OCCRA   [more] Florida Regional : 109d 22h 50m ...
Go to Post These people however realize WHEN to screw around and have fun, and when to be serious and have fun. - Enigma's puzzle [more]
Team 47   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
Innovation First, Inc.
Delphi
ADVERTISEMENT
Old 01-01-2009, 07:22 PM
JHSmentor's Avatar
JHSmentor JHSmentor is offline
AKA: Bryan Molloseau
FRC #2374 (Jesuit Crusaderbots)
JHSmentor is a jewel in the roughJHSmentor is a jewel in the roughJHSmentor is a jewel in the roughJHSmentor is a jewel in the rough
pic: 6wd - revised - feedback requested
Old 01-01-2009, 07:23 PM
chris31 chris31 is offline
Team 2021 Captain
AKA: Chris Davidson
FRC #2021 (FA Robotics)
chris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond repute
Send a message via AIM to chris31 Send a message via Skype™ to chris31
Re: pic: 6wd - revised - feedback requested
Those bottom plates could very well be where you under up mounting your electronics and battery. If you are going to make this is would originally leave the bedpan out and layout the electronics and batteries and determine what material you can cut out after these components have been mounted.
Old 01-01-2009, 07:24 PM
gorrilla's Avatar
gorrilla gorrilla is offline
the STOD is STOP'd
AKA: adam spears
FRC #1557 (12voltbolt)
gorrilla is a splendid one to beholdgorrilla is a splendid one to beholdgorrilla is a splendid one to beholdgorrilla is a splendid one to beholdgorrilla is a splendid one to beholdgorrilla is a splendid one to beholdgorrilla is a splendid one to behold
why omni's in all four corners?
you could probobly get away with just having them in the back(and not have to drop the center wheels)
Adam Spears
2009: Florida Regional Chairmans!!!!!!!
2009: Rockwell Automation Innovation in Controll Award
Old 01-01-2009, 08:09 PM
rc_cola1323's Avatar
rc_cola1323 rc_cola1323 is offline
EWCP/CAD/CNC/PWNMATICS
AKA: Killer ICE Miller
FRC #1323 (Madtown Robotics - EWCP Founder)
rc_cola1323 has a reputation beyond reputerc_cola1323 has a reputation beyond reputerc_cola1323 has a reputation beyond reputerc_cola1323 has a reputation beyond reputerc_cola1323 has a reputation beyond reputerc_cola1323 has a reputation beyond reputerc_cola1323 has a reputation beyond reputerc_cola1323 has a reputation beyond reputerc_cola1323 has a reputation beyond reputerc_cola1323 has a reputation beyond reputerc_cola1323 has a reputation beyond repute
Send a message via AIM to rc_cola1323
I like it but:
-40 lbs is a lot with cnc work in it, supershifter are about 18 lbs if you don't lighten them.
-Why omni's, use 2 in the front. If you put the ones in the back you'll get pushed around and levered.
Otherwise, nice design.
Old 01-01-2009, 08:59 PM
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
FRC #2175 (Fighting Calculators)
Originally Posted by rc_cola1323 View Post
I like it but:
-Why omni's, use on the 2 in the front. If you put you'll get pushed around and levered.
I will pt in the siggestion here to see what the game is before deciding on a drivetrain.
Last year my team went with a 4 omni 6WD setup and we were not spun or turned at all during our regional. As I recall 488 also uses the 4 omni 6WD setup and is generally happy with it.
We felt that with the 2008 field layout it would be difficult for a team to get into a position to try and spin us and we wanted our turn center to be centered so we went with the 4 omni 6 WD.
Old 01-01-2009, 09:29 PM
I have never been a fan of omni's and i have seen a lot of teams getting turned with them. But if it works for you guys then ok, sounds great then.
Old 01-01-2009, 10:04 PM
GUI GUI is offline
AKA: Gary
FRC #1726 (N.E.R.D.S.) and FTC 3272 (Robotillamacorns)
GUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to behold
You might not want to put the lightening holes in the bellypan, it would be easier to mount the electronics without them, and you only save about 2 1/2 pounds. Also, I would be wary of using this design withoug adding gussets on the top corners, it will be a lot stronger with them. You may want to lighten the super shifters a little, if you're concerned about weight.
-Gary Forbes
I <3 the Rotex punch
Old 01-01-2009, 10:23 PM
JHSmentor's Avatar
Thx for the suggestions.
We used the 4 omni's last year and it worked very well - although I am definitely keeping options open to use only 2 in the front. obviously the game may make this whole design not very good anyway.
The gussets have been suggested often and it's probably something we will strongly consider. Just worried about them getting in the way. We didn't use them last year but our whole chassis was 3/16" rather than 1/8" so maybe that made the difference. Plus we didn't have any huge impacts.
