Go to Post All I ask is that you stay with FIRST. It's a great place to be - Wayne Doenges [more]
Go Back   Chief Delphi > Technical > Control System > FRC Control System
VEXpro
Pontiac Discount Pharmacy
ADVERTISEMENT
Unread 12-20-2008, 05:07 PM
Tom Line Tom Line is offline
Autonomouse
FRC #1718 (The Fighting Pi)
I think one of my Jaguars ate a chipmunk.
Once we got our test bot up and driving with the new control system, we noticed something odd.
One of our Jaguars (and only 1) makes a very interesting high pitched squeal. This occurs with the fan on or off, with the system enabled or disabled. We've checked the wiring, removed the PWM, and it continues. The pitch changes slightly when the LED blinks.
Did our Jaguar swallow a chipmunk, or is something else going on?
Unread 12-20-2008, 06:34 PM
Jon236's Avatar
Jon236 Jon236 is online now
AKA: Jon Mittelman
FRC #2648 (Infinite Loop)
Jon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond repute
Send a message via Skype™ to Jon236
Re: I think one of my Jaguars ate a chipmunk.
Maybe that's what my Jaguar did before it gave up the ghost. I sent it back to Luminary for an autopsy. Have you checked the output? Is it still linear? Keep us apprised of the ultimate fate of yours; I will do the same.
Jon Mittelman
Infinite Loop Mentor 2011-2013
TechnoTicks Mentor 2000-2011
Championship Chairman's Award 2009
Judge and Inspector 2010-2012 Championships
Judge Advisor Tel Aviv Regional 2007-2012
Judge Advisor Pine Tree Regional 2013
Maine Regional Planning Committee
New England District Planning Committee
Lead Inspector Microsoft Tel Aviv Regional 2006-2008
Judge & Lead Inspector GM/Technion Tel Aviv Regional 2006
Judge UTC Hartford Regional 2006
Unread 12-20-2008, 06:51 PM
Autonomouse
Sure thing!
That's the other part of this that's a bit odd - that particular Jag is NOT one we have put any load through at all - we are only running two sims because we rebuilt our 2006, 2007, and 2008 robots this fall. So we are only using two of the Jags, and those two are whisper silent.
Unread 12-21-2008, 03:12 PM
EricVanWyk EricVanWyk is offline
EricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond repute
Send a message via AIM to EricVanWyk
Are you positive it is the Jag squealing, and not the PD? We ran out of chipmunks while building the PDs, and had to resort to squirrels, groundhogs and ferrets.
I find it really hard to localize high pitched noises, and the PD is known to squeal.
Unread 12-21-2008, 05:15 PM
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
So what makes the PD squeal? We noticed it yesterday during the benchtest. Seems like when the Jag lights stopped blinking, the PD would "squeal". Actually sounded more like the hamster wheel than a chipmunk.
Unread 12-21-2008, 05:20 PM
EHaskins EHaskins is offline
Needs to change his user title.
AKA: Eric Haskins
no team (CARD #6 (SCOE))
EHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond repute
Send a message via MSN to EHaskins Send a message via Skype™ to EHaskins
I believe the noise from the PD is related to the voltage regulators for the 24v(cRio), 5v(Camera), and 12v(WiFi) regulated outputs, but I'm not an electrical engineer so I'm probably wrong.
Eric Haskins KC9JVH
Unread 12-21-2008, 08:23 PM
The source of the PD squeal is the 12V (and sometimes 24V) boost supplies. Nominally, the boost supply runs at ~600kHz - way out of the audible range. What you are hearing is somewhere in the 20kHz region(ish).
The boost circuit (inductor specifically) was sized to be able to handle the maximum stress conditions. Since it has a fixed frequency and a minimum on time, there is a minimum amount of work it can do in any given cycle. If it is asked to do less, it will simply go to sleep for a few cycles before trying again. This napping or "pulse skipping" happens in the audible range.
Obnoxious? Yes.
Bad? No.
Unread 12-21-2008, 09:45 PM
AKA: Eric Haskins
Obnoxious? Yes.
Bad? No.
Thanks for the details.
Eric Haskins KC9JVH
Advantages of the Jaguars? EricVicenti Electrical 36 03-03-2009 07:16 PM
What Do You Think About Teams Winning More Than One? Cow Bell Solo Awards 13 04-07-2008 04:42 PM
I think these guys have just one-upped Dave... geeknerd99 Chit-Chat 11 11-22-2006 06:18 PM
javascript ate my cereal! steveg IT / Communications 2 03-29-2004 12:10 AM
One way to think about it. Joe Johnson General Forum 16 10-07-2001 08:21 PM
