Gearboxes for shooter?
oh-kay....
so we've been prototyping a shooter mechanism, using a CIM and the kit wheels from last year...only problem, we dont have any (easy) ways of powering it, toughboxes only give us around 300 RPM, so we took out a few gears and got it down to 4:1 wich should give us around 1200 RPM(hopefully) now ive heard(read) about other people just directly driving the wheel off the cim motor how can this be done? 1200 RPM should be enough right? if not we can use chain reduction(upduction ) so the question is....what other ways are there to do this? (yes i read the other thread, this is more from a assembely standpoint though) |
Re: Gearboxes for shooter?
we're using a CIM on a 9:1 Banebots planetary. Gives us more torque so the wheel doesn't slow down as much as each ball goes through, and still keeps a hefty RPM on the wheel. Also theres the added benefit of really easy direct mounting since the output shaft is a simple 1/2" OD with a 1/8" keyway. Though we are actually going to use a sprocket combination with it to give the possibility of high torque or high RPM based on what our testing shows.
using a hub?
we have the 12:1 BB's but there kinda slow... |
Well, the CIM is actually 4300 rpm
http://www2.usfirst.org/2005comp/Specs/CIM.pdf I'll assume it hasn't changed since 2005 |
You can use a shaft on your wheel and a love joy shaft coupler to connect the two shafts.
You might consider using only a belt or chain drive, with a reduction ratio of about half the inch diameter of the wheel. ie. 4:1 for an 8" wheel. With the smaller pulley/sprocket on the motor.
thats what we did, one CIM in a toughbox chained to a sprocket(which is bolted) on a 5/8 shaft. (using two kit wheels from last year, bolted together(not attached to the shaft at all!!! just the compressin of the wheel-bolts and the plastic hubs are enough to hold it on the shaft nicely) works pretty well, we are getting around 6ft maximum distance, and at 4ft were getting around 80% accuracy |
A couple of years ago, for Aim High, we decided to just direct drive the wheels with a connector we designed to fit with the keyed shaft. It took some time to design the right parts but it worked well. It was a last minute addition and due to weight we didn't get to use it, but it worked really well. It's just another option.
A direct drive from the 2.5" CIM is more than enough speed to get you more than your 6ft max distance with a 6" wheel. |
#10
But if your system needs alot of torque a direct drive CIM may not cut it. Attached directly to a 6" wheel I think it would get you much further (20 feet or more), but if you don't want that distance it helps to gear down and limit your distance but be able to fire balls at an even higher rate.
#11
Be sure to read the other related thread
http://www.chiefdelphi.com/forums/sh...threadid=71854 Seems that it's possible to make it work with a direct drive CIM, or with chain/gear reduction. We're planning to build ours with chain reduction, that can be changed to see what works best. |
#12
Might want to check out Joe's "Nothing but Dewalts" White paper.
The combination of 3:1, 4:1 and 12:1 with servo shifting on the fly, plus the fact they are a fraction of the weight of the Banebots gearboxes make them a lovely addition to any FRC robot. We ran them last year on our drivetrain and were very impressed. You might even see 4 or 5 of them on our 2009 bot ![]() |
#13
Some considerations that haven't been mentioned:
Good Luck! -John Last edited by JVN : 01-14-2009 at 11:58 AM. Reason: I missed one... thanks KP. |
#14
I think he could have cut and pasted from any year to get the experiment quote
| motor for ball Shooter? | excel2474 | Motors | 42 | 01-15-2009 08:48 AM |
| which gearboxes can we use for this year? | mahmosh | Kit & Additional Hardware | 2 | 01-09-2009 06:52 PM |
| Which pinions for FP motors and BaneBots 42 mm gearboxes? | Madison | Technical Discussion | 3 | 01-23-2007 07:04 PM |
| Speed Sensor for Ball Shooter | Justin Stiltner | Electrical | 15 | 01-28-2006 01:40 PM |
