OCCRA   [more] Florida Regional : 110d 01h 44m ...
Go to Post This is just one example of why you MUST NOT make engineering decisions based on assumptions. You should check/measure your parts and make appropriate design adjustments. - Stu Bloom [more]
Team 47   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
HEXBUG Nano
Delphi
ADVERTISEMENT
Old 06-18-2009, 02:04 AM
kajeevan kajeevan is offline
FRC #0188 (blizzard)
kajeevan is just really nicekajeevan is just really nicekajeevan is just really nicekajeevan is just really nicekajeevan is just really nice
pic: Prototype 6WD
Old 06-18-2009, 02:05 AM
Jon Jack's Avatar
Jon Jack Jon Jack is offline
Couldn't Quite Bring One Home...
AKA: Mentor / Coach
FRC #1538 (The Holy Cows)
Jon Jack has a brilliant futureJon Jack has a brilliant futureJon Jack has a brilliant futureJon Jack has a brilliant futureJon Jack has a brilliant futureJon Jack has a brilliant futureJon Jack has a brilliant futureJon Jack has a brilliant futureJon Jack has a brilliant futureJon Jack has a brilliant futureJon Jack has a brilliant future
Send a message via AIM to Jon Jack
Re: pic: Prototype 6WD
I can't see clearly, but why are your gearboxes offset from the center wheel? How are you running your chain?
Team 1538 - The Holy Cows - Got FIRST?
2007 San Diego Regional - Delphi "Driving Tomorrow's Technology" Award & Semi-Finalists w/ 1852 & 1388
2007 Las Vegas Regional - Imagery Award & Semi-Finalists w/ 1572 & 8
2008 San Diego Regional - Woodie Flowers Award, Imagery Award & Semi-Finalist w/ 1158 & 1671
2008 Los Angeles Regional - Xerox Creativity Award / Engineering Inspiration & Quarter-Finalists w/ 207 & 589
2009 San Diego Regional - Woodie Flowers Award, Finalists w/ 1388 & 1348, Chairman's Award
2009 Las Vegas Regional - Imagery Award, Semi-Finalists w/ 254 & 2339
2009 World Championship - Semi-Finalists w/ 1503 & 1649/176
2009 IRI - Quarter-Finalists w/ 2775, 2056 & 148
2009 Fall Classic - Judges Award, Champions w/ 399 & 980
Old 06-18-2009, 02:18 AM
NickE's Avatar
NickE NickE is offline
Driver/Mechanical/CAD
AKA: Nick Eyre
FRC #0254 (The Cheesy Poofs), VRC #254b, #254s (The Cheesy Poofs)
Send a message via AIM to NickE
It looks like a direct driven center wheel to me. The final gear reduction is hard to see (Looks like a supershifter using standoffs instead of the stock extruded body).
Nick Eyre
FRC Team 254 Driver / Pit / FRC Captain / CAD Captain
2009 FRC254 Record: 41-19-1
VRC Team 254b Member
VRC Team 254s Captain
Old 06-18-2009, 10:37 AM
Chaotic Itinerancy
AKA: Jesse
FRC #1885 (iLITE)
I love the use of U-channel, however usually U-Channel is weaker at the bends than C-channel. This would worry me on the outside rails on a high-impact carpet game. To keep the frame stiff, I would use C-channel on the inside (usually for those dimensions you can only find 3" base with 1.5" legs or a 4" base with 2" legs and both have a ~3/16" radius on the inside corners of the bend) and 2x1" or 3x1" box extrusion on the outside. It's roughly the same weight, stiffer, and much stronger on the outside. Possibly a little more expensive depending on the supplier. For a prototype this looks good!
Fail faster to succeed sooner, especially if your plans are ambitious.
www.battlefieldrobotics.org
The site is all student-built and
mentor-abused, believe it or not.
Old 06-18-2009, 10:43 AM
AM SS steel hex driven direct drive
42lbs w/no lighting
should take one day to build
can use 25/35 chain
tensioners are floaters
wheels are CNC baltic birch used in every 188 drive train
AM bearing hubs/hex hubs/sprockets/spacers
Old 06-18-2009, 08:16 PM
Jon Jack's Avatar
AKA: Mentor / Coach
Okay, I see now. I couldn't tell if that was a SS or not.
Old 06-19-2009, 11:41 AM
Joyride_67_1902's Avatar
Joyride_67_1902 Joyride_67_1902 is offline
AKA: Andrew Remmers
FRC #1902 (Exploding Bacon)
Joyride_67_1902 is an unknown quantity at this point
Send a message via AIM to Joyride_67_1902
still looks really cool tho great jon
Old 06-19-2009, 11:43 AM
AKA: Andrew Remmers
job*
Old 06-21-2009, 12:38 PM
Cyberphil's Avatar
Cyberphil Cyberphil is offline
AHH HA!
AKA: Phil
FRC #0103 (Cybersonics)
Cyberphil is a splendid one to beholdCyberphil is a splendid one to beholdCyberphil is a splendid one to beholdCyberphil is a splendid one to beholdCyberphil is a splendid one to beholdCyberphil is a splendid one to beholdCyberphil is a splendid one to behold
Send a message via AIM to Cyberphil
Let me just say this. I will warn you about chains right now. There are a lot more problems that chains will have rather than gears. I will suggest you use gears before you go too headlong into chains. Ask team 79. They could have won in Florida if their chains didn't break.
