pic: Robot-Week1
Re: pic: Robot-Week1
Wow, please give some specifics!
Well, wide chassis w/ 4 wheel skid steering, all powered. Obviously the drive isn't installed yet.. right now it's on a test robot w/ our electronics guys.
We plan on a conveyor type system to run between those wood panels, and feed the huge hopper (we estimate it holds around 20 balls), then a front panel on the hopper will drop and (the hopper will have an agitator) the balls will drop out... If you check out http://www.youtube.com/watch?v=Lcjl8nWDzmo at around 0:32 is a little clip of how we plan to coveyor the balls up. |
If you thought poof balls jammed easily... well... have I got a suprise for you ![]() See y'all in Davis! |
i can't explain it... But just half a half circle that starts up like a n then swings around to the bottom like a u. The top of the u/the bottom of the n is there the bottom of the hopper is... if that makes sense. pivoting around the bottom of the hopper. |
I have a question about the tabs sticking out from the hopper, are they to "grab" balls of to sort the out as in a peg board, so they dont get jammed. or if both ideas are wrong what is thier purpose. I like were the direction of the robot is going. Also what kind of rope/ tubeing are you using for the conveyor.
I would suggest putting some kind of large pipe on those thin rods because what ever you use as belting will grip more onto a larger surface and it won't slip on the balls (This breaks the basic idea that surface area doesn't effect friction because the surfaces actually aren't parallel so each point has a separate force, kinda weird but ya)
Some 1" surgical tubing from McMaster has been ordered... We've used it with success. Quote:
But, we've been joking that I'd post another picture like this after week 5 and it would just show a crate and an empty shop... We all know that won't happen though ![]() |
#10
Aww Brad you beat me to the post
Oh BTW our new website has been posted with some other pictures of our bot during week 1. Check us out at: www.team399.org |
#11
How far deep inside your bumper perimeter is that mechanism going to be?
I'm just asking, because I feel you ought to make sure to that that wouldn't have an off chance of being considered a wedge. You're making good progress, though. Keep at it. |
#12
Good progress for Week 2
Well I thought I would beat all you guys to the punch this week...
Check out the Team399 Videos for this week. http://www.youtube.com/user/cevTV399 http://www.youtube.com/watch?v=isP11...eature=related Have fun!!! |
#13
I saw you were using surgical tubing in the video...we used that in 2006 for the poof balls. It worked quite well, except we would have to change the tubing every so often because it would rip or start to rip. We just got some new type of tubuing yesterday that we are going to use...can't remember what it is called, but it has the same effect that the surgical tubing did, but it is much much stronger!
#14
This looks a lot taller than 60". Is it?
| pic: 166's Robot '07 Robot: Gemini | InfernoX14 | Robot Showcase | 4 | 02-20-2007 09:41 PM |
| pic: 233 robot teaser, yep, theres our robot ; ) | ducttapedude | Extra Discussion | 20 | 02-15-2007 10:02 PM |
| pic: 1889 Team HAZE's frame (week1) | Tytus Gerrish | Extra Discussion | 8 | 01-19-2007 02:23 AM |
| pic: Team 114 Real Robot Vs. Inventor Robot | James114 | Robot Showcase | 3 | 02-18-2005 01:02 PM |
| pic: Closeup of the robot hanging on robot | CD47-Bot | Extra Discussion | 16 | 03-09-2004 06:27 PM |