All of the lightening holes will be dependent on if we can find a shop to help us. Otherwise we have ZERO ability to do anything this fancy. I would love to lighten the Super Shifters as well but that's way beyond our abilities as well.
this design is already 20+ lbs lighter than last years so even if we couldn't do everything shown here then we are a little ahead already.
thx,
Old 01-02-2009, 02:51 AM
Don Rotolo's Avatar
Don Rotolo Don Rotolo is offline
Almost ready 2 start another season
FRC #1676 (Pascack PI Oneers)
Don Rotolo has a reputation beyond reputeDon Rotolo has a reputation beyond reputeDon Rotolo has a reputation beyond reputeDon Rotolo has a reputation beyond reputeDon Rotolo has a reputation beyond reputeDon Rotolo has a reputation beyond reputeDon Rotolo has a reputation beyond reputeDon Rotolo has a reputation beyond reputeDon Rotolo has a reputation beyond reputeDon Rotolo has a reputation beyond reputeDon Rotolo has a reputation beyond repute
Make sure there are places at the top edge to mount superstructure (i.e., manipulator), perhaps turn the top edge of the inner rails inward. Maybe make them a little taller too, so the top is just above the tops of the wheels - your manipulator team will love you for giving them a perfectly flat surface the size of the whole robot (your maintenance work will be from the bottom looking up). Also, count on using your bumpers as structural elements, which means only the mounting points on the outer rails need to be strong, the rest can be weak because you have that 3/4" plywood holding it all together. For the bottom plate, consider fewer and smaller lightening holes, as mentioned above so you can easily mount your electronics and gear there. Last, line up the shift pistons and use just one to shift both at the same time. There's a thread here somewhere that shows how one team did that.
Team 1676 - Pascack π-o-neers
Attending: Brunswick Eruption 8, Newark Kickoff; NJ Regional
2009 Palmetto Regional Chairman's Award
2008 NJ Regional Chairman's Award
2008 Chrysler Team Spirit Award, GTR
2007 NJ Regional: 3rd seed, Best Website Award, Johnson & Johnson - Sportsmanship Award, Motorola Quality Award
2007 Buckeye Regional: Motorola Quality Award (again)
2006 Palmetto Regional Finalists (with 16 & 95)
FVC 1676: 2006 Garden State Rumble Champions
2005 NJ Regional Rookie All-Stars
Old 01-02-2009, 07:42 AM
TVan's Avatar
TVan TVan is offline
FRC #0085 (BOB)
TVan is an unknown quantity at this point
Are the standoff bolts in the path of the chains ? maybe just one bolt
in the center will be ok, Or you could put a slot in this area to mount chain
tensioners, A shaft with tapped holes in the ends and a small roller
on it may work as a stand off and a chain tensioner.
Caution this is a untested idea, just a quick thought
thank you for posting your chassis it looks great,
Tim
Old 01-03-2009, 03:32 AM
bmarick bmarick is offline
FRC #2374 (Crusader Bots)
bmarick is on a distinguished road
Thumbs up Re: pic: 6wd - revised - feedback requested
This looks Great Brian.
I would disagree this will be enough to mount our electonics and phenumatics.
One worry that I agree with is the bumbers. Thanks for doing this.
From what I hear form jordan, Crossbracing the cornors would be a good ideal it would give some solid regidity. This can be ssen in our cornors of last years bot.
To finish it off it we can't decide what we will use for wheels until the game is anounced.
See you tomorrow.
Old 01-03-2009, 03:59 AM
CraigHickman's Avatar
CraigHickman CraigHickman is offline
doesn't bite, often.
AKA: Wut.
FRC #9001 (Unaffiliated, currently. Anyone need a mentor?)
CraigHickman has a reputation beyond reputeCraigHickman has a reputation beyond reputeCraigHickman has a reputation beyond reputeCraigHickman has a reputation beyond reputeCraigHickman has a reputation beyond reputeCraigHickman has a reputation beyond reputeCraigHickman has a reputation beyond reputeCraigHickman has a reputation beyond reputeCraigHickman has a reputation beyond reputeCraigHickman has a reputation beyond reputeCraigHickman has a reputation beyond repute
Talk to Madison from 488 about their experience using Omni's in a traction 6 wheel drive. She's got some GREAT insight and experience there.
Otherwise, looks pretty good. Might want to work on using less material by means of design instead of CNC pocketing... I'm SURE you can achieve a lighter, stronger base with less machine time. Keep at it!
pic: 6wd chassis - need feedback JHSmentor Extra Discussion 22 01-01-2009 02:20 PM
pic: FR 1771 Drivetrain Revised sdcantrell56 Extra Discussion 7 09-03-2008 09:26 PM
Sundial - Feedback Requested, Please Pat Fairbank General Forum 39 05-03-2006 08:51 PM
pic: Revised Ball Shooter cleonavicius Robot Showcase 7 01-29-2006 05:26 PM
pic: Revised* Another view CD47-Bot Robot Showcase 5 04-29-2004 10:50 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
