplaced. ![]() Last edited by Mark McLeod : 11-19-2008 at 01:34 PM. |
One may attempt to use lesser tools, but Hark! Thou must still be true to the spirit of The Wago Tool. Insert the tool fully, in a graceful glide. Once sheathed in its Wago Connector Home, remove thy hand from the tool and insert the stripped wire. Gently remove the tool, and smartly tug the wire to verify your success. |
that is no WOGO tool guys sorry but if you look the WOGO web site it says the WOGO tool has a "Partially insulated shaft makes this tool an optimal choice for connecting terminal blocks"
link-http://www.wago.us/products/2453.htm looks nice but man i hope they give us 5 more lbs and the jags are shiny and nice but they big and i still have questions on there air flow |
I don't think the ground will open up and swallow you whole if you use a slightly "irregular" mini screwdriver to get the job done. Last edited by Travis Hoffman : 11-19-2008 at 11:14 PM. |
#10
That is a large number of of really big components to fit in a small space.
#11
Are the joysticks comfortable (in ergonomic terms) & interchangable, or do we have two right-handed sticks again?
I'm not familiar with that brand. |
#12
![]() http://www.logitech.com/index.cfm/ga...s/302&cl=us,en |
#13
Nobody said they had to fit in a small space. Yet. We'll see in January.
#14
We might have to think outside of the box... Last edited by Lowfategg : 11-19-2008 at 02:46 PM. |
#15
Realize that a lot of the things pictured do not go on the robot. Also, many of the components are optional (pending the official rules).
| Early Shipment of the New Control System | EricVanWyk | FRC Control System | 3 | 11-05-2008 01:51 PM |
| **FIRST EMAIL**/ FRC 2009 Control System Early Release Update | dlavery | FIRST E-Mail Blast Archive | 12 | 10-15-2008 07:30 PM |
| pic: 2009 Control System, Mounted | Billfred | FRC Control System | 23 | 05-01-2008 07:02 PM |
| pic: Team 116 Modular Control System | dlavery | Robot Showcase | 42 | 10-21-2007 11:15 AM |
| pic: FIRST's New field control system | Greg Needel | Extra Discussion | 22 | 01-12-2007 09:23 AM |
