OCCRA   [more] Florida Regional : 109d 16h 43m ...
Go to Post before you post, ask yourself: Is there a good reason to post this? - Jeff Waegelin [more]
Team 47   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
HEXBUG Nano
Tormach
ADVERTISEMENT
Old 03-20-2009, 12:40 PM
basicxman's Avatar
basicxman basicxman is offline
Will program PHP for food
AKA: Andy
FTC #0168 (Mini Robotics)
basicxman has much to be proud ofbasicxman has much to be proud ofbasicxman has much to be proud ofbasicxman has much to be proud ofbasicxman has much to be proud ofbasicxman has much to be proud ofbasicxman has much to be proud ofbasicxman has much to be proud of
Send a message via MSN to basicxman Send a message via Skype™ to basicxman
pic: Why LEGO Should Not Be In Tetrix
Old 03-20-2009, 12:44 PM
Barry Bonzack's Avatar
Barry Bonzack Barry Bonzack is offline
Frequent self humbler
AKA: The guy in the umbrella hat
FRC #1902 (Exploding Bacon)
Barry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond repute
Send a message via AIM to Barry Bonzack Send a message via Skype™ to Barry Bonzack
Re: pic: Why LEGO Should Not Be In Tetrix
...Or engineer new creative ways to program and build your robot to work around the challenges and limits given to your team with your kit.
Example one: Program the robot to slow down before running into a wall.
This will only protect it in autonomous mode, a run in with another robot will still most likely make it snap. You may need to engineer a way for something to come down to protect it the rest of the match, or put it on a servo so it hides itself safely in the robot.
Example two: Don't use the Touch Sensor. The ultrasonic sensor can read walls from a short distance without running into it. Use the touch sensor as a limit switch when necessary.
Welcome to Harmony, home ofunderwater robotics.
No animals were harmed in the making of this post.
Old 03-20-2009, 12:49 PM
basicxman's Avatar
AKA: Andy
Oh I've engineered a way to protect it. The reason why I'm using a touch sensor is because it's the only sensor with a multiplexer for it. We only have 3 sensor ports y'know. This is still pathetic, point being if FIRST wants a "real world robotics experience" plastic LEGO should not be part of it.
Old 03-20-2009, 02:16 PM
meaubry meaubry is offline
None #0047 (Chief Delphi)
Rookie Year: 1994
meaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond repute
Many times materials are included in kits of parts that require careful planning and analysis to determine if they will "hold up" to the application and environment it will be exposed to.
That is part of the challenge.
Often, we make decisions about what parts we will use and which won't we will not use. Not all of the parts are intended or expected to fit every situation.
Embrace the challange and use this as a learning / teaching experience.
Lego parts have a place and function in the kit, but perhaps not the way you are using them.
Old 03-20-2009, 06:24 PM
Abra Cadabra IV's Avatar
Abra Cadabra IV Abra Cadabra IV is offline
Needs more zip ties
AKA: Katy W.
FRC #2429 (LCEC), FTC #25 (Rock-n-Roll Robots)
Abra Cadabra IV will become famous soon enough
I think that the Lego can hold up under pressure if the structures are designed right. Purely Lego structures aren't going to be very stable, but a smart mixture of Lego and metal will be more functional than either of the two on their own.
For example, the main structure of the claw on my team's robot is made of metal, but most of what actually touches the pucks is Lego. The result is that the metal takes all the load when we run into something, but we still have much more functionality than a purely metal claw could give us. (Our heavy robot actually tipped off the ramp and fell on the claw once but only bent it, as compared to other robots which left bits of their purely-Lego claws all over the field after every match.)
FRC Team 2429 - LCEC
FTC Team 25 - Rock 'n' Roll Robots
Old 03-20-2009, 06:37 PM
keehun's Avatar
keehun keehun is offline
Team Captain/Driver/Lead Programmer
AKA: Keehun Nam
FRC #2502 (Friedman Robotics)
keehun has much to be proud ofkeehun has much to be proud ofkeehun has much to be proud ofkeehun has much to be proud ofkeehun has much to be proud ofkeehun has much to be proud ofkeehun has much to be proud ofkeehun has much to be proud ofkeehun has much to be proud of
Send a message via AIM to keehun
I sense your frustration, but don't take it out on people here because all they are is trying to help you down the road for bigger and more important things.
I do agree that whoever or whichever group that designated items to go in the kit of parts is not dumb so don't assume that they never thought about the strength of the legos in the KOP.
Next time, just take factors such as strength in to consideration and if it falls short, engineer around the problem.
If you know the Chinese Rainbow Bridge, it takes so little wood (just enough food for the walkway) and yet it is so nicely and cleverly engineered that the forces are distributed well and it can hold a lot more weight than you ever imagined.
The amount of wood that it used should never hold that many people (the painting) or the picture below, but it is indeed, possible.
Not criticizing you that you under-thought the process of design, but merely pointing out that don't think that we don't know the strength of some lego pieces and that you can always prevent things of this nature for next time
Good luck at nationals!
Keehun
FRC Team 2502
2009: Quarter Finalist (MN 10,000 Lakes)
2009: GM Industrial Award
[FTC]: Attaching Tetrix to LEGO motors. ttldomination FIRST Tech Challenge 5 01-23-2009 10:13 PM
Why you should use Gmail Nathan Chit-Chat 5 02-22-2007 12:20 AM
pic: Why Workdays should not go past 9pm. insomniac6688 Extra Discussion 14 02-04-2007 06:49 PM
Why should Andy be on Survivor? George1902 General Forum 24 06-21-2004 01:19 AM
Why I think FIRST should reconsider... Joe Johnson General Forum 36 01-14-2003 03:51 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