Old 06-21-2009, 01:25 PM
Andrew Schreiber's Avatar
457
Send a message via AIM to Andrew Schreiber Send a message via Skype™ to Andrew Schreiber
Properly aligned and tensioned chain should NOT break under FRC loads. I know many teams have been using #25 chain for years without problems. If you feel uncomfortable using #25 chain feel free to use the heavier #35 because it will allow you to be lazy when you are tensioning and aligning.
I think we have officially reached the stage of having too much time on our hands. ~ Ed Patterson
27->397->[][]
Old 06-21-2009, 01:30 PM
rtfgnow's Avatar
rtfgnow rtfgnow is online now
Electrical Sub Team Leader
AKA: Alex Tannahill
FRC #0079 (Team Krunch)
Team Role: Electrical
rtfgnow has a reputation beyond reputertfgnow has a reputation beyond reputertfgnow has a reputation beyond reputertfgnow has a reputation beyond reputertfgnow has a reputation beyond reputertfgnow has a reputation beyond reputertfgnow has a reputation beyond reputertfgnow has a reputation beyond reputertfgnow has a reputation beyond reputertfgnow has a reputation beyond reputertfgnow has a reputation beyond repute
Send a message via AIM to rtfgnow
The chain did not break, it came off the gear. We added some metal to our lexan to preven vibration, this was on our manipulator, not the drivetrain.
2009 Tempest N Tampa champion with 1369, 1902 and 801
2009 Minnesota North Star Regional champion with 2970 and 2549
2009 Minnesota North Star Regional Motorola Quality Award
2009 Minnesota North Star Regional Kleiner Perkins Caufield & Byers Entrepreneurship Award
2009 Florida Regional Finalist with 744 and 1251
2009 Florida Regional Motorola Quality Award
2008 Tempest N Tampa Finalist with 801 and 2425
2008 Mission Mayhem Champion with 180 and 1902
2008 Mission Mayhem Judges' Award
2008 Florida Regional Motorola Quality Award
Old 06-21-2009, 02:08 PM
Akash Rastogi's Avatar
Einstein 2010
AKA: lilstogi, Stogi, stogez
FRC #0011 (MORT)(EWCP)
Send a message via AIM to Akash Rastogi
Actually most teams who switch to just gears: you guys, 25, 1403, some more, tried chain first just like the rest of us.
Yes chain has its problems and gears sometimes have their benefits in a DT, but when the design is based on good tensioning and weight is considered their priority you can't go wrong with chain.
We were happy not to have any chain in our drive train this year too though But I wouldn't necessarily bypass chain, especially when its a veteran team like Blizzard.
BAE Systems SIEMENS Corporation Givaudan Kozak Precision MachineryMORT EST. 1996- Doing What We Do, And Moving Forward
2009- Philly Quarterfinalists & 7th seed, NJ Semifinalists & Spirit Award
2008- Championship Archimedes 1st seed & Semifinalist, Chesapeake Winner, NJ Finalist
2007- NYC Delphi's Driving Tomorrow's Technology Award & Semifinalist, NJ Quarterfinalist
Old 06-21-2009, 03:20 PM
188 has a very reliable gear drive like 25 which has never broken once during competition the 2yrs we have used it but some of us think if we had more weight like 10-15lbs we could have built a much better function. I m hoping that the mentors will allow me to build and then break it thru tests to find the breaking point of the 25 chain vs the 35 in FIRST scenarios and see if anything else breaks over an extended period. Also to figure out if floaters are good enough to tension the chain and such.
Old 06-21-2009, 03:44 PM
sdcantrell56's Avatar
FRC #1771 (404 The Unknown Error)
sdcantrell56 has much to be proud ofsdcantrell56 has much to be proud ofsdcantrell56 has much to be proud ofsdcantrell56 has much to be proud ofsdcantrell56 has much to be proud ofsdcantrell56 has much to be proud ofsdcantrell56 has much to be proud ofsdcantrell56 has much to be proud ofsdcantrell56 has much to be proud ofsdcantrell56 has much to be proud of
There is absolutely no reason that a team should be worried about using either #25 or #35 chain on a FIRST drivetrain as long as simple precautions are taken such as proper alignment and tensioning. If the chain is taut and completely aligned there will not be any problems with it breaking. Additionally, it is much more difficult to machine a drivetrain to use gears versus chain and the gears will be much heavier.
2009 Palmetto Champion
2009 GM Industrial Design Award
2009 Rockwell Automation "Innovation in Control" Award
2008 Championship Xerox Creativity Award
Old 06-21-2009, 07:24 PM
Aren_Hill's Avatar
OUT THINK US
FRC #1625 (Winnovation)
Send a message via AIM to Aren_Hill
08 swerve, 8 runs of #25 chain, how many issues we had with them? 0
if you simply pay attention and take care when aligning and tensioning it, it will not go anywhere on you. (1 of those runs was holding back several hundred lbs of surgical tubing)
btw this is biohazard a former world champion battlebot i believe
and it uses #25 chain for the drive
http://www.botshop.150m.com/Biohazard.jpg
simple bots are weird
pic: FRC1293 Prototype 6wd Chassis Thermal Extra Discussion 16 01-06-2009 11:12 PM
pic: 6wd prototype chassis Collin Buchan Extra Discussion 7 01-03-2009 10:00 AM
pic: 6wd prototype chassis Collin Buchan Extra Discussion 3 01-02-2009 02:14 PM
pic: GUS Team 228's 6WD Sheet Metal Prototype Chassis artdutra04 Extra Discussion 14 01-02-2009 02:11 AM
pic: re-modified 6wd spc295 Extra Discussion 15 11-19-2008 03:14 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
